Gönderen Konu: Linux Mint 19.1 Cinnamon Rastgele Oturum Kapanıyor  (Okunma sayısı 249 defa)
Çevrimdışı own
  • İleti: 38
Merhaba
Linux Mint 19.1 Cinnamon kullanıyorum. Bilgisayarım 8 saatlık çalışma diliminde 3 5 defa kendiliğinden  logoff oluyor. Bilgisayarı tekrar açtığımdaki log dosyaları aşağıdaki gibidir.
13:07:24 systemd: Started Locale Service.
13:07:24 dbus-daemon: [system] Successfully activated service 'org.freedesktop.locale1'
13:07:23 systemd: Starting Locale Service...
13:07:23 dbus-daemon: [system] Activating via systemd: service name='org.freedesktop.locale1' unit='dbus-org.freedesktop.locale1.service' requested by ':1.232' (uid=1000 pid=21177 comm="flatpak update -y " label="unconfined")
13:07:02 cinnamon-killer: Bound Cinnamon restart to <Control><Alt>Escape.
13:07:02 polkitd: Registered Authentication Agent for unix-session:c8 (system bus name :1.228 [/usr/lib/policykit-1-gnome/polkit-gnome-authentication-agent-1], object path /org/gnome/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8)
13:07:02 dbus-daemon: [session uid=1000 pid=20970] AppArmor D-Bus mediation is enabled
13:07:00 pulseaudio: [pulseaudio] backend-ofono.c: Failed to register as a handsfree audio agent with ofono: org.freedesktop.DBus.Error.ServiceUnknown: The name org.ofono was not provided by any .service files
13:07:00 bluetoothd: Endpoint registered: sender=:1.221 path=/MediaEndpoint/A2DPSink
13:07:00 rtkit-daemon: Supervising 3 threads of 1 processes of 1 users.
13:07:00 pulseaudio: [pulseaudio] pid.c: Stale PID file, overwriting.
13:07:00 rtkit-daemon: Supervising 1 threads of 1 processes of 1 users.
13:07:00 at-spi-bus-laun: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
13:07:00 systemd: Removed slice User Slice of lightdm.
13:07:00 (sd-pam): pam_unix(systemd-user:session): session closed for user lightdm
13:07:00 systemd: Received SIGRTMIN+24 from PID 20728 (kill).
13:07:00 systemd-logind: Removed session c7.
13:07:00 systemd: Started Session c8 of user aykutdemirci.
13:07:00 systemd-logind: New session c8 of user aykutdemirci.
13:07:00 systemd: Stopped Session c7 of user lightdm.
13:07:00 lightdm: pam_unix(lightdm:session): session opened for user aykutdemirci by (uid=0)
13:07:00 systemd: Stopping Session c7 of user lightdm.
13:06:55 lightdm: pam_succeed_if(lightdm:auth): requirement "user ingroup nopasswdlogin" not met by user "aykutdemirci"
13:06:55 lightdm: PAM adding faulty module: pam_kwallet5.so
13:06:55 lightdm: PAM unable to dlopen(pam_kwallet5.so): /lib/security/pam_kwallet5.so: cannot open shared object file: No such file or directory
13:06:55 lightdm: PAM adding faulty module: pam_kwallet.so
13:06:55 lightdm: PAM unable to dlopen(pam_kwallet.so): /lib/security/pam_kwallet.so: cannot open shared object file: No such file or directory
13:06:55 systemd: Started Virtual filesystem service.
13:06:55 dbus-daemon: [session uid=111 pid=20659] Successfully activated service 'org.gtk.vfs.Daemon'
13:06:55 systemd: Starting Virtual filesystem service...
13:06:55 dbus-daemon: [session uid=111 pid=20659] Activating via systemd: service name='org.gtk.vfs.Daemon' unit='gvfs-daemon.service' requested by ':1.1' (uid=111 pid=20655 comm="/usr/sbin/slick-greeter " label="unconfined")
13:06:55 systemd: Started Accessibility services bus.
13:06:55 dbus-daemon: [session uid=111 pid=20659] Successfully activated service 'org.a11y.Bus'
13:06:55 systemd: Starting Accessibility services bus...
