Gönderen Konu: Acer Aspire 5735 de batarya takılıyken ekran kararma sorunu  (Okunma sayısı 374 defa)
Çevrimdışı ninova
  • İleti: 19
Merhaba, bilgisayarın açılışında herşey normal ve mint logosu görünüyorken, 10-15 sn sonra ekran kararıyor fakat telefonun ışığını tuttuğumda ekranda hareketliliğin devam ettiğini görüyorum.Bu sorun güç kablosu takılıyken yaşanmıyor. Çözüm bulmaya çalışıyorum.
inxi -Sxx
System:    Host: emre-Aspire-5735 Kernel: 4.4.0-21-generic x86_64 (64 bit gcc: 5.3.1)
           Desktop: Xfce 4.12.3 (Gtk 2.24.28) dm: mdm
           Distro: Linux Mint 18 Sarah
emre[member=690]Emre[/member]-Aspire-5735 ~ $ inxi -Fx
           Desktop: Xfce 4.12.3 (Gtk 2.24.28) Distro: Linux Mint 18 Sarah
Machine:   System: Acer (portable) product: Aspire 5735 v: 0100
           Mobo: Acer model: CathedralPeak v: Rev Bios: Phoenix v: V1.10 date: 12/04/2008
CPU:       Dual core Intel Core2 Duo T6400 (-MCP-) cache: 2048 KB
           flags: (lm nx sse sse2 sse3 sse4_1 ssse3) bmips: 7980
           clock speeds: max: 2000 MHz 1: 1600 MHz 2: 1600 MHz
Graphics:  Card: Intel Mobile 4 Series Integrated Graphics Controller bus-ID: 00:02.0
           Display Server: X.Org 1.18.3 drivers: intel (unloaded: fbdev,vesa) Resolution: 1366x768@60.11hz
           GLX Renderer: Mesa DRI Mobile Intel GM45 Express GLX Version: 2.1 Mesa 11.2.0 Direct Rendering: Yes
Audio:     Card Intel 82801I (ICH9 Family) HD Audio Controller driver: snd_hda_intel bus-ID: 00:1b.0
           Sound: Advanced Linux Sound Architecture v: k4.4.0-21-generic
Network:   Card-1: Marvell 88E8071 PCI-E Gigabit Ethernet Controller
           driver: sky2 v: 1.30 port: 2000 bus-ID: 02:00.0
           IF: enp2s0 state: down mac: 00:1d:72:ec:d1:9a
           Card-2: Intel WiFi Link 5100 driver: iwlwifi bus-ID: 03:00.0
           IF: wlp3s0 state: down mac: 00:21:6b:09:45:36
Drives:    HDD Total Size: 175.6GB (5.1% used) ID-1: /dev/sda model: WDC_WD1600BEVT size: 160.0GB
           ID-2: USB /dev/sdb model: TransMemory size: 15.5GB
Partition: ID-1: / size: 145G used: 6.5G (5%) fs: ext4 dev: /dev/sda1
           ID-2: swap-1 size: 2.07GB used: 0.00GB (0%) fs: swap dev: /dev/sda5
Sensors:   System Temperatures: cpu: 42.0C mobo: 42.0C
Info:      Processes: 206 Uptime: 5 min Memory: 306.9/1929.7MB Init: systemd runlevel: 5 Gcc sys: 5.4.0
           Client: Shell (bash 4.3.481) inxi: 2.2.35
Konuya ilişkin bir yardım yanıtı bekliyorum.
Düzenleme: Kod etiketi
« Son Düzenleme: 28 Aralık 2018, 14:29:49 Gönderen: Butterfly »
  • İleti: 16272
Ynt: Acer Aspire 5735 de batarya takılıyken ekran kararma sorunu
« Yanıtla #1 : 28 Aralık 2018, 14:40:46 »
@ninova , lütfen konuya peşpeşe mesaj göndermeyiniz, gönderdiğiniz sonraki mesajlar mevcut mesajlarla birleştirildiği için konu daha üstte çıkmadığı gibi, daha hızlı yardım almanızı da sağlamıyor.
Bu sorun sonradan mı ortaya çıktı?
TLP ya da Laptop-mod-tools gibi bir güç yönetimi uygulaması yüklediniz mi?
Güç yönetimi ayarlarından pil gücündeki parlaklık ayarını kontrol ettiniz mi?
Çevrimdışı ninova
  • İleti: 19
« Yanıtla #2 : 28 Aralık 2018, 14:44:14 »
Bilgisayarıma yeni kurdum linuxminti sadece bataryadayken yapıyor bu sorunu fişle çalıştığında sıkıntı yok. herhangi bir yükleme yapmadım.
Dediğiniz yerden pil gücüyle ilgili ayarları kontrol ettim fakat orda bir sorun gözükmuyor. Birkaç denemede yaptım o panelde.
« Son Düzenleme: 28 Aralık 2018, 14:46:15 Gönderen: ninova »
  • İleti: 16272
« Yanıtla #3 : 28 Aralık 2018, 15:03:37 »
Sistem çekmeseindeki güç yönetimi uygulamacığına bakmış olabilirsiniz. Bunun yerine güç yönetimi aracını açıp düzenleme yapmayı deneyiniz. Aşağıdaki gibi pil gücündeyken parlaklığın ne kadar olacağı ile ilgili bir ayar olmalı. Bu araçtan ekranın güç yönetimi tarafından kontrol edilmesini de engelleyebilirsiniz.
