Gönderen Konu: Ekli pdf dosyalar geç açılıyor  (Okunma sayısı 163 defa)
Çevrimdışı harkail_rad
  • İleti: 114
  • Dağıtım: linux mint
« : 07 Mart 2019, 13:06:02 »
Merhabalar,
Mailin ekinde olan bir pdf dökümanı çok geç açılıyor ama masaüstünde ki klasör yada dosyada sorun olmuyor.
Sebebi ne olabilir acaba?
mozilla thunderbir belge görüntüleyicisi resmi ektedir.
inxi -Fxz
System:
  Host: WS-LIN-33 Kernel: 4.18.0-15-generic x86_64 bits: 64 compiler: gcc
  v: 7.3.0 Desktop: Cinnamon 4.0.9 Distro: Linux Mint 19.1 Tessa
  base: Ubuntu 18.04 bionic
Machine:
  Type: Desktop Mobo: Gigabyte model: GA-78LMT-S2PT v: x.x serial: N/A
  BIOS: Award v: FC date: 11/05/2012
CPU:
  Topology: Quad Core model: AMD FX-4100 bits: 64 type: MCP arch: Bulldozer
  rev: 2 L2 cache: 2048 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
  bogomips: 28930
  Speed: 3422 MHz min/max: 1400/3600 MHz Core speeds (MHz): 1: 3662 2: 3843
  3: 1526 4: 1510
Graphics:
  Device-1: AMD RS780L [Radeon 3000] vendor: Gigabyte driver: radeon
  v: kernel bus ID: 01:05.0
  Display: server: X.Org 1.19.6 driver: radeon resolution: 1440x900~60Hz
  OpenGL: renderer: AMD RS780 (DRM 2.50.0 / 4.18.0-15-generic LLVM 7.0.0)
  v: 3.3 Mesa 18.2.2 direct render: Yes
Audio:
  Device-1: AMD SBx00 Azalia vendor: Gigabyte driver: snd_hda_intel
  v: kernel bus ID: 00:14.2
  Sound Server: ALSA v: k4.18.0-15-generic
Network:
  Device-1: Qualcomm Atheros AR8161 Gigabit Ethernet vendor: Gigabyte
  driver: alx v: kernel port: df00 bus ID: 02:00.0
  IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives:
  Local Storage: total: 409.88 GiB used: 72.65 GiB (17.7%)
  ID-1: /dev/sda model: SATA SSD size: 111.79 GiB temp: 33 C
  ID-2: /dev/sdb vendor: Seagate model: ST3320413CS size: 298.09 GiB
  temp: 30 C
Partition:
  ID-1: / size: 109.53 GiB used: 72.65 GiB (66.3%) fs: ext4 dev: /dev/sda1
Sensors:
  System Temperatures: cpu: 11.6 C mobo: N/A
  Fan Speeds (RPM): N/A
Info:
  Processes: 204 Uptime: 6h 05m Memory: 7.30 GiB used: 2.46 GiB (33.7%)
  Init: systemd runlevel: 5 Compilers: gcc: 7.3.0 Shell: bash v: 4.4.19
  inxi: 3.0.27
« Son Düzenleme: 07 Mart 2019, 13:15:17 Gönderen: harkail_rad »
Ynt: Ekli pdf dosyalar geç açılıyor
« Yanıtla #1 : 07 Mart 2019, 13:47:26 »
PDF belge okuyucu Atril olarak görünüyor, bu MATE masaüstünün bir aracı. Linux Mint'te Xreader kullanılıyor. PDF dosyasını bununla açmayı dener misiniz? Xreader da Belge Görüntüleyici olarak görünüyordur.
Bir de e-posta yapılandırması IMAP ise, ekli dosyanın indirilmesi için geçen süreyi hesaba katmalısınız.
« Son Düzenleme: 07 Mart 2019, 13:51:08 Gönderen: Butterfly »
  • İleti: 114
« Yanıtla #2 : 07 Mart 2019, 14:04:51 »
Hocam xreader belge görüntüleyici olarak açtığımda da 15 sn geç açıyor. indirme süresi ile ilgilli değil çünkü diğer arkadaşlara da aynı e-posta geliyor ve onlar 1 sn gibi bir sürede açıyor.
« Yanıtla #3 : 07 Mart 2019, 15:09:58 »
Diğer kişilerin bilgisayarında da Linux Mint mi var ya da Linux Mint'in aynı sürümünü mü kullanıyorsunuz?
  • İleti: 114
« Yanıtla #4 : 07 Mart 2019, 15:40:25 »
evet hocam hepsi aynı sürüm.
« Yanıtla #5 : 07 Mart 2019, 15:59:13 »
Thunderbird => Düzenle menüsü => Tercihler => Gelişmiş sekmesi => Yapılandırma düzenleyiciyi açınız. Aşağıdaki değişkeni aratıp, değişkeni false olarak değiştiriniz. Ardından Thunderbird uygulamasını kapatıp yeniden başlatmayı deneyiniz.
mail.server.default.fetch_by_chunks
  • İleti: 114
« Yanıtla #6 : 07 Mart 2019, 16:33:56 »
Hocam denedim, yine 15 sn kadar geç açtı.
« Yanıtla #7 : 07 Mart 2019, 17:16:31 »
Aşağıdaki komutla menü düzenleyiciyi açıp,
cinnamon-menu-editor
Donatılar => Belge Görüntüleyiciye çift tıklayın. Komut kısmındaki aşağıdaki satırı,
xreader %U
aşağıdaki şekilde değiştirip kaydetmeyi deneyin.
xreader %F
  • İleti: 114
« Yanıtla #8 : 12 Mart 2019, 08:52:05 »
Hocam merhaba,
Bu işlemden sonra bilgisayarı yeniden başlatmadan denedim.
Sonuç aynı, pdf dökümanları geç açıyor.
« Yanıtla #9 : 12 Mart 2019, 13:37:08 »
Foxit Reader uygulamasını deneyebilirsiniz. Xreader ve Atril, Evince tabanlı olduğu için aynı hataı veriyor olabilir. Bakalım alternatif uygulama ile sonuç ne olacak. Bunun yerine Okular uygulamasını kurabilirsiniz, Okular depoda mevcut.
