Gönderen Konu: Nvidia GTX 1050 Sürücü Kurulum Sorunu  (Okunma sayısı 729 defa)
Çevrimdışı cozal
  • İleti: 2
  • Dağıtım: linux mint
  • Masaüstü: cinnamon
  • Grafik Kartı: gtx 1050
  • İşlemci: intel i7
« : 30 Mart 2018, 23:02:12 »
Merhaba, Nvidia sürücümü güncelledikten sonra şu tarz bir hata alıyorum; "Cinnamon sadece çöktü şu an Fallback kipinde çalışıyorsunuz". Ayrıca hiç bir Linux sürümünde de sürücüyü kuramadım, yardım ederseniz sevinirim.
inxi -SMGxx
System:    Host: HP-Pavilion Kernel: 4.13.0-37-generic x86_64 (64 bit gcc: 5.4.0)
           Desktop: Cinnamon 3.6.7 (Gtk 3.18.9-1ubuntu3.3) dm: lightdm
Machine:   System: HP (portable) product: HP Pavilion Power Laptop 15-cb0xx v: Type1ProductConfigId
           Mobo: HP model: 836B v: 46.23 Bios: Insyde v: F.13 date: 11/03/2017
           Chassis: type: 10
Graphics:  Card-1: Intel Device 591b bus-ID: 00:02.0 chip-ID: 8086:591b
           Card-2: NVIDIA Device 1c8d bus-ID: 01:00.0 chip-ID: 10de:1c8d
           Display Server: X.Org 1.18.4 drivers: fbdev,intel (unloaded: vesa)
           Resolution: 1920x1080@77.00hz
           GLX Renderer: llvmpipe (LLVM 5.0, 256 bits)
           GLX Version: 3.0 Mesa 17.2.8 Direct Rendering: Yes
irect rendering: Yes
OpenGL renderer string: llvmpipe (LLVM 5.0, 256 bits)
00:02.0 VGA compatible controller: Intel Corporation Device 591b (rev 04)
01:00.0 VGA compatible controller: NVIDIA Corporation Device 1c8d (rev a1)
xrandr: Failed to get size of gamma for output default
Screen 0: minimum 1920 x 1080, current 1920 x 1080, maximum 1920 x 1080
default connected primary 1920x1080+0+0 0mm x 0mm
   1920x1080     77.00*
rc  nvidia-384                            384.111-0ubuntu0.16.04.1                     amd64        NVIDIA binary driver - version 384.111
rc  nvidia-opencl-icd-384                 384.111-0ubuntu0.16.04.1                     amd64        NVIDIA OpenCL ICD
ii  nvidia-prime                          0.8.2linuxmint1                              amd64        Tools to enable NVIDIA's Prime
ii  nvidia-prime-applet                   1.0.6                                        all          An applet for NVIDIA Prime
ii  nvidia-settings                       361.42-0ubuntu1                              amd64        Tool for configuring the NVIDIA graphics driver
« Son Düzenleme: 31 Mart 2018, 10:12:42 Gönderen: Butterfly »
  • İleti: 16611
Ynt: Nvidia GTX 1050 Sürücü Kurulum Sorunu
« Yanıtla #1 : 31 Mart 2018, 10:20:13 »
Size de merhaba,
Lütfen açılan konularda aşağıdaki hususlara özen gösterelim, buna istinaden mesajınız yazım kurallarına göre düzenlenmiş ve konu başlığı başlığı düzeltilmiştir.
Şu anki duruma göre Nvidia sürücüsü kurulu görünmüyor. Ama siz sorunun sürücü güncellemesi ile oluştuğunu yazmışsınız. Bu hususu biraz daha açıklamanız gerekiyor.
  • İleti: 1005
« Yanıtla #2 : 01 Nisan 2018, 19:58:48 »
Bahsettiğiniz sorunun bir benzerini ben yaşadım laptopumda.
Acpi değişkeni olarak Windows 2009 ayarlayarak çözdüm. İsterseniz sizde deneyin.
Asus Fx553 VD , bende de Gtx 1050 var.