« Son Düzenleme: 28 Aralık 2018, 15:04:43 Gönderen: Butterfly »
Çevrimdışı ninova
  • İleti: 19
« Yanıtla #4 : 28 Aralık 2018, 15:07:07 »
evet bu menüden ayarlamaları yaptım, burda bir sorun gözükmüyor.
  • İleti: 16272
« Yanıtla #5 : 28 Aralık 2018, 15:13:13 »
Ekran görüntüsünü paylaşır mısınız?
Çevrimdışı ninova
  • İleti: 19
« Yanıtla #6 : 28 Aralık 2018, 15:19:31 »
  • İleti: 16272
« Yanıtla #7 : 28 Aralık 2018, 15:41:06 »
Paylaştığınız resme göre parlaklığın 120 sn. kullanım olmadığında azaltılması gerekir. Burada anlatıldığı biçimde 18.3 sürüme yükseltme yapar mısınız? Bu sürümde güç yönetimi uygulaması ile ilgili güncellemelerin olması gerekiyor. Sorunun kaynağı güç yönetimi aracında olabilir. Ardından sistemi yeniden başalatınız.
Sorun çözülmezse sırasıyla aşağıdaki adımları da uygulayabilirsiniz.
1. Burada anlatıldığı biçimde çekirdek sürümünü de yükseltiniz. Ardından sisteminizi yeniden başlatınız.
2. Aşağıdaki komutla X sunucusunu güncelleyebilirsiniz.
sudo apt-get install --install-recommends xserver-xorg-hwe-16.04
Çevrimdışı ninova
  • İleti: 19
« Yanıtla #8 : 28 Aralık 2018, 16:35:07 »
Yönlendirmelrinizi eksiksiz yerine getirdim fakat yine açılışta görüntüyü kararttı.
  • İleti: 16272
« Yanıtla #9 : 28 Aralık 2018, 17:46:09 »
ls /sys/class/backlight/
cat /var/log/Xorg.0.log | grep -i backlight
Çevrimdışı ninova
  • İleti: 19
« Yanıtla #10 : 28 Aralık 2018, 19:28:58 »
  • İleti: 16272
« Yanıtla #11 : 28 Aralık 2018, 19:36:56 »
Lütfen çıktıları resim olarak paylaşmayınız, çıktıları kopyalayıp kod etiketi içinde foruma aktarınız.
Açılışa eklediğiniz değişkenleri kaldırmayı deneyiniz. Yaptığınız düzenlemelerden bahsetmemişsiniz.
Eklediğiniz değişkenleri kaldırıp, çıktıları yeniden paylaşınız.
« Son Düzenleme: 28 Aralık 2018, 19:51:07 Gönderen: Butterfly »
Çevrimdışı ninova
  • İleti: 19
« Yanıtla #12 : 28 Aralık 2018, 20:15:22 »
acer-wmi
[    31.614] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-43-generic root=UUID=4183594e-b38f-46c4-9351-9fa9e009b618 ro acpi_backlight=vendor quiet splash acpi_osi=Linux vt.handoff=7
acer-wmi
[Paylaştığınız resme göre parlaklığın 120 sn. kullanım olmadığında azaltılması gerekir. Burada anlatıldığı biçimde 18.3 sürüme yükseltme yapar mısınız? Bu sürümde güç yönetimi uygulaması ile ilgili güncellemelerin olması gerekiyor. Sorunun kaynağı güç yönetimi aracında olabilir. Ardından sistemi yeniden başalatınız.
sudo apt-get install --install-recommends xserver-xorg-hwe-16.04/quote]
Sırasıyla söylediklerinizi yaptım.Açılışa eklediğim bir değişken yok.
« Son Düzenleme: 28 Aralık 2018, 20:48:27 Gönderen: ninova »
  • İleti: 16272
« Yanıtla #13 : 28 Aralık 2018, 21:51:23 »
Açılış acpi_backlight=vendor ve acpi_osi=Linux değişkenlerini eklemek için bir düzenleme yapmışsınız, bunu geri alıp çıktıyı paylaşmanız gerekiyor.
Bu düzenleme /etc/default/grub dosyasındadır. Bu dosyadan ilgili değişkenleri siliniz ve aşağıdaki komutu çalıştırıp sistemi yeniden başlatınız.
Sonra istenen komutların ıktılarını yeniden paylaşırsınız.
Çevrimdışı ninova
  • İleti: 19
« Yanıtla #14 : 28 Aralık 2018, 21:56:36 »
Nasıl geri alabilirim onu bilmiyorum.Rica etsem yardımcı olurmusunuz.
Dediğiniz işlemi yaptım.
[sudo] password for emre:
Grub yapılandırma dosyası oluşturuluyor ...
Uyarı: Setting GRUB_TIMEOUT to a non-zero value when GRUB_HIDDEN_TIMEOUT is set is no longer supported.
Bulunan linux imajı: /boot/vmlinuz-4.15.0-43-generic
Bulunan initrd imajı: /boot/initrd.img-4.15.0-43-generic
Bulunan linux imajı: /boot/vmlinuz-4.4.0-21-generic
Bulunan initrd imajı: /boot/initrd.img-4.4.0-21-generic
Found memtest86+ image: /boot/memtest86+.elf
Found memtest86+ image: /boot/memtest86+.bin
bitti
emre[member=690]Emre[/member]-Aspire-5735 ~ $ ls /sys/class/backlight/
acpi_video0
emre[member=690]Emre[/member]-Aspire-5735 ~ $ cat /var/log/Xorg.0.log | grep -i backlight
« Son Düzenleme: 28 Aralık 2018, 22:40:21 Gönderen: ninova »
