Gönderen Konu: phpmyadmin #2002 - Sunucu yanıt vermiyor hatası  (Okunma sayısı 390 defa)
Çevrimdışı alper196
  • İleti: 10
    • alper196
    • alper196
  • Dağıtım: Linux Mint 18.3
  • Masaüstü: Gnome
  • Grafik Kartı: İntel + Nvidia
  • İşlemci: i7 2. nesil
« : 19 Eylül 2018, 21:18:08 »
sorunum budur PHP 7 kurulu
uçbirimden mysql bağlanmaya çalıştığımda aldığım hata:
alper[member=3649]alper[/member]-A15:~$    mysql -u root
ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)
Pc Genel özellikleri
System:    Host: alper-A15 Kernel: 4.15.0-34-generic x86_64
           bits: 64 gcc: 7.3.0
           Desktop: MATE 1.20.1 (Gtk 3.22.30-1ubuntu1) dm: lightdm
Machine:   Device: laptop System: PEGATRON product: A15 v: 1.0 serial: N/A
           Mobo: PEGATRON model: A15 v: 1.0 serial: N/A
           BIOS: American Megatrends v: 303 date: 07/04/2012
Battery    BAT0: charge: 22.4 Wh 97.4% condition: 23.0/47.3 Wh (49%)
           volts: 12.3/10.8
           model: A15 A15--22 serial: N/A status: N/A
CPU:       Dual core Intel Core i7-2620M (-MT-MCP-)
           arch: Sandy Bridge rev.7 cache: 4096 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 10775
           clock speeds: min/max: 800/3400 MHz 1: 2698 MHz 2: 2883 MHz
           3: 3083 MHz 4: 2913 MHz
Graphics:  Card-1: Intel 2nd Generation Core Integrated Graphics Controller
           bus-ID: 00:02.0 chip-ID: 8086:0126
           Card-2: NVIDIA GF108M [GeForce GT 540M]
           bus-ID: 01:00.0 chip-ID: 10de:0df4
           Display Server: x11 (X.Org 1.19.6 ) driver: intel
           Resolution: 1366x768@60.00hz
           OpenGL: renderer: Mesa DRI Intel Sandybridge Mobile
           version: 3.3 Mesa 18.0.5 (compat-v: 3.0) Direct Render: Yes
Audio:     Card Intel 6 Series/C200 Series Family High Def. Audio Controller
           driver: snd_hda_intel bus-ID: 00:1b.0 chip-ID: 8086:1c20
           Sound: Advanced Linux Sound Architecture v: k4.15.0-34-generic
Network:   Card-1: Intel Centrino Wireless-N 1030 [Rainbow Peak]
           driver: iwlwifi bus-ID: 03:00.0 chip-ID: 8086:008a
           Card-2: Qualcomm Atheros AR8151 v2.0 Gigabit Ethernet
           driver: atl1c v: 1.0.1.1-NAPI port: a000
           bus-ID: 04:00.0 chip-ID: 1969:1083
Drives:    HDD Total Size: 500.1GB (12.6% used)
           ID-1: /dev/sda model: ST500LM021 size: 500.1GB serial: <filter>
Partition: ID-1: / size: 83G used: 59G (76%) fs: ext4 dev: /dev/sda1
           Unused Devices: none
Sensors:   System Temperatures: cpu: 79.0C mobo: N/A
Info:      Processes: 213 Uptime: 1 day Memory: 3298.6/7886.9MB
           Client: Shell (bash 4.4.191 running in mate-terminal) inxi: 2.3.56
  • İleti: 16061
Ynt: phpmyadmin #2002 - Sunucu yanıt vermiyor hatası
« Yanıtla #1 : 19 Eylül 2018, 22:33:02 »
Lütfen açtığınız konularda hataları resim olarak paylaşmayınız, bunları kod etiketi içinde foruma aktarınız.
Burada anlatıldığı biçimde parola sıfırlamayı deneyebilirsiniz.
Çevrimdışı alper196
  • İleti: 10
    • alper196
    • alper196
  • Masaüstü: Gnome
« Yanıtla #2 : 19 Eylül 2018, 23:54:35 »
bu konuyu yaptım sıfırlama esnasında
mysql -u root
girilmesi gerekiyor girdiğim zaman
ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)uyarısı alıyorum.
adımın ilk başında hata aldığım için devamına geçemiyorum.
Ekran fotoğrafi PHPmyadmin ekran görüntüdür.  ekranı görerek hata tespiti daha sağlıklı olabileceğini düşündüğüm için o şekilde koydum.
  • İleti: 16061
« Yanıtla #3 : 20 Eylül 2018, 00:02:04 »
Komutu yönetici haklarıyla çalıştırdığınıza emin misin? Bağlantıdaki komutu inceleyiniz.
Çıktıların foruma aktarılmasını istememmizin sebepleri var; örneğin bir tanesi forum içi aramalarda sonuç çıkması, bir diğeri paylaşılan resmin sağlayıcı da silinmesi sonraı konunun benzer sorunları yaşayabilecek kişiler için anlamsız hale gelmesi gibi...
Çevrimdışı alper196
  • İleti: 10
    • alper196
    • alper196
  • Masaüstü: Gnome
« Yanıtla #4 : 20 Eylül 2018, 00:12:29 »
alıyorum tabiki bir sonraki konuya dikkat ederim,
Evet Komutu yönetici olarak çalıştırdım.
root@ alper-A15:~# mysql -u root
  • İleti: 16061
« Yanıtla #5 : 20 Eylül 2018, 00:18:30 »
Buradaki benzer bir sorun için, burada önerildiği biçimde tüm paketleri kaldırıp, yeniden kurulumu önermişiz ve sorun çözülmüş.
Çevrimdışı minteger
  • İleti: 387
  • Masaüstü: --illede KDE
« Yanıtla #6 : 21 Eylül 2018, 01:44:42 »
Yapılandırma esnasında bir sorun oluşması anlık kesinti yada bir dosyanın inmemesi veya bir nedenle bir eksiğin gibi durumlarda bu sorun oluşuyor.
 Kısacası kurulum ve yapılandırma kusurlu oluyor. Çözülebilirmi ? Olabilir ? Ama çok uğraş gerektirir. Sizin için önemli bilgiler içermiyorsa yeniden temiz kurulum yapmanızı öneririm.
Çevrimdışı alper196
  • İleti: 10
    • alper196
    • alper196
  • Masaüstü: Gnome
« Yanıtla #7 : 21 Eylül 2018, 14:10:02 »
evet temiz kurulum yaparak oldu ilginiz için teşekürler :)
