Gönderen Konu: Harici Monitör Çözünürlük Sorunu  (Okunma sayısı 965 defa)
Çevrimdışı fusuyevo
  • İleti: 14
« : 19 Ağustos 2017, 11:01:27 »
Merhaba
1920x1080 harici monitörü bağladığımda alt panelin sadece ucu görünüyor.Aynı sorun windows kullanırken de oldu ve intel ayarlarından dikey ve yatay ayarlama yaptım.Yani Ekranı üstten ve sağdan biraz azaltmam gerekli.Nasıl yapabilirim.
professor[member=5081]professor[/member]-Lenovo-G500 ~ $ inxi -SGx
System:    Host: professor-Lenovo-G500 Kernel: 4.8.0-53-generic x86_64 (64 bit gcc: 5.4.0)
           Desktop: KDE Plasma 5.8.7 (Qt 5.6.1) Distro: Linux Mint 18.2 Sonya
Graphics:  Card-1: Intel 3rd Gen Core processor Graphics Controller bus-ID: 00:02.0
           Card-2: Advanced Micro Devices [AMD/ATI] Sun PRO [Radeon HD 8570A/8570M] bus-ID: 01:00.0
           Display Server: X.Org 1.18.4 drivers: ati,radeon,intel (unloaded: fbdev,vesa)
           Resolution: 1920x1080@60.00hz
           GLX Renderer: Mesa DRI Intel Ivybridge Mobile GLX Version: 3.0 Mesa 17.0.7 Direct Rendering: Yes
professor[member=5081]professor[/member]-Lenovo-G500 ~ $ glxinfo | grep render
professor[member=5081]professor[/member]-Lenovo-G500 ~ $ lspci | egrep 'VGA|3D|Display'
01:00.0 Display controller: Advanced Micro Devices, Inc. [AMD/ATI] Sun PRO [Radeon HD 8570A/8570M] (rev ff)
professor[member=5081]professor[/member]-Lenovo-G500 ~ $ xrandr
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
LVDS1 connected (normal left inverted right x axis y axis)
   1366x768      60.00 +
   1360x768      59.80    59.96
   1280x720      60.00
   1024x768      60.00
   1024x576      60.00
   960x540       60.00
   800x600       60.32    56.25
   864x486       60.00
   640x480       59.94
   720x405       60.00
   680x384       60.00
   640x360       60.00
HDMI1 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 735mm x 420mm panning 1920x1080+0+0
   1920x1080     50.00 +  60.00*   59.94
   1920x1080i    60.00    50.00    59.94
   1280x720      60.00    50.00    59.94
   720x576       50.00
   720x576i      50.00
   720x480       60.00    59.94
   720x480i      60.00    59.94
   640x480       60.00    59.94
   19200         59.96
professor[member=5081]professor[/member]-Lenovo-G500 ~ $ cat /etc/X11/xorg.conf
professor[member=5081]professor[/member]-Lenovo-G500 ~ $ dpkg -l | egrep 'nvidia|bumblebee|primus|prime|virtualgl|fglrx'
ii  nvidia-prime-applet                             1.0.6                                      all          An applet for NVIDIA Prime
  • İleti: 16273
Ynt: Harici Monitör Çözünürlük Sorunu
« Yanıtla #1 : 19 Ağustos 2017, 11:14:09 »
Aşağıdaki komutlardan sonra durum ne oluyor?
xrandr --output HDMI1 --set underscan on
xrandr --output HDMI1 --set "underscan hborder" 48 --set "underscan vborder" 24
Komutları çalıştırdıktan sonra, kabloyu çıkartıp yeniden takmak gerekebilir.
Çevrimdışı fusuyevo
  • İleti: 14
« Yanıtla #2 : 19 Ağustos 2017, 11:15:14 »
professor[member=5081]professor[/member]-Lenovo-G500 ~ $ xrandr --output HDMI1 --set underscan on
X Error of failed request:  BadName (named color or font does not exist)
  Major opcode of failed request:  140 (RANDR)
  Minor opcode of failed request:  11 (RRQueryOutputProperty)
  Serial number of failed request:  39
  Current serial number in output stream:  39
professor[member=5081]professor[/member]-Lenovo-G500 ~ $ xrandr --output HDMI1 --set "underscan hborder" 48 --set "underscan vborder" 24
  • İleti: 16273
« Yanıtla #3 : 19 Ağustos 2017, 11:45:43 »
Peki aşağıdaki komutun sonucu ne oluyor?
intel_panel_fitter -p A -x 1850 -y 1040
Çevrimdışı fusuyevo
  • İleti: 14
« Yanıtla #4 : 19 Ağustos 2017, 11:58:43 »
xrandr --output HDMI --set audio force-dvi --mode 1920x1080
bu komut işe yaradı.Konu kapanabilir.Teşekkürler.intel komutu hata verdi.
  • İleti: 16273
« Yanıtla #5 : 19 Ağustos 2017, 17:57:51 »
Geri dönüş için biz teşekkür ederiz. Konu başlığını etiketlerseniz, konuyu kilitleyebiliriz.
