Gönderen Konu: Harddisk Kötü sektör veya arıza durumu  (Okunma sayısı 177 defa)
Çevrimdışı onurtasci
  • İleti: 14
    • onurtasci5252
    • onurtasci5252
    • Bir web developerlik macerası
  • Grafik Kartı: Intel + Nvidia Hibrit
  • İşlemci: İntel i5
« : 21 Ekim 2018, 18:37:01 »
Merhabalar,
Harddiskimin sağlığını öğrenmek için gsmartcontrol ile tarattım ve error log bölümünde hataların olduğunu gördüm ciddiye almam gereken hatalarmı bunlar bilmediğim için size sormak istediğim aşağıda tarama sonuçları mevcut
Harddiskimi onarmak yapabileceğim birşey varmı örnek kötü sektör gibi olaylar için
Gsmartcontrol Çıktısı
=== START OF INFORMATION SECTION ===
Model Family:     Seagate Samsung SpinPoint M8 (AF)
Device Model:     ST1000LM024 HN-M101MBB
Serial Number:    S32HJ9HDC03847
LU WWN Device Id: 5 0004cf 20c1f2ce6
Firmware Version: 2BA30001
User Capacity:    1,000,204,886,016 bytes [1.00 TB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    5400 rpm
Form Factor:      2.5 inches
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   ATA8-ACS T13/1699-D revision 6
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Sun Oct 21 18:31:16 2018 +03
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
AAM feature is:   Disabled
APM level is:     254 (maximum performance)
Rd look-ahead is: Enabled
Write cache is:   Enabled
ATA Security is:  Disabled, frozen [SEC2]
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status:      ( 121) The previous self-test completed having
the read element of the test failed.
Total time to complete Offline
data collection: (12600) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities:            (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability:        (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: (   2) minutes.
Extended self-test routine
recommended polling time: ( 210) minutes.
SCT capabilities:        (0x003f) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate     POSR-K   100   100   051    -    1624
  2 Throughput_Performance  -OS--K   252   252   000    -    0
  3 Spin_Up_Time            PO---K   092   091   025    -    2617
  4 Start_Stop_Count        -O--CK   095   095   000    -    5171
  5 Reallocated_Sector_Ct   PO--CK   252   252   010    -    0
  7 Seek_Error_Rate         -OSR-K   252   252   051    -    0
  8 Seek_Time_Performance   --S--K   252   252   015    -    0
  9 Power_On_Hours          -O--CK   100   100   000    -    14736
 10 Spin_Retry_Count        -O--CK   252   252   051    -    0
 12 Power_Cycle_Count       -O--CK   097   097   000    -    4018
191 G-Sense_Error_Rate      -O---K   100   100   000    -    3668
192 Power-Off_Retract_Count -O---K   252   252   000    -    0
194 Temperature_Celsius     -O----   060   048   000    -    40 (Min/Max 13/55)
195 Hardware_ECC_Recovered  -O-RCK   100   100   000    -    0
196 Reallocated_Event_Count -O--CK   252   252   000    -    0
197 Current_Pending_Sector  -O--CK   100   100   000    -    2
198 Offline_Uncorrectable   ----CK   252   252   000    -    0
199 UDMA_CRC_Error_Count    -OS-CK   100   100   000    -    3
200 Multi_Zone_Error_Rate   -O-R-K   100   100   000    -    73011
223 Load_Retry_Count        -O--CK   100   100   000    -    287
225 Load_Cycle_Count        -O--CK   086   086   000    -    146169
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
                            |||____ S speed/performance
                            ||_____ O updated online
                            |______ P prefailure warning
General Purpose Log Directory Version 1
SMART           Log Directory Version 1 [multi-sector log support]
Address    Access  R/W   Size  Description
0x00       GPL,SL  R/O      1  Log Directory
0x01           SL  R/O      1  Summary SMART error log
0x02           SL  R/O      2  Comprehensive SMART error log
0x03       GPL     R/O      2  Ext. Comprehensive SMART error log
0x06           SL  R/O      1  SMART self-test log
0x07       GPL     R/O      2  Extended self-test log
0x08       GPL     R/O      2  Power Conditions log
0x09           SL  R/W      1  Selective self-test log
0x10       GPL     R/O      1  SATA NCQ Queued Error log
0x11       GPL     R/O      1  SATA Phy Event Counters log
0x80-0x9f  GPL,SL  R/W     16  Host vendor specific log
0xc0-0xdf  GPL,SL  VS      16  Device vendor specific log
0xe0       GPL,SL  R/W      1  SCT Command/Status
0xe1       GPL,SL  R/W      1  SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (2 sectors)
Device Error Count: 1055 (device log contains only the most recent 8 errors)
CR     = Command Register
FEATR  = Features Register
COUNT  = Count (was: Sector Count) Register
LBA_48 = Upper bytes of LBA High/Mid/Low Registers ]  ATA-8
LH     = LBA High (was: Cylinder High) Register    ]   LBA
LM     = LBA Mid (was: Cylinder Low) Register      ] Register
LL     = LBA Low (was: Sector Number) Register     ]
DV     = Device (was: Device/Head) Register
DC     = Device Control Register
ER     = Error register
ST     = Status register
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 1055 [6] occurred at disk power-on lifetime: 14722 hours (613 days + 10 hours)
  When the command that caused the error occurred, the device was active or idle.
