Gönderen Konu: [Çözüldü] LM 18.1 Kablosuz Bağlantı Açma/Kapama Butonu Sorunu  (Okunma sayısı 177 defa)
Çevrimdışı abdulkadir0666
  • İleti: 21
  • Dağıtım: Linux Mint 18.3
  • Masaüstü: cinnamon
  • RAM: 3
İyi günler dilerim. Panel üzerindeki ve ağ ayarları kısmındaki kablosuz bağlantıyı açma butonu sürekli hata veriyor ve kablosuz bağlantıyı açmıyor.
Sistem bilgilerim bunlardır;
inxi -Fxxz
System:    Host: kadir-bekopc Kernel: 4.4.0-53-generic i686 (32 bit gcc: 5.4.0)
           Desktop: Cinnamon 3.2.7 (Gtk 3.18.9-1ubuntu3.3) dm: mdm
Machine:   System: - product: bekopc v: G17 Chassis: No Enclosure type: 10
           Mobo: - model: IFL91 v: IFT00 Bios: COMPAL v: 1.12 date: 08/29/2007
CPU:       Dual core Intel Core2 Duo T5250 (-MCP-) cache: 2048 KB
           flags: (lm nx pae sse sse2 sse3 ssse3) bmips: 5984
           clock speeds: min/max: 1000/1500 MHz 1: 1000 MHz 2: 1500 MHz
Graphics:  Card: Intel Mobile GM965/GL960 Integrated Graphics Controller (primary)
           bus-ID: 00:02.0 chip-ID: 8086:2a02
           Resolution: 1280x800@59.97hz
           GLX Renderer: Mesa DRI Intel 965GM x86/MMX/SSE2
           GLX Version: 2.1 Mesa 11.2.0 Direct Rendering: Yes
Audio:     Card Intel 82801H (ICH8 Family) HD Audio Controller
           driver: snd_hda_intel bus-ID: 00:1b.0 chip-ID: 8086:284b
           Sound: Advanced Linux Sound Architecture v: k4.4.0-53-generic
Network:   Card-1: Broadcom NetLink BCM5906M Fast Ethernet PCI Express
           driver: tg3 v: 3.137 bus-ID: 04:00.0 chip-ID: 14e4:1713
           Card-2: Intel PRO/Wireless 4965 AG or AGN [Kedron] Network Connection
           driver: iwl4965 v: in-tree: bus-ID: 0c:00.0 chip-ID: 8086:4229
           IF: wlp12s0 state: down mac: <filter>
Drives:    HDD Total Size: 120.0GB (11.8% used)
           ID-1: /dev/sda model: TOSHIBA_MK1246GS size: 120.0GB serial: Y7RPT1RJT
Partition: ID-1: / size: 109G used: 13G (12%) fs: ext4 dev: /dev/sda1
           ID-2: swap-1 size: 1.06GB used: 0.18GB (17%) fs: swap dev: /dev/sda5
           Unused Devices: none
Sensors:   System Temperatures: cpu: 35.0C mobo: N/A
Info:      Processes: 176 Uptime: 1:09 Memory: 624.0/990.9MB
           Client: Shell (bash 4.3.481 running in gnome-terminal-) inxi: 2.2.35
Diğer aldığım çıktılar ise bunlar;
inxi -SMNnxxz
lspci -nnk | grep -iA2 net
04:00.0 Ethernet controller [0200]: Broadcom Corporation NetLink BCM5906M Fast Ethernet PCI Express [14e4:1713] (rev 02)
Subsystem: COMPAL Electronics Inc NetLink BCM5906M Fast Ethernet PCI Express [14c0:0026]
Kernel driver in use: tg3
Kernel modules: tg3
0c:00.0 Network controller [0280]: Intel Corporation PRO/Wireless 4965 AG or AGN [Kedron] Network Connection [8086:4229] (rev 61)
Subsystem: Intel Corporation PRO/Wireless 4965 AG or AGN [Kedron] Network Connection [8086:1001]
Kernel driver in use: iwl4965
Kernel modules: iwl4965
lsusb
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 002: ID 04f2:b018 Chicony Electronics Co., Ltd 2M UVC Webcam
Bus 001 Device 005: ID 2717:ff80
rfkill list
0: compal-wifi: Wireless LAN
Soft blocked: no
Hard blocked: no
1: compal-bluetooth: Bluetooth
Soft blocked: yes
Hard blocked: no
2: phy0: Wireless LAN
Soft blocked: no
Hard blocked: yes
sudo lshw -C network
[sudo] password for kadir:
  *-network
       açıklama: Eternet interface
       ürün: NetLink BCM5906M Fast Ethernet PCI Express
       üretici: Broadcom Corporation
       physical id: 0
       bus info: pci@0000:04:00.0
       mantıksal ad: enp4s0
       sürüm: 02
       serial: 00:1b:38:73:aa:c7
       kapasite: 100Mbit/s
       genişlik: 64 bits
       saat: 33MHz
       kapasiteler: pm vpd msi pciexpress bus_master cap_list eternet physical tp 10bt 10bt-fd 100bt 100bt-fd autonegotiation
       yapılandırma: autonegotiation=on broadcast=yes driver=tg3 driverversion=3.137 firmware=sb v3.04 latency=0 link=no multicast=yes port=twisted pair
       kaynaklar: irq:33 bellek:f0000000-f000ffff
  *-network ETKİSİZLEŞTİRİLDİ
       açıklama: Kablosuz arayüz
       ürün: PRO/Wireless 4965 AG or AGN [Kedron] Network Connection
       üretici: Intel Corporation
       physical id: 0
       bus info: pci@0000:0c:00.0
       mantıksal ad: wlp12s0
       sürüm: 61
       serial: 00:1d:e0:bd:ad:1b
       genişlik: 64 bits
       saat: 33MHz
       yapılandırma: broadcast=yes driver=iwl4965 driverversion=4.4.0-53-generic firmware=228.61.2.24 latency=0 link=no multicast=yes wireless=IEEE 802.11abgn
       kaynaklar: irq:31 bellek:f8200000-f8201fff
  *-network
       physical id: 1
       mantıksal ad: enp0s26f7u1
       serial: 62:fb:2b:3e:e5:d4
       kapasiteler: eternet physical
       yapılandırma: broadcast=yes driver=rndis_host driverversion=22-Aug-2005 firmware=RNDIS device ip=192.168.42.252 link=yes multicast=yes
iwconfig | grep Power
enp4s0    no wireless extensions.
