Gönderen Konu: [Çözüldü] Wifi hız problemi  (Okunma sayısı 545 defa)
Çevrimdışı korkmaz
  • İleti: 27
  • Dağıtım: Linux Mint 18.1 Serena
  • Masaüstü: Cinnamon 3.2.6
  • Grafik Kartı: Radeon HD 7500M/7600M Series
  • İşlemci: Intel Core i5-3210M CPU @ 3.1GHz
« : 16 Aralık 2016, 11:45:46 »
İnternet hızım ağa bağlı diğer cihazlara nazaran çok yavaş
korkmaz@korkmazPC ~ $ inxi -SNx
System:    Host: korkmazPC Kernel: 4.4.0-21-generic x86_64 (64 bit gcc: 5.3.1)
           Desktop: KDE Plasma 5.8.4 (Qt 5.6.1) Distro: Linux Mint 18 Sarah
Network:   Card-1: Broadcom BCM4313 802.11bgn Wireless Network Adapter
           driver: bcma-pci-bridge bus-ID: 07:00.0
           Card-2: Realtek RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller
           driver: r8169 v: 2.3LK-NAPI port: 3000 bus-ID: 08:00.0
korkmaz@korkmazPC ~ $ lspci -nnk | grep -iA2 net
07:00.0 Network controller [0280]: Broadcom Corporation BCM4313 802.11bgn Wireless Network Adapter [14e4:4727] (rev 01)
        DeviceName: Broadcom WLAN Valentine BCM94313HMGBLP1_802.11bgn 1x1 Combo HMC
        Subsystem: Hewlett-Packard Company BCM4313 802.11bgn Wireless Network Adapter [103c:1795]
        Kernel driver in use: bcma-pci-bridge
        Kernel modules: bcma
08:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller [10ec:8136] (rev 05)
        DeviceName: Realtek PCIe FE Family Controller
        Subsystem: Hewlett-Packard Company RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller [103c:183e]
        Kernel driver in use: r8169
        Kernel modules: r8169
korkmaz@korkmazPC ~ $ lsusb
Bus 002 Device 003: ID 064e:e289 Suyin Corp.
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 003: ID 0a5c:21e3 Broadcom Corp. HP Portable Valentine
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 003 Device 002: ID 24ae:2001
korkmaz@korkmazPC ~ $ rfkill list
0: phy0: Wireless LAN
        Soft blocked: no
        Hard blocked: no
1: hci0: Bluetooth
        Soft blocked: no
        Hard blocked: no
korkmaz@korkmazPC ~ $ sudo lshw -C network
[sudo] password for korkmaz:
  *-network
       description: Network controller
       product: BCM4313 802.11bgn Wireless Network Adapter
       vendor: Broadcom Corporation
       physical id: 0
       bus info: pci@0000:07:00.0
       version: 01
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list
       configuration: driver=bcma-pci-bridge latency=0
       resources: irq:16 memory:c3500000-c3503fff
  *-network
       product: RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller
       physical id: 0
       bus info: pci@0000:08:00.0
       logical name: eno1
       version: 05
       serial: 28:92:4a:40:fe:a5
       capacity: 100Mbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=rtl_nic/rtl8105e-1.fw latency=0 link=no multicast=yes port=MII speed=10Mbit/s
       resources: irq:27 ioport:3000(size=256) memory:c3404000-c3404fff memory:c3400000-c3403fff
  *-network
       physical id: 2
       logical name: wlp7s0b1
       serial: 84:4b:f5:76:a8:fa
       capabilities: ethernet physical wireless
       configuration: broadcast=yes driver=brcmsmac driverversion=4.4.0-21-generic firmware=610.812 ip=192.168.1.2 link=yes multicast=yes wireless=IEEE 802.11bgn
korkmaz@korkmazPC ~ $ iwconfig | grep Power
eno1      no wireless extensions.
