mehmet[member=1581]Mehmet[/member] ~ $ steam steam://rungameid/286080
Running Steam on linuxmint 18.3 64-bit
STEAM_RUNTIME is enabled automatically
Pins up-to-date!
Installing breakpad exception handler for appid(steam)/version(1522709999)
** (steam:4305): WARNING **: Ignoring invalid property 'secondaries'
** (steam:4305): WARNING **: Ignoring invalid property 'route-data'
** (steam:4305): WARNING **: Ignoring invalid property 'address-data'
tManager.cpp (469) : Assertion Failed: font != vgui::INVALID_FONT
../vgui_surfacelib/FontManager.cpp (469) : Assertion Failed: font != vgui::INVALID_FONT
ExecCommandLine: "'/home/mehmet/.local/share/Steam/ubuntu12_32/steam' 'steam://rungameid/286080'"
ExecuteSteamURL: "steam://rungameid/286080"
System startup time: 4,54 seconds
GameAction [AppID 286080, ActionID 1] : LaunchApp changed task to SynchronizingCloud with ""
(steam:4305): LIBDBUSMENU-GLIB-WARNING **: Trying to remove a child that doesn't believe we're it's parent.
(steam:4305): LIBDBUSME.....................................
[0508/165253.327931:ERROR:web_plugin_impl.cc(38)] Widevine registration is not supported after context initialization
Setting breakpad minidump AppID = 769
Steam_SetMinidumpSteamID: Caching Steam ID: 76561198084174758 [API loaded no]
GameAction [AppID 286080, ActionID 1] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
GameAction [AppID 286080, ActionID 1] : LaunchApp changed task to CreatingProcess with ""
GameAction [AppID 286080, ActionID 1] : LaunchApp waiting for user response to CreatingProcess ""
GameAction [AppID 286080, ActionID 1] : LaunchApp continues with user response "CreatingProcess"
Opted-in Controller Mask: 0
Game update: AppID 286080 "", ProcID 4410, IP 0.0.0.0:0
>>> Adding process 4410 for game ID 286080
GameAction [AppID 286080, ActionID 1] : LaunchApp changed task to WaitingGameWindow with ""
ERROR: ld.so: object '/home/mehmet/.local/share/Steam/ubuntu12_32/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS32): ignored.
GameAction [AppID 286080, ActionID 1] : LaunchApp changed task to Completed with ""
pid 4413 != 4412, skipping destruction (fork without exec?)
>>> Adding process 4411 for game ID 286080
ERROR: ld.so: object '/home/mehmet/.local/share/Steam/ubuntu12_64/gameoverlayrenderer.so' from LD_PRELOAD cannot be preloaded (wrong ELF class: ELFCLASS64): ignored.
>>> Adding process 4412 for game ID 286080
>>> Adding process 4414 for game ID 286080
>>> Adding process 4415 for game ID 286080
libGL error: unable to load driver: r600_dri.so
libGL error: driver pointer missing
libGL error: failed to load driver: r600
libGL error: unable to load driver: swrast_dri.so
libGL error: failed to load driver: swrast
X Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode of failed request: 155 (GLX)
Minor opcode of failed request: 3 (X_GLXCreateContext)
Value in failed request: 0x0
Serial number of failed request: 80
Current serial number in output stream: 81
Game removed: AppID 286080 "", ProcID 4410
No cached sticky mapping in ActivateActionSet.[0508/165254.360689:ERROR:web_plugin_impl.cc(38)] Widevine registration is not supported after context initialization
process 4305: arguments to dbus_connection_ref() were incorrect, assertion "connection->generation == _dbus_current_generation" failed in file ../../dbus/dbus-connection.c line 2656.
This is normally a bug in some application using the D-Bus library.
process 4305: arguments to dbus_connection_unref() were incorrect, assertion "connection->generation == _dbus_current_generation" failed in file ../../dbus/dbus-connection.c line 2794.
process 4305: arguments to dbus_connection_ref() were incorrect, assertion "connection->generation == _dbus_current_generation" failed in file ../../dbus/dbus-c........................................
bp-fe7b775a-f043-4906-8f7a-731f92180508
assert_20180508165252_23.dmp[4408]: file ''/tmp/dumps/assert_20180508165252_23.dmp'', upload yes: ''CrashID=bp-fe7b775a-f043-4906-8f7a-731f92180508''
ClientJobRemoteStorageSync.cpp (2419) : Assertion Failed: Failed to write file after download (2)
process 4305: arguments to dbus_connection_ref() were incorrect, assertion "connection->generation == _dbus_current_generation" failed in file ../../dbus/dbus-connection.c line 2656..........................
This is normal.........................
şu an çıktı bu
