Gönderen Konu: [Çözüldü] Chromium sistemi donduruyor?  (Okunma sayısı 624 defa)
Çevrimdışı mesut24
  • İleti: 50
  • Grafik Kartı: NVDİA
  • İşlemci: İNTEL
« : 31 Mayıs 2018, 04:18:20 »
Mrb. Chromium ile nete girdiğim zaman pc donuyor ve mecbur güç düğmesi ile reset atıyorum. Çözerseniz çok sevinirim..
Sİstem çıktısı
System:    Host: erdenler Kernel: 4.13.0-43-generic x86_64 (64 bit gcc: 5.4.0)
           Desktop: Cinnamon 3.6.7 (Gtk 3.18.9-1ubuntu3.3) dm: lightdm
Machine:   Mobo: ASUSTeK model: Z77-A v: Rev X.0x
           Bios: American Megatrends v: 0402 date: 01/18/2013
CPU:       Quad core Intel Core i5-3330 (-MCP-) cache: 6144 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 24069
           clock speeds: min/max: 1600/3200 MHz 1: 1622 MHz 2: 1612 MHz
           3: 1607 MHz 4: 1625 MHz
Graphics:  Card: NVIDIA GK106 [GeForce GTX 660]
           bus-ID: 01:00.0 chip-ID: 10de:11c0
           Display Server: X.Org 1.18.4 drivers: nouveau (unloaded: fbdev,vesa)
           Resolution: 1920x1080@60.00hz
           GLX Renderer: NVE6
           GLX Version: 3.0 Mesa 17.2.8 Direct Rendering: Yes
Audio:     Card-1 Intel 7 Series/C210 Series Family High Definition Audio Controller
           Card-2 NVIDIA GK106 HDMI Audio Controller
           driver: snd_hda_intel bus-ID: 01:00.1 chip-ID: 10de:0e0b
           Sound: Advanced Linux Sound Architecture v: k4.13.0-43-generic
           driver: r8169 v: 2.3LK-NAPI port: d000
           bus-ID: 03:00.0 chip-ID: 10ec:8168
           Card-2: Realtek RTL8192CU 802.11n WLAN Adapter
           driver: rtl8192cu usb-ID: 003-002 chip-ID: 0bda:8178
           IF: wlx081076fa73ae state: N/A mac: N/A
Drives:    HDD Total Size: 250.1GB (54.3% used)
           ID-1: /dev/sda model: TOSHIBA_MK2561GS size: 250.1GB serial: 82S7F4X7S
Partition: ID-1: / size: 222G used: 119G (57%) fs: ext4 dev: /dev/sda1
           ID-2: swap-1 size: 8.53GB used: 0.00GB (0%) fs: swap dev: /dev/sda5
           Unused Devices: none
Sensors:   System Temperatures: cpu: 29.8C mobo: 27.8C
           Fan Speeds (in rpm): cpu: 0
Info:      Processes: 190 Uptime: 5 min Memory: 1251.9/7925.1MB
           Client: Shell (bash 4.3.481 running in gnome-terminal-) inxi: 2.2.35
ekran kartı çıktıları
           GLX Renderer: NVE6
OpenGL renderer string: NVE6
01:00.0 VGA compatible controller: NVIDIA Corporation GK106 [GeForce GTX 660] (rev a1)
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 16384 x 16384
DVI-I-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 477mm x 268mm
   1920x1080     60.00*+
   1680x1050     59.95
   1280x1024     75.02    60.02
   1440x900      59.89
   1280x960      60.00
   1024x768      75.03    70.07    60.00
   832x624       74.55
   640x480       75.00    72.81    66.67    59.94
   720x400       70.08
DVI-D-1 disconnected (normal left inverted right x axis y axis)
erdenler@erdenler ~ $ xrandr
   1920x1080     60.00*+
   1680x1050     59.95
   1440x900      59.89
   1280x960      60.00
   832x624       74.55
   720x400       70.08
erdenler@erdenler ~ $ cat /etc/X11/xorg.conf
erdenler@erdenler ~ $ dpkg -l | egrep 'nvidia|bumblebee|primus|prime|virtualgl|fglrx'
ii  nvidia-384                                        384.130-0ubuntu0.16.04.1                     amd64        NVIDIA binary driver - version 384.130
ii  nvidia-opencl-icd-384                             384.130-0ubuntu0.16.04.1                     amd64        NVIDIA OpenCL ICD
ii  nvidia-prime                                      0.8.2linuxmint1                              amd64        Tools to enable NVIDIA's Prime
ii  nvidia-prime-applet                               1.0.6                                        all          An applet for NVIDIA Prime
ii  nvidia-settings                                   361.42-0ubuntu1                              amd64        Tool for configuring the NVIDIA graphics driver
Şİmdiden teşekkürler
« Son Düzenleme: 31 Mayıs 2018, 18:30:52 Gönderen: mesut24 »
  • İleti: 16273
Ynt: Chromium sistemi donduruyor?
« Yanıtla #1 : 31 Mayıs 2018, 09:06:04 »
Öncelikle sisteminizi aşağıdaki şekilde güncelleyiniz.
Güncelleme Yöneticisi => Düzenle menüsü => Tercihler => Seviyeler kısmından 4. seviyeye kadar güncellemeleri işaretleyiniz. Ardından "Yenile" düğmesine tıklayıp paket bilgisi önbelleğini güncelledikten sonra, görünen tüm güncellemeleri seçiniz ve "Güncellemeleri Kur" düğmesine tıklayarak sisteminizi güncelleyiniz. Sonrasında isterseniz 4. seviye güncellemeleri pasifleştirebilirsiniz.
https://forum.linuxmint.net.tr/index.php?topic=9154.0
Ayrıca Sürücü Yöneticisinden Nvidia sahipli sürücüsünü kurmayı deneyiniz.
Çevrimdışı mesut24
  • İleti: 50
  • İşlemci: İNTEL
« Yanıtla #2 : 31 Mayıs 2018, 14:32:40 »
Zaten NVDİA kurulu idi onu son sürüm driver ile güncelledim.
  • İleti: 16273
« Yanıtla #3 : 31 Mayıs 2018, 14:40:47 »
Çıktıya göre etkin görünmüyor. Aşağıdıdaki komutu uçbirimde çalıştırıp sistemi yeniden başlatmayı deneyiniz.
sudo nvidia-xconfig
Çevrimdışı mesut24
  • İleti: 50
  • İşlemci: İNTEL
« Yanıtla #4 : 31 Mayıs 2018, 18:28:25 »
Sorun çözüldü. Teşekkürler...
  • İleti: 16273
Ynt: [Çözüldü] Chromium sistemi donduruyor?
« Yanıtla #5 : 31 Mayıs 2018, 18:41:28 »
Rica ederiz. Aşağıdaki komutun çıktısını paylaşırsanız, Nvidia sürücüsünün etkin olup olmadığını teyit edelim.
inxi -Gxx
Çevrimdışı mesut24
  • İleti: 50
  • İşlemci: İNTEL
« Yanıtla #6 : 02 Haziran 2018, 16:09:35 »
inxi -Gxx
erdenler@erdenler ~ $ inxi -Gxx
           GLX Renderer: GeForce GTX 660/PCIe/SSE2
           GLX Version: 4.6.0 NVIDIA 396.24 Direct Rendering: Yes
  • İleti: 16273
« Yanıtla #7 : 02 Haziran 2018, 19:13:15 »
Çıktıya göre Nvidia sürücüsü etkin olmuş.
Sorun çözüldüğü konu kilitlenmiştir.
