Gönderen Konu: Ekranda ki tepkilerin geç oluşması  (Okunma sayısı 147 defa)
Çevrimdışı harkail_rad
  • İleti: 96
  • Dağıtım: linux mint
« : 10 Aralık 2018, 16:59:49 »
Merhabalar,
Elimdeki tablet ve bilgisayar karışımı cihaza linux mint 19 yükledim.
güncellemeleri de yaptım ama bir şeye tıkladığımda tepkime süresi geç oluyor.
Ekran kartı ile ilgili mi anlayamadım.
inxi -Fxz
System:    Host: yusuf Kernel: 4.15.0-20-generic x86_64
           bits: 64 gcc: 7.3.0
           Desktop: Cinnamon 3.8.8 (Gtk 3.22.30-1ubuntu1)
Machine:   Device: laptop System: ASUSTeK product: TX201LA v: 1.0 serial: N/A
           Mobo: ASUSTeK model: TX201LA v: 1.0 serial: N/A
           BIOS: American Megatrends v: TX201LA.215 date: 06/17/2014
Battery    BAT0: charge: 26.4 Wh 98.9% condition: 26.7/33.4 Wh (80%)
           model: ASUSTeK TX21-4 status: Charging
CPU:       Dual core Intel Core i5-4200U (-MT-MCP-)
           arch: Haswell rev.1 cache: 3072 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 9179
           clock speeds: max: 2600 MHz 1: 1029 MHz 2: 1310 MHz 3: 1366 MHz
           4: 1428 MHz
Graphics:  Card: Intel Haswell-ULT Integrated Graphics Controller
           bus-ID: 00:02.0
           Resolution: 1920x1080@60.00hz
           OpenGL: renderer: Mesa DRI Intel Haswell Mobile
           version: 4.5 Mesa 18.0.0-rc5 Direct Render: Yes
Audio:     Card-1 Intel 8 Series HD Audio Controller
           Card-2 Intel Haswell-ULT HD Audio Controller
           driver: snd_hda_intel bus-ID: 00:03.0
           Sound: Advanced Linux Sound Architecture v: k4.15.0-20-generic
Network:   Card: Realtek RTL8821AE 802.11ac PCIe Wireless Network Adapter
           driver: rtl8821ae port: e000 bus-ID: 02:00.0
Drives:    HDD Total Size: 1500.3GB (38.9% used)
           ID-1: /dev/sda model: HGST_HTS545050A7 size: 500.1GB
           ID-2: USB /dev/sdb model: M3_Portable size: 1000.2GB
Partition: ID-1: / size: 458G used: 53G (13%) fs: ext4 dev: /dev/sda1
Sensors:   System Temperatures: cpu: 45.5C mobo: N/A
           Fan Speeds (in rpm): cpu: 3200
Info:      Processes: 209 Uptime: 24 min Memory: 1400.8/3828.9MB
« Son Düzenleme: 11 Aralık 2018, 07:12:53 Gönderen: harkail_rad »
  • İleti: 16272
Ynt: Ekranda ki tepkilerin geç oluşması
« Yanıtla #1 : 10 Aralık 2018, 22:43:37 »
Paylaştığınız çıktılara göre sistem güncel değil, ya da sistemi güncelledikten sonra yeniden başlatmadınız.
Aşağıdaki komutla Intel GPU için klasik sürücüyü ve UXA hızlandırmayı etkinleştirmeyi deneyebilirsiniz.
sudo mkdir -p /etc/X11/xorg.conf.d/ && echo -e 'Section "Device"\n Identifier "Intel Graphics"\n Driver "Intel"\n Option "AccelMethod" "uxa"\nEndSection' | sudo tee /etc/X11/xorg.conf.d/20-intel.conf
  • İleti: 96
« Yanıtla #2 : 11 Aralık 2018, 07:11:38 »
Hocam oldu çok teşekkür ederim .
Güncellemeden sonra ki son hali bu şekilde.
inxi -Fxz
           bits: 64 gcc: 7.3.0
           Desktop: Cinnamon 3.8.9 (Gtk 3.22.30-1ubuntu1)
Battery    BAT0: charge: 27.1 Wh 98.4% condition: 27.5/33.4 Wh (82%)
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 9177
           clock speeds: max: 2600 MHz 1: 814 MHz 2: 1328 MHz 3: 1452 MHz
           4: 1430 MHz
           bus-ID: 00:02.0
           Display Server: x11 (X.Org 1.19.6 ) driver: intel
           version: 4.5 Mesa 18.0.5 Direct Render: Yes
Drives:    HDD Total Size: 500.1GB (12.1% used)
Partition: ID-1: / size: 458G used: 57G (13%) fs: ext4 dev: /dev/sda1
Sensors:   System Temperatures: cpu: 42.0C mobo: N/A
           Fan Speeds (in rpm): cpu: 2800
Info:      Processes: 201 Uptime: 4 min Memory: 847.8/3828.9MB
Yalnız bir sorum olacak. Her intel sürücüde bu komutu kullanmalımıyız?
Bir de hocam, sizlere zahmet olacak ama ben teknik servis personeli olduğum için gün içinde bir kaç bilgisayara kurulum yapabiliyorum. Tabi linux işletim sistemi windows gibi olmadığı için aygıt yöneticisinden eksik sürücüleri var mı yokmu nereden kontrol edilir bilemiyorum.
Ekran takılma sorununu inanın bulamazdım diye düşünüyorum.
Buna benzer püf noktaları bizimle paylaşırsanız belki sizleri yormamış oluruz hemde formdaki diğer arkadaşlarımızın sorunlarını çözmesinde durumu daha iyi anlayacağımız için faydalı oluruz diye düşünüyorum.
  • İleti: 16272
« Yanıtla #3 : 11 Aralık 2018, 17:03:57 »
Bu işlem Intel GPU'ların geneli için uygulanabilir. Hem yırtılma hem de performans sorunlarını çözebilir ama kesin değil.
Farklı GPU'lar farklı öneriler sunulabilir. Bu sebeple bir şablon önermek zor. Ama kendinize sık oluşan sorunların çözümünü içerecek bir dosya oluşturabilirsiniz.
Bizim burada yaptığımız bir sürücü kurulumu değildi. Sadece geleneksel Intel sürücüsünü etkinleştirip, buu UXA hızlandırma kipinde çalıştırmaktı.
Hangi aygıt için hangi sürücünün etkin olduğu inxi komutunun çıktsında görünüyor, mesela Intel için modesetting sürücüsü etkindi. apılandırma dosyası ile klasik intel sürücüsünü etkinleştirdik.
Modesetting sürücüsü KVM desteği için daha uygun bir sürücü, çekirdekle geliyor ve artık Linux Mint 19.x (Ubuntu 18.0.x tabanı ile) varsayılan. Eğer sistemde sanallaştırma kullanıyorsanız, modesetting sürücüsünü tercih edin, ofis vb. işlemler için klasik intel sürücüsü daha uygun olur. Önceki sürümde intel sürücüsü varsayılandı. Bazı güncel donanımlarda bu sürücü daha performaslıyken, bazı donanımlarda klasik sürücü daha performanslı olabiliyor.
