Gönderen Konu: opera uç birimde hatalar  (Okunma sayısı 1896 defa)
Çevrimdışı lutfuarslan
  • İleti: 14
    • lutfuarslan
    • lutfuarslan
  • Dağıtım: linux mint 17.3
  • Masaüstü: cinnamon
  • Grafik Kartı: ati hd5670
  • İşlemci: e4600 core2duo 2.4ghz
« : 04 Aralık 2016, 22:56:08 »
lutfu@lutfu-G31M-ES2L ~ $ opera
[1204/234934:ERROR:object_proxy.cc(583)] Failed to call method: org.freedesktop.UPower.GetDisplayDevice: object_path= /org/freedesktop/UPower: org.freedesktop.DBus.Error.UnknownMethod: Method "GetDisplayDevice" with signature "" on interface "org.freedesktop.UPower" doesn't exist
[1204/234935:ERROR:sandbox_linux.cc(343)] InitializeSandbox() called with multiple threads in process gpu-process.
[1204/234935:ERROR:TextEncodingRegistry.cpp(144)] alias ISO-8859-8-I maps to ISO-8859-8-I already, but someone is trying to make it map to ISO-8859-8
[1204/234936:ERROR:TextEncodingRegistry.cpp(144)] alias ISO-8859-8-I maps to ISO-8859-8-I already, but someone is trying to make it map to ISO-8859-8
Çok ufak kesilmeler oluyor.  Youtube videolarında  eski sürüm bir Opera yükledim uç birimde hiç hata vermedi fakat oda videolarda çok kesik kesik.
Düzenleme: Kod etiketi ve imla
« Son Düzenleme: 05 Aralık 2016, 21:42:00 Gönderen: Reddet »
  • İleti: 1972
  • Dağıtım: Linux Mint 18.3
Ynt: opera uç birimde hatalar
« Yanıtla #1 : 06 Aralık 2016, 17:35:47 »
  • İleti: 14
    • lutfuarslan
    • lutfuarslan
« Yanıtla #2 : 06 Aralık 2016, 19:24:13 »
inxi -SGx
System:    Host: lutfu-G31M-ES2L Kernel: 3.19.0-32-generic i686 (32 bit gcc: 4.8.2)
           Desktop: Cinnamon 2.8.8 (Gtk 3.10.8~8+qiana)
           Distro: Linux Mint 17.3 Rosa
Graphics:  Card: Advanced Micro Devices [AMD/ATI] Redwood XT [Radeon HD 5670/5690/5730]
           bus-ID: 01:00.0
           Display Server: X.Org 1.17.1 drivers: ati,radeon (unloaded: fbdev,vesa)
           Resolution: 1920x1080@60.0hz
           GLX Renderer: Gallium 0.4 on AMD REDWOOD
OpenGL renderer string: Gallium 0.4 on AMD REDWOOD
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Redwood XT [Radeon HD 5670/5690/5730]
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 8192 x 8192
HDMI-0 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 477mm x 268mm
   1920x1080      60.0*+   50.0     59.9     30.0     25.0     24.0     30.0     24.0
   1920x1080i     60.1     50.0     60.0
   1680x1050      59.9
   1600x900       60.0
   1280x1024      75.0     60.0
   1440x900       59.9
   1366x768       59.8
   1280x800       59.9
   1152x864       75.0
   1280x720       60.0     50.0     59.9
   1024x768       75.1     70.1     60.0
   832x624        74.6
   800x600        72.2     75.0     60.3
   720x576        50.0
   720x576i       50.1
   720x480        60.0     59.9
   720x480i       60.1     60.1
   640x480        75.0     72.8     66.7     60.0     59.9
   720x400        70.1
DVI-0 disconnected (normal left inverted right x axis y axis)
VGA-0 disconnected (normal left inverted right x axis y axis)
ii  nvidia-prime-applet                         1.0.3                                               all          An applet for NVIDIA Prime
açık kaynak sürücüden flgrx e  geçiyorum yeniden başlattıgımda güvenli kipe geçiyor  komutla geçmeye çalıştığımda ise  eksik paketler var diyor bende yeniden format atıyorum birde youtube ana sayfasını bile açsam (tarayıcı farketmeden )cpu % 70 ve üstüne bile çıkabiliyor.
sudo apt-get install xserver-xorg-video-ati
Bazı paketler kurulamadı. Bu durum, olanaksız bir durum istemiş
olduğunuzu ya da kararsız (unstable) dağıtımı kullandığınızı ve
bazı paketlerin henüz oluşturulamamış  ya da oluşturulmakta
olduğunu gösterir.
Aşağıdaki bilgiler durumu çözmenize yardımcı olabilir:
Aşağıdaki paketler karşılanmamış bağımlılıklara sahip:
 xserver-xorg-video-ati : Bağımlılıklar: xorg-video-abi-15
                          Bağımlılıklar: xserver-xorg-core (>= 2:1.14.99.902)
                          Bağımlılıklar: xserver-xorg-video-glamoregl ama kurulmayacak
E: Sorunlar giderilemedi, tutulan bozuk paketleriniz var.
« Son Düzenleme: 07 Aralık 2016, 01:50:23 Gönderen: lutfuarslan »
  • İleti: 14321
« Yanıtla #3 : 07 Aralık 2016, 14:09:05 »
Sürücü Yöneticisini açıp fglrx-updates sürücüsünü kurmayı deneyebilirsiniz. Sonrasında sistemi yeniden başlatınız.