enp0s26f7u1  no wireless extensions.
          Mode:Managed  Access Point: Not-Associated   Tx-Power=off
          Power Management:on
lsmod
rndis_host             16384  0
cdc_ether              16384  1 rndis_host
usbnet                 45056  2 rndis_host,cdc_ether
mii                    16384  1 usbnet
nls_iso8859_1          16384  0
drbg                   28672  1
ansi_cprng             16384  0
ctr                    16384  0
ccm                    20480  0
uvcvideo               77824  0
videobuf2_v4l2         28672  1 uvcvideo
videobuf2_core         36864  2 uvcvideo,videobuf2_v4l2
snd_hda_codec_si3054    16384  1
uas                    20480  0
v4l2_common            16384  1 videobuf2_v4l2
videodev              155648  4 uvcvideo,v4l2_common,videobuf2_core,videobuf2_v4l2
snd_hda_codec_realtek    73728  1
usb_storage            57344  1 uas
media                  24576  2 uvcvideo,videodev
snd_hda_codec_generic    69632  1 snd_hda_codec_realtek
snd_hda_intel          36864  6
compal_laptop          20480  0
snd_hda_codec         118784  4 snd_hda_codec_realtek,snd_hda_codec_si3054,snd_hda_codec_generic,snd_hda_intel
snd_hda_core           61440  5 snd_hda_codec_realtek,snd_hda_codec_si3054,snd_hda_codec_generic,snd_hda_codec,snd_hda_intel
iwl4965               114688  0
iwlegacy               90112  1 iwl4965
i2c_i801               28672  0
mac80211              659456  2 iwl4965,iwlegacy
snd_pcm                94208  6 snd_hda_codec_si3054,snd_hda_codec,snd_hda_intel,snd_hda_core
r592                   20480  0
cfg80211              499712  3 iwl4965,iwlegacy,mac80211
snd_rawmidi            28672  1 snd_seq_midi
memstick               16384  1 r592
snd_seq                57344  2 snd_seq_midi_event,snd_seq_midi
lpc_ich                20480  0
snd                    69632  21 snd_hda_codec_realtek,snd_hda_codec_si3054,snd_hwdep,snd_timer,snd_pcm,snd_seq,snd_rawmidi,snd_hda_codec_generic,snd_hda_codec,snd_hda_intel,snd_seq_device
shpchp                 32768  0
ene_ir                 20480  0
rc_core                28672  1 ene_ir
parport                45056  3 lp,ppdev,parport_pc
btrfs                1003520  0
xor                    28672  1 btrfs
raid6_pq              102400  1 btrfs
i915                 1130496  4
tg3                   159744  0
psmouse               118784  0
firewire_ohci          36864  0
sdhci_pci              24576  0
firewire_core          65536  1 firewire_ohci
pata_acpi              16384  0
drm_kms_helper        139264  1 i915
ptp                    20480  1 tg3
sdhci                  45056  1 sdhci_pci
crc_itu_t              16384  1 firewire_core
drm                   311296  6 i915,drm_kms_helper
pps_core               20480  1 ptp
wmi                    20480  0
video                  36864  2 i915,compal_laptop
Yardımcı olursanız sevirim.
« Son Düzenleme: 13 Ocak 2019, 01:33:45 Gönderen: abdulkadir0666 »
Ynt: LM 18.1 Kablosuz Bağlantı Açma/Kapama Butonu Sorunu
« Yanıtla #1 : 12 Ocak 2019, 18:08:03 »
   Soft blocked: no
   Hard blocked: yes
Ağ aygıtı donanımsal kilitli görünüyor. Sisteme ağ aygıtını açıp kapatmak için bir düğme olabilir, bunun yardımıyla donanımsal kilidi açmayı deneyiniz.
Altenatif olarak, çekirdekle ya da ağ yöneticisi ile ilgili bir sorun olabilir. Öncelikle 4. seviye güncellemeleri etkinleştirip, tüm güncellemeleri seçerek sistemi güncellemeyi deneyiniz. Ardından sistemi yeniden başlatınız.
Sorun çözülmezse, aşağıdaki bağlantıda anlatıldığı biçimde çekirdeğin 4.15.x serisine geçemeyi deneyebilirsiniz.
« Son Düzenleme: 12 Ocak 2019, 18:12:17 Gönderen: Butterfly »
  • İleti: 21
  • RAM: 3
« Yanıtla #2 : 13 Ocak 2019, 01:33:27 »
Sorun yeniden başlatma sonrası kendiliğinden düzeldi. Çok teşekkür ederim.
