Gönderen Konu: Bluetooth çalışmıyor  (Okunma sayısı 276 defa)
Çevrimdışı HALDUNHİTAY
  • İleti: 69
  • Dağıtım: LİNUX MİNT TARA
  • Grafik Kartı: Intel Haswell Mobile
  • İşlemci: Intel Core i5-4210U CPU
« : 10 Aralık 2018, 15:22:21 »
Merhabalar, benim sorunum şu: Önceleri bir sorun yoktu, fakat son zamanlarda bluetoothum çalışmıyor. Uçbirim çıktıları şöyle:
inxi -Fxz
System:    Host: haldun-PU551LD Kernel: 4.15.0-42-generic x86_64
           bits: 64 gcc: 7.3.0
           Desktop: Cinnamon 3.8.9 (Gtk 3.22.30-1ubuntu1)
Machine:   Device: laptop System: ASUSTeK product: PU551LD v: 1.0 serial: N/A
           Mobo: ASUSTeK model: PU551LD v: 1.0 serial: N/A
           BIOS: American Megatrends v: PU551LD.209 date: 10/30/2014
Battery    BAT0: charge: 32.1 Wh 98.7% condition: 32.5/37.4 Wh (87%)
           model: ASUSTeK PU45026 status: Discharging
CPU:       Dual core Intel Core i5-4210U (-MT-MCP-)
           arch: Haswell rev.1 cache: 3072 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 9578
           clock speeds: max: 2700 MHz 1: 854 MHz 2: 1521 MHz 3: 1640 MHz
           4: 1579 MHz
Graphics:  Card-1: Intel Haswell-ULT Integrated Graphics Controller
           bus-ID: 00:02.0
           Card-2: NVIDIA GF117M [GeForce 610M/710M/810M/820M / GT 620M/625M/630M/720M]
           bus-ID: 05:00.0
           drivers: modesetting,nvidia (unloaded: fbdev,vesa,nouveau)
           Resolution: 1366x768@60.00hz
           OpenGL: renderer: GeForce 820M/PCIe/SSE2
           version: 4.4.0 NVIDIA 340.107 Direct Render: Yes
Audio:     Card-1 Intel 8 Series HD Audio Controller
           Card-2 Intel Haswell-ULT HD Audio Controller
           driver: snd_hda_intel bus-ID: 00:03.0
           Sound: Advanced Linux Sound Architecture v: k4.15.0-42-generic
           driver: r8169 v: 2.3LK-NAPI port: e000 bus-ID: 03:00.0
           Card-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
           driver: ath9k bus-ID: 04:00.0
           IF: wlp4s0 state: up mac: <filter>
Drives:    HDD Total Size: 500.1GB (15.3% used)
           ID-1: /dev/sda model: HGST_HTS545050A7 size: 500.1GB temp: 36C
Partition: ID-1: / size: 137G used: 64G (50%) fs: ext4 dev: /dev/sda1
           ID-2: swap-1 size: 8.18GB used: 0.00GB (0%)
           fs: swap dev: /dev/sda4
Sensors:   System Temperatures: cpu: 43.0C mobo: N/A gpu: 0.0:45C
           Fan Speeds (in rpm): cpu: 2400
Info:      Processes: 199 Uptime: 7 min Memory: 943.0/3816.4MB
           Client: Shell (bash 4.4.191) inxi: 2.3.56 [code]
[code]rfkill list
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
1: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
Tek bildiğim, hiçbir şey bilmediğimdir.
  • İleti: 16272
Ynt: Bluetooth çalışmıyor
« Yanıtla #1 : 10 Aralık 2018, 15:54:42 »
Aşağıdaki komutların çıktılarına da bakalım.
lsusb | grep Blue
dmesg | grep blue
hcitool dev
  • İleti: 69
« Yanıtla #2 : 10 Aralık 2018, 18:12:14 »
Aynen böyle:
haldun[member=3507]Haldun[/member]-PU551LD:~$ lsusb | grep Blue
haldun[member=3507]Haldun[/member]-PU551LD:~$ dmesg | grep blue
haldun[member=3507]Haldun[/member]-PU551LD:~$ hcitool dev
Devices:
hci0 40:E2:30:C7:2A:1A
  • İleti: 16272
« Yanıtla #3 : 10 Aralık 2018, 22:29:29 »
Sistemi eski çekirdeklerden birisi ile açmayı dener misiniz?
  • İleti: 69
« Yanıtla #4 : 11 Aralık 2018, 08:39:34 »
Yine olmadı üstadım. 4.15.0-20'den başlayarak birkaç çekirdek denedim , ama bir türlü çalışmadı. Önce bağlantı kuruluyor, fakat birkaç saniye sonra kesiliyor.