13:06:55 dbus-daemon: [session uid=111 pid=20659] Activating via systemd: service name='org.a11y.Bus' unit='at-spi-dbus-bus.service' requested by ':1.4' (uid=111 pid=20655 comm="/usr/sbin/slick-greeter " label="unconfined")
13:06:55 slick-greeter-s: New keyboard configuration: rules:      evdev
model:      pc105
layout:     tr
13:06:55 slick-greeter-c: Window scale: 1
13:06:55 dbus-daemon: [session uid=111 pid=20659] Successfully activated service 'ca.desrt.dconf'
13:06:55 systemd: Started D-Bus User Message Bus.
13:06:55 (systemd): pam_unix(systemd-user:session): session opened for user lightdm by (uid=0)
13:06:55 systemd: Started Session c7 of user lightdm.
13:06:55 systemd-logind: New session c7 of user lightdm.
13:06:55 systemd: Starting User Manager for UID 111...
13:06:55 lightdm: pam_unix(lightdm-greeter:session): session opened for user lightdm by (uid=0)
13:06:52 acpid: 1 client rule loaded
13:06:51 systemd: Started NVIDIA Persistence Daemon.
13:06:51 nvidia-persiste: Local RPC service initialized
13:06:51 systemd: Starting NVIDIA Persistence Daemon...
13:06:51 lightdm: Error: can't open /lib/modules/4.15.0-46-generic/updates/dkms
13:06:51 systemd: Stopped NVIDIA Persistence Daemon.
13:06:51 nvidia-persiste: Shutdown (16150)
13:06:51 systemd: Stopping NVIDIA Persistence Daemon...
13:06:51 nvidia-persiste: Received signal 15
13:06:50 polkitd: Unregistered Authentication Agent for unix-session:c6 (system bus name :1.185, object path /org/gnome/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8) (disconnected from bus)
13:06:50 lightdm: pam_unix(lightdm:session): session closed for user aykutdemirci
  • İleti: 16851
Ynt: Linux Mint 19.1 Cinnamon Rastgele Oturum Kapanıyor
« Yanıtla #1 : 10 Mart 2019, 14:46:16 »
Bu tür konularda genel sorunlar için istenen komutun çıktısını da paylaşınız. Bu şekilde sisteminiz hakkında genel bilgi sahibi olabiliriz. Şu konumuzu inceleyiniz.
Çevrimdışı own
  • İleti: 38
« Yanıtla #2 : 10 Mart 2019, 14:56:28 »
Uyurı için teşekkür ederim. İstediğini cikti aşağıdaki gibidir.
aykutdemirci@OwL:~$ inxi -Fxxz
System:    Host: OwL Kernel: 4.15.0-46-generic x86_64 bits: 64 compiler: gcc v: 7.3.0 Desktop: Cinnamon 4.0.9
           wm: muffin dm: LightDM Distro: Linux Mint 19.1 Tessa base: Ubuntu 18.04 bionic
Machine:   Type: Laptop System: Micro-Star product: GF63 8RC v: REV:1.0 serial: <filter> Chassis: type: 10
           serial: <filter>
           Mobo: Micro-Star model: MS-16R1 v: REV:1.0 serial: <filter> UEFI: American Megatrends v: E16R1IMS.10A
           date: 10/24/2018
Battery:   ID-1: BAT1 charge: 47.3 Wh condition: 47.3/51.3 Wh (92%) volts: 12.9/11.4 model: MSI Corp. MS-16R1
           serial: N/A status: Full
CPU:       Topology: Quad Core model: Intel Core i5-8300H bits: 64 type: MT MCP arch: Kaby Lake rev: A
           L2 cache: 8192 KiB
           flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 36864
           Speed: 800 MHz min/max: 800/4000 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
           8: 800
Graphics:  Device-1: Intel vendor: Micro-Star MSI driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:3e9b
           Device-2: NVIDIA vendor: Micro-Star MSI driver: nvidia v: 415.27 bus ID: 01:00.0 chip ID: 10de:1c92
           Display: x11 server: X.Org 1.19.6 driver: modesetting,nvidia unloaded: fbdev,nouveau,vesa
           resolution: 1920x1080~60Hz, 1920x1080~60Hz