  After command completion occurred, registers were:
  ER -- ST COUNT  LBA_48  LH LM LL DV DC
  40 -- 41 00 08 00 00 45 cd e8 00 40 00  Error: UNC at LBA = 0x45cde800 = 1171122176
  Commands leading to the command that caused the error were:
  CR FEATR COUNT  LBA_48  LH LM LL DV DC  Powered_Up_Time  Command/Feature_Name
  60 00 00 00 08 00 00 45 cd e8 00 40 08     00:00:00.059  READ FPDMA QUEUED
  61 00 00 00 08 00 00 05 00 10 00 40 08     00:00:00.129  WRITE FPDMA QUEUED
  60 00 00 00 08 00 00 45 cd e8 00 40 08     00:00:00.129  READ FPDMA QUEUED
  61 00 00 00 08 00 00 01 00 13 90 40 08     00:00:00.129  WRITE FPDMA QUEUED
  27 00 00 00 00 00 00 00 00 00 00 e0 08     00:00:00.129  READ NATIVE MAX ADDRESS EXT [OBS-ACS-3]
Error 1054 [5] occurred at disk power-on lifetime: 14722 hours (613 days + 10 hours)
  60 00 00 00 08 00 00 45 cd e8 00 40 08     00:00:00.126  READ FPDMA QUEUED
  61 00 00 05 40 00 00 14 80 81 00 40 08     00:00:00.126  WRITE FPDMA QUEUED
  61 00 00 05 40 00 00 14 80 86 40 40 08     00:00:00.126  WRITE FPDMA QUEUED
  61 00 00 05 40 00 00 14 80 8b 80 40 08     00:00:00.126  WRITE FPDMA QUEUED
Error 1053 [4] occurred at disk power-on lifetime: 14722 hours (613 days + 10 hours)
  40 -- 41 00 08 00 00 45 cd e8 00 40 00  Error: WP at LBA = 0x45cde800 = 1171122176
  61 00 00 05 40 00 00 14 80 81 00 40 08     00:00:00.097  WRITE FPDMA QUEUED
  60 00 00 00 08 00 00 45 cd e8 00 40 08     00:00:00.095  READ FPDMA QUEUED
  ea 00 00 00 00 00 00 00 00 00 00 e0 08     00:00:00.095  FLUSH CACHE EXT
  61 00 00 00 08 00 00 00 00 10 30 40 08     00:00:00.095  WRITE FPDMA QUEUED
Error 1052 [3] occurred at disk power-on lifetime: 14722 hours (613 days + 10 hours)
  61 00 00 00 10 00 00 0f 44 11 88 40 00     00:00:00.092  WRITE FPDMA QUEUED
  60 00 00 00 08 00 00 45 cd e8 00 40 08     00:00:00.092  READ FPDMA QUEUED
  61 00 00 05 40 00 00 14 80 71 00 40 08     00:00:00.092  WRITE FPDMA QUEUED
  61 00 00 05 40 00 00 14 80 76 40 40 08     00:00:00.092  WRITE FPDMA QUEUED
Error 1051 [2] occurred at disk power-on lifetime: 14722 hours (613 days + 10 hours)
  61 00 00 05 40 00 00 14 80 71 00 40 08     00:00:00.062  WRITE FPDMA QUEUED
  60 00 00 00 08 00 00 45 cd e8 00 40 08     00:00:00.060  READ FPDMA QUEUED
  60 00 00 00 08 00 00 45 8d e8 00 40 08     00:00:00.060  READ FPDMA QUEUED
  60 00 00 00 08 00 00 45 4d e8 00 40 08     00:00:00.060  READ FPDMA QUEUED
Error 1050 [1] occurred at disk power-on lifetime: 14513 hours (604 days + 17 hours)
  40 -- 41 00 08 00 00 0f 6c f1 b8 40 00  Error: UNC at LBA = 0x0f6cf1b8 = 258798008
  60 00 00 00 08 00 00 0f 6c f1 b8 40 08     00:00:00.596  READ FPDMA QUEUED
  60 00 00 00 20 00 00 00 61 a0 00 40 00     00:00:00.634  READ FPDMA QUEUED
  60 00 00 00 08 00 00 0f 6c f1 b8 40 08     00:00:00.634  READ FPDMA QUEUED
  60 00 00 00 08 00 00 07 c1 11 40 40 08     00:00:00.634  READ FPDMA QUEUED
  60 00 00 00 08 00 00 10 00 08 78 40 00     00:00:00.634  READ FPDMA QUEUED
Error 1049 [0] occurred at disk power-on lifetime: 14513 hours (604 days + 17 hours)
  60 00 00 00 08 00 00 07 c1 11 40 40 08     00:00:00.601  READ FPDMA QUEUED
  60 00 00 00 08 00 00 0f 6c f1 b8 40 08     00:00:00.599  READ FPDMA QUEUED
  61 00 00 00 08 00 00 10 ae 3e f8 40 08     00:00:00.599  WRITE FPDMA QUEUED
  61 00 00 00 08 00 00 0f 7c 43 98 40 08     00:00:00.599  WRITE FPDMA QUEUED
Error 1048 [7] occurred at disk power-on lifetime: 14513 hours (604 days + 17 hours)
  60 00 00 00 08 00 00 0f 6c f1 b8 40 08     00:00:00.511  READ FPDMA QUEUED
  61 00 00 00 70 00 00 08 84 1f 60 40 08     00:00:00.556  WRITE FPDMA QUEUED
  60 00 00 00 08 00 00 0c 84 08 f0 40 08     00:00:00.556  READ FPDMA QUEUED
  60 00 00 00 08 00 00 0f 6c f1 b8 40 08     00:00:00.556  READ FPDMA QUEUED
  60 00 00 00 08 00 00 0c 81 0b 08 40 08     00:00:00.556  READ FPDMA QUEUED
SMART Extended Self-test Log Version: 1 (2 sectors)
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline       Completed: read failure       90%     14736         258798008