  • İleti: 16272
« Yanıtla #5 : 11 Aralık 2018, 16:40:35 »
sysfsutils paketini kurup aşağıdaki komutun çıktısını paylşaınız.
systool -vm ath9k
  • İleti: 69
« Yanıtla #6 : 11 Aralık 2018, 20:42:24 »
Buyrun :
haldun[member=3507]Haldun[/member]-PU551LD:~$ systool -vm ath9k
Module = "ath9k"
  Attributes:
    coresize            = "151552"
    initsize            = "0"
    initstate           = "live"
    refcnt              = "0"
    srcversion          = "F4328CE52BA6067DD4EDE7B"
    taint               = ""
    uevent              = <store method only>
  Parameters:
    blink               = "0"
    bt_ant_diversity    = "0"
    btcoex_enable       = "1"
    led_active_high     = "-1"
    nohwcrypt           = "1"
    ps_enable           = "0"
    use_chanctx         = "0"
    use_msi             = "0"
  Sections:
  • İleti: 16272
« Yanıtla #7 : 11 Aralık 2018, 23:32:22 »
Aşağıdaki komutu uçbirimde çalıştırıp, sistemi yeniden başlatmayı dener misiniz?
echo "options ath9k btcoex_enable=1 bt_ant_diversity=1 nohwcrypt=1" | sudo tee  /etc/modprobe.d/ath9k.conf
  • İleti: 69
« Yanıtla #8 : 12 Aralık 2018, 09:33:47 »
Bu komutu çalıştırıp sistemi yeniden başlattım, fakat bu da işe yaramadı üstat. Dosya alışverişi yapmak istediğimde "Öntanımlı dosya tarayıcısı çalıştırılamadı." ve "Hata oluştu" mesajları alıyorum.
  • İleti: 16272
« Yanıtla #9 : 12 Aralık 2018, 13:39:06 »
Blueman uygulamasını kurup, bağlantıyı bununla sağlamayı deneyebilirsiniz.
  • İleti: 69
« Yanıtla #10 : 12 Aralık 2018, 18:24:49 »
Blueman da işe yaramadı üstadım.Mint'in yeni kararlı sürümünü indirip kurduğumda bu sorun düzelir belki.İlginize teşekkür ederim.
  • İleti: 16272
« Yanıtla #11 : 13 Aralık 2018, 00:49:12 »
Aşağıdaki komutların çıktılarına bir bakalım.
lsusb
lspci
lsmod
  • İleti: 69
« Yanıtla #12 : 13 Aralık 2018, 08:44:53 »
Buyrun :
lsusb
Bus 001 Device 006: ID 145f:0237 Trust
Bus 001 Device 005: ID 138a:0010 Validity Sensors, Inc. VFS Fingerprint sensor
Bus 001 Device 004: ID 04f2:b409 Chicony Electronics Co., Ltd
Bus 001 Device 007: ID 13d3:3408 IMC Networks
Bus 001 Device 002: ID 8087:8000 Intel Corp.
Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub[code]
[code]lspci
00:00.0 Host bridge: Intel Corporation Haswell-ULT DRAM Controller (rev 0b)
00:03.0 Audio device: Intel Corporation Haswell-ULT HD Audio Controller (rev 0b)
00:04.0 Signal processing controller: Intel Corporation Haswell-ULT Thermal Subsystem (rev 0b)
00:14.0 USB controller: Intel Corporation 8 Series USB xHCI HC (rev 04)
00:16.0 Communication controller: Intel Corporation 8 Series HECI #0 (rev 04)
00:1b.0 Audio device: Intel Corporation 8 Series HD Audio Controller (rev 04)
00:1c.0 PCI bridge: Intel Corporation 8 Series PCI Express Root Port 1 (rev e4)
00:1c.1 PCI bridge: Intel Corporation 8 Series PCI Express Root Port 2 (rev e4)
00:1c.2 PCI bridge: Intel Corporation 8 Series PCI Express Root Port 3 (rev e4)
00:1c.3 PCI bridge: Intel Corporation 8 Series PCI Express Root Port 4 (rev e4)
00:1c.4 PCI bridge: Intel Corporation 8 Series PCI Express Root Port 5 (rev e4)
00:1d.0 USB controller: Intel Corporation 8 Series USB EHCI #1 (rev 04)
00:1f.0 ISA bridge: Intel Corporation 8 Series LPC Controller (rev 04)
00:1f.2 SATA controller: Intel Corporation 8 Series SATA Controller 1 [AHCI mode] (rev 04)
00:1f.3 SMBus: Intel Corporation 8 Series SMBus Controller (rev 04)
00:1f.6 Signal processing controller: Intel Corporation 8 Series Thermal (rev 04)
02:00.0 Unassigned class [ff00]: Alcor Micro AU6601 PCI-E Flash card reader controller
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 10)
04:00.0 Network controller: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter (rev 01)
05:00.0 3D controller: NVIDIA Corporation GF117M [GeForce 610M/710M/810M/820M / GT 620M/625M/630M/720M] (rev a1)[code]
[code]lsmod
ccm                    20480  6
cmac                   16384  1
ip6t_REJECT            16384  1
nf_reject_ipv6         16384  1 ip6t_REJECT
