Gönderen Konu: Çoklu yazdırma seçeneği  (Okunma sayısı 149 defa)
Çevrimdışı harkail_rad
  • İleti: 114
  • Dağıtım: linux mint
« : 27 Şubat 2019, 09:42:45 »
Merhabalar,
Linuxte bir klasör içerisinde bulunan 10 adet .pdf yada .ods uzantılı dosyayı seçip sağ tıkla --> yazdır demek istiyorum.. Çoklu dosyaları nasıl yazdırabilirim acaba?
inxi -Fxz
System:
  Host: WS-LIN-33 Kernel: 4.18.0-15-generic x86_64 bits: 64 compiler: gcc
  v: 7.3.0 Desktop: Cinnamon 4.0.9 Distro: Linux Mint 19.1 Tessa
  base: Ubuntu 18.04 bionic
Machine:
  Type: Desktop Mobo: Gigabyte model: GA-78LMT-S2PT v: x.x serial: <filter>
  BIOS: Award v: FC date: 11/05/2012
CPU:
  Topology: Quad Core model: AMD FX-4100 bits: 64 type: MCP arch: Bulldozer
  rev: 2 L2 cache: 2048 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
  bogomips: 28928
  Speed: 1784 MHz min/max: 1400/3600 MHz Core speeds (MHz): 1: 2425 2: 2798
  3: 1448 4: 1440
Graphics:
  Device-1: AMD RS780L [Radeon 3000] vendor: Gigabyte driver: radeon
  v: kernel bus ID: 01:05.0
  Display: x11 server: X.Org 1.19.6 driver: radeon resolution: 1440x900~60Hz
  OpenGL: renderer: AMD RS780 (DRM 2.50.0 / 4.18.0-15-generic LLVM 7.0.0)
  v: 3.3 Mesa 18.2.2 direct render: Yes
Audio:
  Device-1: AMD SBx00 Azalia vendor: Gigabyte driver: snd_hda_intel
  v: kernel bus ID: 00:14.2
  Sound Server: ALSA v: k4.18.0-15-generic
Network:
  Device-1: Qualcomm Atheros AR8161 Gigabit Ethernet vendor: Gigabyte
  driver: alx v: kernel port: df00 bus ID: 02:00.0
  IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives:
  Local Storage: total: 409.88 GiB used: 68.88 GiB (16.8%)
  ID-1: /dev/sda model: SATA SSD size: 111.79 GiB
  ID-2: /dev/sdb vendor: Seagate model: ST3320413CS size: 298.09 GiB
Partition:
  ID-1: / size: 109.53 GiB used: 68.88 GiB (62.9%) fs: ext4 dev: /dev/sda1
Sensors:
  System Temperatures: cpu: 5.0 C mobo: N/A
  Fan Speeds (RPM): N/A
Info:
  Processes: 201 Uptime: 2h 39m Memory: 7.30 GiB used: 1.31 GiB (18.0%)
  Init: systemd runlevel: 5 Compilers: gcc: 7.3.0 Shell: bash v: 4.4.19
  inxi: 3.0.27
