Gönderen Konu: [Çözüldü] Nvidia Ekran koruyucu hatası  (Okunma sayısı 488 defa)
Çevrimdışı Greydeath
  • İleti: 97
  • Masaüstü: Mate 1.18.0
  • İşlemci: Intel Core i5-2500
« : 03 Haziran 2018, 14:59:49 »
Merhaba, bilgisayarım uzun bekleme süresinden sonra kilitleniyor ve ekranda sadece nvidia sembolü oluyor. Klavyeden veya fare hareketi ile açılış yapılmıyor. Bundan kurtulmak için hızlı başlangıç tuşu ile bilgisayarı tekrar kapatıp açmam gerekiyor. Bu sorunu nasıl çözebilirim?
inxi -Fxz
System:    Host: Lmint Kernel: 4.13.0-43-generic x86_64 (64 bit gcc: 5.4.0)
           Desktop: Xfce 4.12.3 (Gtk 2.24.28) Distro: Linux Mint 18.3 Sylvia
Machine:   Mobo: ASUSTeK model: P8H67-V v: Rev X.0x
           Bios: American Megatrends v: 0806 date: 10/26/2011
CPU:       Quad core Intel Core i5-2500 (-MCP-) cache: 6144 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 26491
           clock speeds: max: 3700 MHz 1: 1605 MHz 2: 1605 MHz 3: 1605 MHz
           4: 1605 MHz
           bus-ID: 00:02.0
           Card-2: NVIDIA GF108 [GeForce GT 420] bus-ID: 01:00.0
           Display Server: X.Org 1.18.4 drivers: nvidia,intel (unloaded: fbdev,vesa,nouveau)
           Resolution: 1360x765@60.00hz
           GLX Renderer: GeForce GT 420/PCIe/SSE2
           GLX Version: 4.4.0 NVIDIA 340.106 Direct Rendering: Yes
Audio:     Card-1 NVIDIA GF108 High Definition Audio Controller
           driver: snd_hda_intel bus-ID: 01:00.1
           Card-2 Intel 6 Series/C200 Series Family High Definition Audio Controller
           Sound: Advanced Linux Sound Architecture v: k4.13.0-43-generic
Network:   Card: Qualcomm Atheros AR8151 v2.0 Gigabit Ethernet
           driver: atl1c v: 1.0.1.1-NAPI port: c000 bus-ID: 07:00.0
           IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives:    HDD Total Size: 6121.2GB (2.4% used)
           ID-1: /dev/sda model: TOSHIBA_DT01ACA2 size: 2000.4GB
           ID-2: /dev/sdb model: WDC_WD20EARS size: 2000.4GB
           ID-3: /dev/sdc model: SAMSUNG_HD154UI size: 1500.3GB
           ID-4: /dev/sdd model: TS120GSSD220S size: 120.0GB
           ID-5: USB /dev/sdi model: 00AAVS size: 500.1GB
Partition: ID-1: / size: 1.8T used: 127G (8%) fs: ext4 dev: /dev/sda2
           ID-2: swap-1 size: 8.50GB used: 0.00GB (0%) fs: swap dev: /dev/sda3
Sensors:   System Temperatures: cpu: 52.0C mobo: N/A gpu: 0.0:39C
           Fan Speeds (in rpm): cpu: 0
Info:      Processes: 187 Uptime: 16 min Memory: 951.2/7888.5MB
           Client: Shell (bash 4.3.481) inxi: 2.2.35
« Son Düzenleme: 04 Haziran 2018, 13:28:48 Gönderen: Greydeath »
  • İleti: 16568
Ynt: Nvidia Ekran koruyucu hatası
« Yanıtla #1 : 03 Haziran 2018, 19:23:05 »
Nvidia sürücüsünün eski bir sürümünü kullaıyorsunuz, bu GPU'nun güncel sürücüler için desteği olması gerekir. Aşağıdaki komutlarla Nvidia sürücüsünü güncellemeyi dener misiniz? Ardından sistemi yeniden başlatmanız gerekecek.
sudo apt update
sudo apt hold nvidia-settings
sudo apt install nvidia-390
Ayrıca çekirdek sürümünü de yükseltmenizde de fayda olabilir. https://forum.linuxmint.net.tr/index.php?topic=9154.0
  • İleti: 97
Ynt: [Çözüldü] Nvidia Ekran koruyucu hatası
« Yanıtla #2 : 04 Haziran 2018, 13:27:50 »
Teşekkürler. Çekirdek ve Nvidia güncellemesi yaptım ve düzeldi.
