Gönderen Konu: HP Pavilion G6 Fan Sorunu  (Okunma sayısı 112 defa)
Çevrimdışı hllk0335
  • İleti: 15
  • Grafik Kartı: AMD Radeon HD 7670M + Intel hd 4000
  • İşlemci: Intel Core i5 3230M
« : 21 Şubat 2019, 19:07:30 »
Selamlar herkese,
Lİnux mint 19.1 sıfır kurulum yaptım. Ama gerek yüklemiş olduğum programların açılış hızından gerekse fanın 5'er dakika arayla sürekli çalışmasından biraz muzdaribim. Konuya vakıf olan arkadaşlar yardımcı olursa sevinirim. Şimdiden teşekkür ederim.
HP-Pavilion-g6-Notebook-PC:~$ lspci | egrep 'VGA|3D|Display'
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Thames [Radeon HD 7500M/7600M Series] (rev ff)
HP-Pavilion-g6-Notebook-PC:~$ glxinfo | grep render
    GLX_INTEL_swap_event, GLX_MESA_copy_sub_buffer, GLX_MESA_query_renderer,
    GL_NV_conditional_render, GL_NV_depth_clamp,
HP-Pavilion-g6-Notebook-PC:~$ inxi -F
Host: HP-Pavilion-g6-Notebook-PC
  Kernel: 4.15.0-45-generic x86_64 bits: 64 Desktop: Cinnamon 4.0.9
  Distro: Linux Mint 19.1 Tessa
Machine:
  Type: Laptop System: Hewlett-Packard product: HP Pavilion g6 Notebook PC
  v: 0890120000005910000600000 serial: <root required>
  Mobo: Hewlett-Packard model: 183E v: 56.32 serial: <root required>
  UEFI [Legacy]: Insyde v: F.27 date: 09/07/2016
Battery:
  ID-1: BAT0 charge: 21.1 Wh condition: 21.1/21.1 Wh (100%)
CPU:
  Topology: Dual Core model: Intel Core i5-3230M bits: 64 type: MT MCP
  L2 cache: 3072 KiB
  Speed: 1197 MHz min/max: 1200/3200 MHz Core speeds (MHz): 1: 1197 2: 1197
  3: 1197 4: 1197
Graphics:
  Device-1: Intel 3rd Gen Core processor Graphics driver: i915 v: kernel
  Device-2: AMD Thames [Radeon HD 7500M/7600M Series] driver: radeon
  v: kernel
  Display: x11 server: X.Org 1.19.6 driver: ati,modesetting,radeon
  unloaded: fbdev,vesa resolution: 1366x768~60Hz
  OpenGL: renderer: Mesa DRI Intel Ivybridge Mobile
  v: 4.2 Mesa 18.3.3 - padoka PPA
Audio:
  Device-1: Intel 7 Series/C216 Family High Definition Audio
  driver: snd_hda_intel
  Sound Server: ALSA v: k4.15.0-45-generic
Network:
  Device-1: Ralink RT3290 Wireless 802.11n 1T/1R PCIe driver: rt2800pci
  IF: wlo1 state: up mac: b8:76:3f:60:8a:33
  Device-2: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169
  IF: eno1 state: down mac: 74:46:a0:80:c5:ec
Drives:
  Local Storage: total: 465.76 GiB used: 51.10 GiB (11.0%)
  ID-1: /dev/sda vendor: Seagate model: ST500LT012-9WS142 size: 465.76 GiB
Partition:
  ID-1: / size: 182.34 GiB used: 15.88 GiB (8.7%) fs: ext4 dev: /dev/sda6
  ID-2: /home size: 266.77 GiB used: 35.22 GiB (13.2%) fs: ext4
  dev: /dev/sda5
  ID-3: swap-1 size: 7.45 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda1
Sensors:
  System Temperatures: cpu: 57.0 C mobo: N/A
  Fan Speeds (RPM): N/A
Info:
  Processes: 213 Uptime: 9h 23m Memory: 7.69 GiB used: 1.90 GiB (24.8%)
  Shell: bash inxi: 3.0.27
Ynt: HP Pavilion G6 Fan Sorunu
« Yanıtla #1 : 21 Şubat 2019, 20:25:25 »
@hllk0335 , forumda aynı başlık latında farklı sorunları konuşmuyoruz. Bu konuya fan soruu ile ilgili husus için devam edelim. Sunulan önerilerle uygulamalar ile ilgili sorun çözülmezse yeni bir konu açarsınız.
Öncelikle aşağıdki komutla Intel GPU için klasik sürücüyü etkinleştirmeyi deneyebilirsiniz.
sudo mkdir -p /etc/X11/xorg.conf.d/ && echo -e 'Section "Device"\n Identifier "Intel Graphics"\n Driver "Intel"\n Option "AccelMethod" "uxa"\nEndSection' | sudo tee /etc/X11/xorg.conf.d/20-intel.conf
Ayrıca forumda mevcut bulunan, güç yönetimi uygulaması TLP'yi kurmak da denenebilir.