# 2  Offline             Completed without error       00%         0         -
SMART Selective self-test log data structure revision number 0
Note: revision number not 1 implies that no selective self-test has ever been run
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Completed_read_failure [90% left] (0-65535)
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
SCT Status Version:                  2
SCT Version (vendor specific):       256 (0x0100)
SCT Support Level:                   1
Device State:                        Active (0)
Current Temperature:                    40 Celsius
Power Cycle Min/Max Temperature:     25/42 Celsius
Lifetime    Min/Max Temperature:     13/55 Celsius
Under/Over Temperature Limit Count:   0/0
SCT Temperature History Version:     2
Temperature Sampling Period:         5 minutes
Temperature Logging Interval:        5 minutes
Min/Max recommended Temperature:     -5/80 Celsius
Min/Max Temperature Limit:           -10/85 Celsius
Temperature History Size (Index):    128 (104)
Index    Estimated Time   Temperature Celsius
 105    2018-10-21 07:55    40  *********************
 106    2018-10-21 08:00    40  *********************
 107    2018-10-21 08:05    39  ********************
 108    2018-10-21 08:10    39  ********************
 109    2018-10-21 08:15    38  *******************
 110    2018-10-21 08:20    38  *******************
 111    2018-10-21 08:25    39  ********************
 112    2018-10-21 08:30    39  ********************
 113    2018-10-21 08:35    39  ********************
 114    2018-10-21 08:40    40  *********************
 ...    ..(  3 skipped).    ..  *********************
 118    2018-10-21 09:00    40  *********************
 119    2018-10-21 09:05    41  **********************
 ...    ..(  5 skipped).    ..  **********************
 125    2018-10-21 09:35    41  **********************
 126    2018-10-21 09:40    33  **************
 127    2018-10-21 09:45    35  ****************
   0    2018-10-21 09:50    37  ******************
   1    2018-10-21 09:55    40  *********************
   2    2018-10-21 10:00    41  **********************
   3    2018-10-21 10:05    42  ***********************
   4    2018-10-21 10:10    43  ************************
   5    2018-10-21 10:15    43  ************************
   6    2018-10-21 10:20    42  ***********************
   7    2018-10-21 10:25    43  ************************
   8    2018-10-21 10:30    43  ************************
   9    2018-10-21 10:35    43  ************************
  10    2018-10-21 10:40    42  ***********************
  11    2018-10-21 10:45    41  **********************
  12    2018-10-21 10:50    40  *********************
  13    2018-10-21 10:55    40  *********************
  14    2018-10-21 11:00    41  **********************
 ...    ..(  7 skipped).    ..  **********************
  22    2018-10-21 11:40    41  **********************
  23    2018-10-21 11:45    42  ***********************
  24    2018-10-21 11:50    42  ***********************
  25    2018-10-21 11:55    41  **********************
  26    2018-10-21 12:00    42  ***********************
  27    2018-10-21 12:05    43  ************************
  28    2018-10-21 12:10    42  ***********************
  29    2018-10-21 12:15    41  **********************
  30    2018-10-21 12:20    39  ********************
  31    2018-10-21 12:25    40  *********************
  32    2018-10-21 12:30    40  *********************
  33    2018-10-21 12:35    41  **********************
  34    2018-10-21 12:40    41  **********************
  35    2018-10-21 12:45    42  ***********************
  36    2018-10-21 12:50    42  ***********************
  37    2018-10-21 12:55    42  ***********************
  38    2018-10-21 13:00    43  ************************
  39    2018-10-21 13:05    28  *********
  40    2018-10-21 13:10    31  ************
  41    2018-10-21 13:15    33  **************
  42    2018-10-21 13:20    35  ****************
  43    2018-10-21 13:25    36  *****************
  44    2018-10-21 13:30    37  ******************