           OpenGL: renderer: GeForce GTX 1050/PCIe/SSE2 v: 4.6.0 NVIDIA 415.27 direct render: Yes
Audio:     Device-1: Intel Cannon Lake PCH cAVS vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
           bus ID: 00:1f.3 chip ID: 8086:a348
           Sound Server: ALSA v: k4.15.0-46-generic
Network:   Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi v: kernel port: 5000 bus ID: 00:14.3
           chip ID: 8086:a370
           IF: wlo1 state: down mac: <filter>
           Device-2: Qualcomm Atheros QCA8171 Gigabit Ethernet vendor: Micro-Star MSI driver: alx v: kernel
           port: 3000 bus ID: 02:00.0 chip ID: 1969:10a1
           IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
           IF-ID-1: vmnet1 state: unknown speed: N/A duplex: N/A mac: <filter>
           IF-ID-2: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
Drives:    Local Storage: total: 223.58 GiB used: 73.47 GiB (32.9%)
           ID-1: /dev/sda vendor: Western Digital model: WDS240G2G0A-00JH30 size: 223.58 GiB speed: 6.0 Gb/s
           serial: <filter>
Partition: ID-1: / size: 161.39 GiB used: 73.44 GiB (45.5%) fs: ext4 dev: /dev/sda3
Sensors:   System Temperatures: cpu: 58.0 C mobo: N/A gpu: nvidia temp: 53 C
           Fan Speeds (RPM): N/A
Info:      Processes: 293 Uptime: 5h 21m Memory: 23.39 GiB used: 1.93 GiB (8.2%) Init: systemd v: 237 runlevel: 5
           Compilers: gcc: 7.3.0 alt: 7 Shell: bash v: 4.4.19 running in: deepin-terminal inxi: 3.0.27
  • İleti: 16851
« Yanıtla #3 : 10 Mart 2019, 15:35:21 »
Nvidia ayar yöneticisinden Intel GPU'yu seçip oturumu kapatıp açınız. Sorunun Intel GPU ile olup olmadığını gözlemleyiniz.
Çevrimdışı own
  • İleti: 38
« Yanıtla #4 : 10 Mart 2019, 16:01:14 »
İnteli seçtim ama sorun devam ediyor. HDMI dan 2. monitor bağlı. Wireshark paket yakalama programı kullanıyorum. Ana ekranda çalışırsam sorun yok fakat 2. monitöre atınca logoff oluyor. Şimdi farketim bu durumuda. Şunuda belirtiyim Wireshark la ilgisi yok daha önceki logoff oluşlarında bu programı kullanmıyordum.
  • İleti: 16851
« Yanıtla #5 : 10 Mart 2019, 16:10:37 »
Komutların çıktılarına bakalım.
journalctl -au lightdm.service
cat /var/log/Xorg.0.log
Çevrimdışı own
  • İleti: 38
  • İleti: 16851
« Yanıtla #7 : 10 Mart 2019, 17:09:41 »
Kullanıcıyı parolasız oturum açma grubundan çıkarmayı deneyelim, belki sorun bununla ilgilidir.
sudo delgroup $USER nopasswdlogin
Çevrimdışı own
  • İleti: 38
« Yanıtla #8 : 11 Mart 2019, 10:10:49 »
Kullanıcım parolasız acma grubunde değil saten ama verdiğiniz komutu girdim çıktısı aşağidaki gibi. Sorunda devam ediyor.
/usr/sbin/delgroup: The user `aykutdemirci' is not a member of group `nopasswdlogin'.
  • İleti: 16851
« Yanıtla #9 : 11 Mart 2019, 13:47:38 »
LightDM çıktıları sebebiyle böyle düşünmüştüm.
Sürücü yöneticisi yardımıyla Nvidia sürücüsünü nvidia-390 sürüme düşürmeyi dener misiniz? Nvidia-415 sürücüsü kullandığınız anlaşılıyor, sorunun bununla ilgili olabilir, bu sürücüyü PPA deposundan kumuş olmalısınız. Nvidia-390 sürücüsü uzun destekli sürüm, bu sürüme çekirdek 5.0 desteği bile eklenmiş durumda.
« Son Düzenleme: 11 Mart 2019, 13:49:25 Gönderen: Butterfly »
Çevrimdışı own
  • İleti: 38
« Yanıtla #10 : 12 Mart 2019, 20:58:18 »
İlgin ve zaman ayırdığın için çok teşekkür ediyorum. Denediğim zaman sonucu söylerim.
  • İleti: 16851
« Yanıtla #11 : 12 Mart 2019, 21:41:38 »
Sorun çözülmezse Xorg ve çekirdek sürümünü yükseltmeyi deneriz.