nf_log_ipv6            16384  5
xt_hl                  16384  22
ip6t_rt                16384  3
nf_conntrack_ipv6      20480  8
nf_defrag_ipv6         36864  1 nf_conntrack_ipv6
ipt_REJECT             16384  1
nf_reject_ipv4         16384  1 ipt_REJECT
nf_log_ipv4            16384  5
nf_log_common          16384  2 nf_log_ipv4,nf_log_ipv6
xt_LOG                 16384  10
xt_multiport           16384  4
xt_limit               16384  13
xt_tcpudp              16384  18
xt_addrtype            16384  4
nvidia_uvm             36864  0
videobuf2_core         40960  2 videobuf2_v4l2,uvcvideo
nvidia              10559488  37 nvidia_uvm
videodev              184320  3 videobuf2_core,videobuf2_v4l2,uvcvideo
media                  40960  2 videodev,uvcvideo
asus_nb_wmi            28672  0
asus_wmi               28672  1 asus_nb_wmi
mxm_wmi                16384  0
sparse_keymap          16384  1 asus_wmi
snd_hda_codec_conexant    24576  1
snd_hda_codec_generic    73728  1 snd_hda_codec_conexant
snd_hda_intel          40960  5
kvm_intel             212992  0
snd_hda_codec         126976  4 snd_hda_codec_generic,snd_hda_codec_conexant,snd_hda_codec_hdmi,snd_hda_intel
ath3k                  20480  0
snd_hda_core           81920  5 snd_hda_codec_generic,snd_hda_codec_conexant,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec
kvm                   598016  1 kvm_intel
snd_pcm                98304  4 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_core
bluetooth             548864  44 btrtl,btintel,btbcm,bnep,ath3k,btusb,rfcomm
ecdh_generic           24576  2 bluetooth
aesni_intel           188416  6
ath9k                 151552  0
ath9k_common           36864  1 ath9k
ath9k_hw              471040  2 ath9k_common,ath9k
ath                    28672  3 ath9k_common,ath9k,ath9k_hw
intel_pch_thermal      16384  0
mac80211              778240  1 ath9k
snd                    81920  21 snd_hda_codec_generic,snd_seq,snd_hda_codec_conexant,snd_seq_device,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_timer,snd_pcm,snd_rawmidi
cfg80211              622592  4 ath9k_common,ath9k,ath,mac80211
processor_thermal_device    16384  0
intel_soc_dts_iosf     16384  1 processor_thermal_device
nf_conntrack_ipv4      16384  8
nf_defrag_ipv4         16384  1 nf_conntrack_ipv4
xt_conntrack           16384  16
wmi                    24576  2 asus_wmi,mxm_wmi
dell_smo8800           16384  0
int3402_thermal        16384  0
int340x_thermal_zone    16384  2 int3402_thermal,processor_thermal_device
asus_wireless          16384  0
int3400_thermal        16384  0
acpi_thermal_rel       16384  1 int3400_thermal
ip6table_filter        16384  1
sch_fq_codel           20480  2
ip6_tables             28672  1 ip6table_filter
nf_conntrack_netbios_ns    16384  0
nf_conntrack_broadcast    16384  1 nf_conntrack_netbios_ns
nf_nat_ftp             16384  0
nf_nat                 32768  1 nf_nat_ftp
nf_conntrack_ftp       20480  1 nf_nat_ftp
nf_conntrack          131072  8 xt_conntrack,nf_conntrack_ipv6,nf_conntrack_ipv4,nf_nat,nf_nat_ftp,nf_conntrack_netbios_ns,nf_conntrack_broadcast,nf_conntrack_ftp
libcrc32c              16384  2 nf_conntrack,nf_nat
iptable_filter         16384  1
ip_tables              28672  1 iptable_filter
x_tables               40960  14 ip6table_filter,xt_conntrack,iptable_filter,xt_LOG,xt_multiport,xt_tcpudp,xt_addrtype,ip6t_rt,ip6_tables,ipt_REJECT,ip_tables,xt_limit,xt_hl,ip6t_REJECT
hid                   118784  2 usbhid,hid_generic
i915                 1617920  3
drm_kms_helper        172032  1 i915
drm                   401408  6 drm_kms_helper,nvidia,i915
i2c_i801               28672  0
video                  45056  2 asus_wmi,i91
  • İleti: 16272
« Yanıtla #13 : 14 Aralık 2018, 00:19:30 »
Aşğaıdaki komutun çıktısına da bakabilir miyiz?
dmesg | grep firm
  • İleti: 69
« Yanıtla #14 : 14 Aralık 2018, 08:13:44 »
Buyrun üstadım :
dmesg | grep firm
[    0.028153] Spectre V2 : Enabling Restricted Speculation for firmware calls
