Gönderen Konu: [Elementary OS 5.0] Bazı Uygulamaların Simgelerinin Gözükmemesi  (Okunma sayısı 741 defa)
Çevrimdışı JihXela
  • İleti: 103
  • Dağıtım: Solus
  • Masaüstü: Budgie
  • Grafik Kartı: GeForce GT 320M
  • İşlemci: Intel Core i3 M330
Elementary OS 5.0 in çıkmasıyla büyük bir heyecanla indirip kurdum. Temiz kurulum gerçekleştirdim. Ancak kurulum bittikten sonra bilgisayarımı yeniden başlattığımda bazı simgelerin gözükmediğini farkettim. İnternette gözlemlediğim kadarıyla bu sorun sadece bende var.
inxi -Fxxz
System:    Host: elder Kernel: 4.15.0-36-generic x86_64 bits: 64 gcc: 7.3.0
           Desktop: Gnome  (Gtk 3.22.30-1ubuntu1) dm: lightdm Distro: elementary OS 5.0 Juno
Machine:   Device: laptop System: Packard Bell product: EasyNote TM86 v: V1.23 serial: N/A
           Mobo: Packard Bell model: EasyNote TM86 v: V1.23 serial: N/A
           BIOS: Packard Bell v: V1.23 date: 04/25/2011
Battery    BAT0: charge: 4.6 Wh 100.0% condition: 4.6/47.5 Wh (10%) volts: 12.0/10.8
           model: SANYO Li_Ion_4000mA serial: <filter>status: Full
CPU:       Dual core Intel Core i3 M 330 (-MT-MCP-) arch: Nehalem rev.2 cache: 3072 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 8513
           clock speeds: min/max: 933/2133 MHz 1: 2128 MHz 2: 2128 MHz 3: 2128 MHz 4: 2128 MHz
Graphics:  Card: NVIDIA GT216M [GeForce GT 320M] bus-ID: 01:00.0 chip-ID: 10de:0a2d
           Display Server: x11 (X.Org 1.19.6 ) drivers: nouveau (unloaded: modesetting,fbdev,vesa)
           Resolution: 1366x768@60.04hz
           OpenGL: renderer: NVA5 version: 3.3 Mesa 18.0.5 (compat-v: 3.0) Direct Render: Yes
Audio:     Card-1 Intel 5 Series/3400 Series High Definition Audio
           driver: snd_hda_intel bus-ID: 00:1b.0 chip-ID: 8086:3b56
           Card-2 NVIDIA GT216 HDMI Audio Controller driver: snd_hda_intel bus-ID: 01:00.1 chip-ID: 10de:0be2
           Sound: Advanced Linux Sound Architecture v: k4.15.0-36-generic
Network:   Card-1: Broadcom Limited NetLink BCM57780 Gigabit Ethernet PCIe
           driver: tg3 v: 3.137 bus-ID: 02:00.0 chip-ID: 14e4:1692
           IF: enp2s0 state: down mac: <filter>
           Card-2: Realtek RTL8192SE Wireless LAN Controller
           driver: rtl8192se port: 1000 bus-ID: 03:00.0 chip-ID: 10ec:8174
Drives:    HDD Total Size: 320.1GB (2.2% used)
           ID-1: /dev/sda model: Hitachi_HTS54503 size: 320.1GB serial: <filter>
Partition: ID-1: / size: 293G used: 6.6G (3%) fs: ext4 dev: /dev/sda1
           Unused Devices: none
Sensors:   System Temperatures: cpu: 47.0C mobo: N/A gpu: 45.0
Info:      Processes: 196 Uptime: 2 min Memory: 830.2/2863.5MB Init: systemd v: 237 runlevel: 5 Gcc sys: N/A
           Client: Shell (bash 4.4.191 running in io.elementary.t) inxi: 2.3.56
Yardımlarınız için şimdiden teşekkür ederim :)
« Son Düzenleme: 17 Ekim 2018, 21:21:06 Gönderen: JihXela »
  • İleti: 16465
Hangi uygulamalar mesela? Açılan konularda mümkün olduğunca fazla ayrıntı paylaşalım lütfen.
ISO dosyasında mevcut bazı uygulamalar, kurulum sonrası betiği ile temizlenmiş olabilir, örneğin Gparted gibi..
