Gönderen Konu: Epson L382 çıktı alma sorunu  (Okunma sayısı 2285 defa)
Çevrimdışı mynetcan
  • İleti: 3
« : 17 Ocak 2017, 23:12:33 »
Epson marka  L 382 model yazıcıdan bir türlü çıktı alamadım. epson-inkjet-printer-escpr_1.6.11-1lsb3.2_i386.deb paketini epson sayfasından bulup yüklediysemde çıktılarda düzensiz harfler görülmekte.
inxi -Sr
System:    Host: benben-System-Product-Name Kernel: 3.13.0-24-generic i686 (32 bit)
           Desktop: Cinnamon 2.8.8  Distro: Linux Mint 17.3 Rosa
Repos:     Active apt sources in file: /etc/apt/sources.list.d/libreoffice-ppa-trusty.list
           deb http://ppa.launchpad.net/libreoffice/ppa/ubuntu trusty main
           deb-src http://ppa.launchpad.net/libreoffice/ppa/ubuntu trusty main
           Active apt sources in file: /etc/apt/sources.list.d/official-package-repositories.list
           deb http://packages.linuxmint.com rosa main upstream import
           deb http://extra.linuxmint.com rosa main
           deb http://archive.ubuntu.com/ubuntu trusty main restricted universe multiverse
           deb http://archive.ubuntu.com/ubuntu trusty-updates main restricted universe multiverse
           deb http://security.ubuntu.com/ubuntu/ trusty-security main restricted universe multiverse
           deb http://archive.canonical.com/ubuntu/ trusty partner
           Active apt sources in file: /etc/apt/sources.list.d/pipelight-stable-trusty.list
           deb http://ppa.launchpad.net/pipelight/stable/ubuntu trusty main
           deb-src http://ppa.launchpad.net/pipelight/stable/ubuntu trusty main
[code] sudo apt-get install -f
Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
  graphicsmagick libboost-regex1.54.0 libgraphicsmagick++3 libgraphicsmagick3
Use 'apt-get autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 32 not upgraded.
  • İleti: 16568
Ynt: Epson L382 çıktı alma sorunu
« Yanıtla #1 : 18 Ocak 2017, 10:45:10 »
Yüklediğiniz paketi aşağıdaki komutla silip,
sudo apt-get purge epson-inkjet-printer-escpr*
aşağıdaki komutla printer-driver-escpr paketini yüklemeyi deneyebilirsiniz.
sudo apt-get install printer-driver-escpr
Çevrimdışı mynetcan
  • İleti: 3
« Yanıtla #2 : 18 Ocak 2017, 19:55:46 »
Yazdığınız gibi yaptım printer-driver-escpr yi kurdum Generic ESC/P Dot Matrix Printer Foomatic/epson (recommended) isimli sürücüyü kendisi otomatik yükledi, ama sonuc aynı yine çıktı alamıyorum hatta bu sefer kağıt makinede kalıyor.
Cups dan olabilirmi acaba 1.7.2 yüklü? openprinting.org sayfasına baktım bu model için epson sürücü bulamadım aynı özellikte baska bir modelin sürücüsünü yüklediğimde uygun sürücü değil hatası veriyor
Çevrimdışı mynetcan
  • İleti: 3
« Yanıtla #3 : 25 Ocak 2017, 18:56:20 »
sorun çözülür mü diye 18.1 cinnamon 64 bit yükledim ama hiçbir şey  değişmedi sorun aynen devam ediyor çıktı alamıyorum
inxi -Fxz
System:    Host: benben-System-Product-Name Kernel: 4.4.0-53-generic x86_64 (64 bit gcc: 5.4.0)
           Desktop: Cinnamon 3.2.7 (Gtk 3.18.9-1ubuntu3.1)
Machine:   Mobo: ASUSTeK model: M3N78-EMH HDMI v: Rev 1.xx
           Bios: American Megatrends v: 0222 date: 03/11/2008
CPU:       Dual core AMD Athlon 64 X2 5000+ (-MCP-) cache: 1024 KB
           flags: (lm nx sse sse2 sse3 svm) bmips: 3999
           clock speeds: max: 2600 MHz 1: 1000 MHz 2: 1000 MHz
Graphics:  Card: NVIDIA C77 [GeForce 8200] bus-ID: 02:00.0
           Display Server: X.Org 1.18.4 drivers: nouveau (unloaded: fbdev,vesa)
           Resolution: 1280x1024@60.02hz
           GLX Renderer: Gallium 0.4 on NVAA
Audio:     Card NVIDIA MCP72XE/MCP72P/MCP78U/MCP78S High Definition Audio
           driver: snd_hda_intel bus-ID: 00:07.0
           Sound: Advanced Linux Sound Architecture v: k4.4.0-53-generic
Network:   Card: NVIDIA MCP77 Ethernet
           driver: forcedeth port: c880 bus-ID: 00:0a.0
           IF: enp0s10 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives:    HDD Total Size: 402.1GB (3.4% used)
           ID-1: /dev/sda model: WDC_WD800BB size: 80.0GB
           ID-2: /dev/sdb model: SAMSUNG_HD322HJ size: 320.1GB
           ID-3: USB /dev/sdc model: DataTraveler_2.0 size: 2.0GB
Partition: ID-1: / size: 30G used: 5.4G (20%) fs: ext4 dev: /dev/sdb1
           ID-2: /home size: 257G used: 161M (1%) fs: ext4 dev: /dev/sdb2
           ID-3: swap-1 size: 8.19GB used: 0.00GB (0%) fs: swap dev: /dev/sdb3
Sensors:   System Temperatures: cpu: 34.0C mobo: 34.0C gpu: 49.0
           Fan Speeds (in rpm): cpu: 2213 sys-1: 0
Info:      Processes: 187 Uptime: 44 min Memory: 1035.4/3823.5MB
           Client: Shell (bash 4.3.461) inxi: 2.2.35
lsusb
Bus 004 Device 002: ID 09da:000a A4Tech Co., Ltd. Optical Mouse Opto 510D / OP-620D
Bus 003 Device 003: ID 04f9:0028 Brother Industries, Ltd Printer
Bus 003 Device 002: ID 1c4f:0002 SiGma Micro Keyboard TRACER Gamma Ivory
 lpinfo -v
network socket
network ipps
network beh
network http
network ipp14
network https
network ipp
direct ecblp:/var/run/ecblp0
network lpd
direct parallel:/dev/lp0
serial serial:/dev/ttyS0?baud=115200
direct usb://Brother/HL-2040%20series?serial=B0J838738
direct hp
network smb
direct hpfax
anladığım kadarıyla usb de sorun var epson yazıcıyı görmüyor ama brother'ı görüyor
« Son Düzenleme: 26 Ocak 2017, 23:52:13 Gönderen: mynetcan »
