inxi -SGx
System: Host: cengiz-Lenovo Kernel: 4.4.0-21-generic x86_64 (64 bit gcc: 5.3.1)
Desktop: MATE 1.14.1 (Gtk 3.18.9-1ubuntu3.1)
Distro: Linux Mint 18 Sarah
Graphics: Card-1: Intel Haswell-ULT Integrated Graphics Controller
bus-ID: 00:02.0
Card-2: Advanced Micro Devices [AMD/ATI] Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330]
bus-ID: 04:00.0
Display Server: X.Org 1.18.3 drivers: ati,radeon,intel (unloaded: fbdev,vesa)
Resolution: 1366x768@60.00hz
OpenGL renderer string: Mesa DRI Intel(R) Haswell Mobile
cengiz@cengiz-Lenovo ~ $
04:00.0 Display controller: Advanced Micro Devices, Inc. [AMD/ATI] Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330] (rev ff)
eDP1 connected 1366x768+0+0 (normal left inverted right x axis y axis) 344mm x 194mm
1366x768 60.00*+
1360x768 59.80 59.96
1280x720 60.00
1024x768 60.00
1024x576 60.00
960x540 60.00
800x600 60.32 56.25
864x486 60.00
640x480 59.94
720x405 60.00
680x384 60.00
640x360 60.00
HDMI2 disconnected (normal left inverted right x axis y axis)
cengiz@cengiz-Lenovo ~ $ cat /etc/X11/xorg.conf
ii nvidia-prime-applet 1.0.5 all An applet for NVIDIA Prime