Çevrimdışı JihXela
  • İleti: 103
  • Dağıtım: Solus
  • Masaüstü: Budgie
Hocam paylaştığım ekran görüntüsünde Ekran görüntüsü, Hesap Makinesi, Kamera, Sistem Ayarları ve Takvim uygulamalarının simgeleri sabit bir simge (gri bir kutucuk içinde koyu renkli çark) ile değiştirilmiş ve asıl simgeleri gözükmüyor. ISO dosyasında mevcut olan bazı uygulamaların kurum sonrasında silindiğini biliyorum. Ancak burada sorun uygulamaların silinmesi değil sadece uygulamaların simgelerinin olmayıp orjinal simgelerin yerlerinde sabit bir simge ile değiştirilmiş olması.
Her ihtimale karşı paylaştığım ekran görüntüsünü direk bağlantı şeklinde buraya bırakıyorum: https://postimg.cc/YG9qpxSG
  • İleti: 16465
Aşağıdaki komutla eksik olabilecek paketleri kurumayı dener misiniz?
sudo apt install --reinstall elementary-desktop
Çevrimdışı JihXela
  • İleti: 103
  • Dağıtım: Solus
  • Masaüstü: Budgie
Hocam verdiğiniz komutu deneyip bilgisayarı yeniden başlattım ve sonuç değişmedi. Aynı işlemi elementary-icon-theme paketi içinde denedim ancak sorunum yine çözülmedi. ISO kalıbını tekrar indirip format atmayı denediğimi de belirtmek istiyorum.
  • İleti: 16465
Buradaki başlığı da siz mi açtınız? Eğer siz açmadıysanız genel bir sorun olabilir.
but translators keep changing the names of these icons and breaking it
Çevirmenler, bazı simge isimlerini de çevirmişler diyor. Eğer böyleyse doğal olarak ilgili simge isimleri bulunamadığı için boş görünecektir. Dili değiştirmeyi denediniz mi?
« Son Düzenleme: 17 Ekim 2018, 22:43:46 Gönderen: Butterfly »
Çevrimdışı JihXela
  • İleti: 103
  • Dağıtım: Solus
  • Masaüstü: Budgie
Hayır o konuyu ben açmadım. Sistem dilini değiştirince simgeler düzeldi. Dediğiniz gibi sistem diliyle alakalı genel bir sorun galiba. Güncelleme gelene kadar İngilizce kullanmam gerekebilir. Güncellemeyi beklemeden düzeltebilir miyim diye bakıcam daha geniş bir zamanda. Yardım ettiğiniz için teşekkür ederim.
Reddit'i takip etmem gerektiğinide kendime not düşeyim :D
  • İleti: 16465
Mesajımı düzeltmiştim, doğrudan dil ile ilgili değilmiş, çeviri yapılmaması gereken simge isimleri de çevirilmiş sanırım.
Çevrimdışı JihXela
  • İleti: 103
  • Dağıtım: Solus
  • Masaüstü: Budgie
Anladım hocam o zaman çeviriler düzelene kadar bekleyeceğim artık. Konunun çözüldü etiketi ile etiketlenmesi uygun mudur?
  • İleti: 16465
Çevrimdışı JihXela
  • İleti: 103
  • Dağıtım: Solus
  • Masaüstü: Budgie
Eğer sadece Türkçe'ye çevrilmiş kısımları geri İngilizce'ye döndürmek yeterli ise bende yapabilirim hocam. Çevirileri düzenleyebilmek için hesap açmak yeterli mi yoksa çevirmenlerin görebileceği bir şekilde öneride mi bulunmam gerekiyor?
Güncelleme: Çevirileri düzenleyebilmek için yetkili olmak gerekiyormuş. Şu aşamada yetkili bir çevirmen görene kadar yapabileceğimiz tek şey öneri yapmak ki onu da zaten siz yapmışsınız.
« Son Düzenleme: 17 Ekim 2018, 23:35:17 Gönderen: JihXela »
Çevrimiçi Leopard
  • İleti: 1006
Çoğu Linux dağıtımında ve yazılımında İngilizce dışındaki diller ikinci sınıf vatandaş muamelesi görüyor maalesef. Ama rapor oluşturduğunuz zaman geç de olsa düzeltiliyor.