          Bit Rate=2 Mb/s   Tx-Power=19 dBm
          Power Management:off
korkmaz@korkmazPC ~ $ lsmod
drbg                   32768  1
ansi_cprng             16384  0
ctr                    16384  2
ccm                    20480  2
rfcomm                 69632  14
uvcvideo               90112  0
snd_hda_codec_idt      57344  1
kvm_intel             172032  0
kvm                   536576  1 kvm_intel
videobuf2_v4l2         28672  1 uvcvideo
bluetooth             520192  39 bnep,btbcm,btrtl,btusb,rfcomm,btintel
snd_hda_codec_generic    77824  1 snd_hda_codec_idt
videobuf2_core         36864  2 uvcvideo,videobuf2_v4l2
snd_hda_intel          36864  3
v4l2_common            16384  1 videobuf2_v4l2
snd_hda_codec         135168  4 snd_hda_codec_hdmi,snd_hda_codec_idt,snd_hda_codec_generic,snd_hda_intel
videodev              176128  4 uvcvideo,v4l2_common,videobuf2_core,videobuf2_v4l2
brcmsmac              573440  0
snd_hda_core           73728  5 snd_hda_codec_hdmi,snd_hda_codec_idt,snd_hda_codec_generic,snd_hda_codec,snd_hda_intel
cordic                 16384  1 brcmsmac
brcmutil               16384  1 brcmsmac
media                  24576  2 uvcvideo,videodev
b43                   417792  0
snd_pcm               106496  4 snd_hda_codec_hdmi,snd_hda_codec,snd_hda_intel,snd_hda_core
mac80211              737280  2 b43,brcmsmac
aesni_intel           167936  4
cfg80211              565248  3 b43,brcmsmac,mac80211
ssb                    65536  1 b43
lrw                    16384  1 aesni_intel
snd_seq                69632  2 snd_seq_midi_event,snd_seq_midi
gf128mul               16384  1 lrw
bcma                   53248  3 b43,brcmsmac
ablk_helper            16384  1 aesni_intel
snd                    81920  17 snd_hwdep,snd_timer,snd_hda_codec_hdmi,snd_hda_codec_idt,snd_pcm,snd_seq,snd_rawmidi,snd_hda_codec_generic,snd_hda_codec,snd_hda_intel,snd_seq_device
rtsx_pci_ms            20480  0
cryptd                 20480  2 aesni_intel,ablk_helper
memstick               20480  1 rtsx_pci_ms
mei_me                 36864  0
mei                    98304  1 mei_me
hp_accel               28672  0
hp_wireless            16384  0
lis3lv02d              20480  1 hp_accel
input_polldev          16384  1 lis3lv02d
parport                49152  3 lp,ppdev,parport_pc
btrfs                 987136  0
raid6_pq              102400  1 btrfs
dm_region_hash         24576  1 dm_mirror
hid                   118784  2 hid_generic,usbhid
rtsx_pci_sdmmc         24576  0
amdkfd                122880  1
amd_iommu_v2           20480  1 amdkfd
psmouse               126976  0
radeon               1511424  1
i915                 1208320  8
i2c_algo_bit           16384  2 i915,radeon
ttm                    98304  1 radeon
rtsx_pci               53248  2 rtsx_pci_ms,rtsx_pci_sdmmc
drm_kms_helper        139264  2 i915,radeon
r8169                  81920  0
drm                   360448  13 ttm,i915,drm_kms_helper,radeon
ahci                   36864  1
wmi                    20480  1 hp_wmi
video                  40960  1 i915
« Son Düzenleme: 16 Aralık 2016, 18:03:40 Gönderen: korkmaz »
  • İleti: 1919
    • MintTurkiye
    • sametocean
  • İşlemci: Intel i7
Ynt: Wifi hız problemi
« Yanıtla #1 : 16 Aralık 2016, 13:55:46 »
Aşağıdaki komutla bcmwl-kernel-source paketini yükleyip sisteminizi yeniden başlatmayı deneyiniz.
sudo apt-get install bcmwl-kernel-source
Çevrimdışı korkmaz
  • İleti: 27
« Yanıtla #2 : 16 Aralık 2016, 18:03:16 »
Sorun çözüldü hocam teşekkürler