  45    2018-10-21 13:35    38  *******************
  46    2018-10-21 13:40    39  ********************
  47    2018-10-21 13:45    39  ********************
  48    2018-10-21 13:50    40  *********************
 ...    ..(  2 skipped).    ..  *********************
  51    2018-10-21 14:05    40  *********************
  52    2018-10-21 14:10    39  ********************
  53    2018-10-21 14:15    39  ********************
  54    2018-10-21 14:20    39  ********************
  55    2018-10-21 14:25    40  *********************
  56    2018-10-21 14:30    39  ********************
  57    2018-10-21 14:35    40  *********************
  58    2018-10-21 14:40    41  **********************
  59    2018-10-21 14:45    41  **********************
  60    2018-10-21 14:50    42  ***********************
 ...    ..(  3 skipped).    ..  ***********************
  64    2018-10-21 15:10    42  ***********************
  65    2018-10-21 15:15    41  **********************
  66    2018-10-21 15:20    40  *********************
 ...    ..(  9 skipped).    ..  *********************
  76    2018-10-21 16:10    40  *********************
  77    2018-10-21 16:15    41  **********************
 ...    ..(  2 skipped).    ..  **********************
  80    2018-10-21 16:30    41  **********************
  81    2018-10-21 16:35    40  *********************
  82    2018-10-21 16:40    39  ********************
  83    2018-10-21 16:45    39  ********************
  84    2018-10-21 16:50    38  *******************
  88    2018-10-21 17:10    38  *******************
  89    2018-10-21 17:15    39  ********************
  90    2018-10-21 17:20    39  ********************
  91    2018-10-21 17:25    40  *********************
  94    2018-10-21 17:40    40  *********************
  95    2018-10-21 17:45    39  ********************
 103    2018-10-21 18:25    39  ********************
 104    2018-10-21 18:30    40  *********************
SCT Error Recovery Control:
           Read: Disabled
          Write: Disabled
Device Statistics (GP/SMART Log 0x04) not supported
SATA Phy Event Counters (GP Log 0x11)
ID      Size     Value  Description
0x0001  4            0  Command failed due to ICRC error
0x0002  4            0  R_ERR response for data FIS
0x0003  4            0  R_ERR response for device-to-host data FIS
0x0004  4            0  R_ERR response for host-to-device data FIS
0x0005  4            0  R_ERR response for non-data FIS
0x0006  4            0  R_ERR response for device-to-host non-data FIS
0x0007  4            0  R_ERR response for host-to-device non-data FIS
0x0008  4            0  Device-to-host non-data FIS retries
0x0009  4            6  Transition from drive PhyRdy to drive PhyNRdy
0x000a  4            3  Device-to-host register FISes sent due to a COMRESET
0x000b  4            0  CRC errors within host-to-device FIS
0x000d  4            0  Non-CRC errors within host-to-device FIS
0x000f  4            0  R_ERR response for host-to-device data FIS, CRC
0x0010  4            0  R_ERR response for host-to-device data FIS, non-CRC
0x0012  4            0  R_ERR response for host-to-device non-data FIS, CRC
0x0013  4            0  R_ERR response for host-to-device non-data FIS, non-CRC
0x8e00  4            0  Vendor specific
0x8e01  4            0  Vendor specific
0x8e02  4            0  Vendor specific
0x8e03  4            0  Vendor specific
0x8e04  4            0  Vendor specific
0x8e05  4            0  Vendor specific
0x8e06  4            0  Vendor specific
0x8e07  4            0  Vendor specific
0x8e08  4            0  Vendor specific
0x8e09  4            0  Vendor specific
0x8e0a  4            0  Vendor specific
0x8e0b  4            0  Vendor specific
0x8e0c  4            0  Vendor specific
0x8e0d  4            0  Vendor specific
0x8e0e  4            0  Vendor specific
0x8e0f  4            0  Vendor specific
0x8e10  4            0  Vendor specific
0x8e11  4            0  Vendor specific
« Son Düzenleme: 21 Ekim 2018, 18:38:21 Gönderen: onurtasci »