  • İleti: 14
    • lutfuarslan
    • lutfuarslan
« Yanıtla #4 : 07 Aralık 2016, 18:01:16 »
 ~ $ opera
[1207/184937:ERROR:object_proxy.cc(583)] Failed to call method: org.freedesktop.UPower.GetDisplayDevice: object_path= /org/freedesktop/UPower: org.freedesktop.DBus.Error.UnknownMethod: Method "GetDisplayDevice" with signature "" on interface "org.freedesktop.UPower" doesn't exist
[1207/184943:ERROR:TextEncodingRegistry.cpp(144)] alias ISO-8859-8-I maps to ISO-8859-8-I already, but someone is trying to make it map to ISO-8859-8
getrlimit(RLIMIT_NOFILE) failed
[1207/184945:ERROR:TextEncodingRegistry.cpp(144)] alias ISO-8859-8-I maps to ISO-8859-8-I already, but someone is trying to make it map to ISO-8859-8
flgrxe geçip yeniden başlattım  cpu çok yüksek youtubeda video açtıgımda %85-90 -95 değişiyor (tarayıcı değişmeksizin) ayrıca  görüntülerde bozulmalar oluyor. yatay şekilllerde dalgalanmalar var
chromium-browser
Using PPAPI flash.
[1:1:1207/185911:ERROR:TextEncodingRegistry.cpp(144)] alias ISO-8859-8-I maps to ISO-8859-8-I already, but someone is trying to make it map to ISO-8859-8
~ $ firefox
(firefox:3763): GLib-GObject-CRITICAL **: g_object_ref: assertion 'object->ref_count > 0' failed
(firefox:3763): GLib-GObject-CRITICAL **: g_object_unref: assertion 'object->ref_count > 0' failed
(/usr/lib/firefox/plugin-container:3797): GLib-GObject-CRITICAL **: g_object_ref: assertion 'object->ref_count > 0' failed
(/usr/lib/firefox/plugin-container:3797): GLib-GObject-CRITICAL **: g_object_unref: assertion 'object->ref_count > 0' failed
  • İleti: 14321
« Yanıtla #5 : 08 Aralık 2016, 13:23:51 »
@lutfuarslan , lütfen çıktıları kod etiketi içinde paylaşınız. İletilerde code Etiketi Kullanımı
fglrxinfo
inxi -SGx
  • İleti: 14
    • lutfuarslan
    • lutfuarslan
« Yanıtla #6 : 08 Aralık 2016, 16:09:45 »
~ $ fglrxinfo
display: :0  screen: 0
OpenGL vendor string: Advanced Micro Devices, Inc.
OpenGL renderer string: AMD Radeon HD 5670
OpenGL version string: 4.5.13399 Compatibility Profile Context 15.201.1151
~ $ glxinfo | grep render
    GL_KTX_buffer_region, GL_NV_blend_square, GL_NV_conditional_render,
~ $ inxi -SGx
           bus-ID: 01:00.0
           Display Server: X.Org 1.17.1 drivers: ati,fglrx (unloaded: fbdev,vesa,radeon)
           GLX Renderer: AMD Radeon HD 5670
           GLX Version: 4.5.13399 - CPC 15.201.1151 Direct Rendering: Yes
~ $ cat /etc/X11/xorg.conf
  • İleti: 14321
« Yanıtla #7 : 08 Aralık 2016, 16:18:42 »
Aşağıdaki komutla xorg.conf yapılandırma dosyasını otomatik olarak oluşturup sistemi yeniden başlatmayı deneyiniz. Bu yırtılma sorunlarını çözmek içinde tear free değişkenini ekleyecek komutu da barındırıyor.
sudo aticonfig --initial -f
sudo aticonfig --sync-video=on
Eğer aticonfig komutu bulunumadı şeklinde bir hata alırsanız aşağıdaki komutları denersiniz.
sudo amdconfig --initial -f
sudo amdconfig --sync-video=on
  • İleti: 14
    • lutfuarslan
    • lutfuarslan
« Yanıtla #8 : 08 Aralık 2016, 16:31:55 »
[sudo] password for lutfu:
Uninitialised file found, configuring.
Using /etc/X11/xorg.conf
Saving back-up to /etc/X11/xorg.conf.original-0
~ $ sudo aticonfig --sync-video=on
failed to set textured video sync
Warning: Option 'TexturedVideoSync' doesn't affect running session.
Saving back-up to /etc/X11/xorg.conf.fglrx-0
~ $ sudo amdconfig --sync-video=on
Saving back-up to /etc/X11/xorg.conf.fglrx-2
görüntüde bir düzelme yok ve youtube videolarda işlemci %90-95 lerde çalışmaya devam ediyor.
« Son Düzenleme: 08 Aralık 2016, 16:40:28 Gönderen: lutfuarslan »
  • İleti: 14321
« Yanıtla #9 : 08 Aralık 2016, 17:20:34 »
ATI kapalı kaynak sürücüler için aşağıdaki komutlarla Flash için donanımsal hızlandırmayı destekleyecek paketleri kurabilirsiniz.
sudo apt-get install xvba-va-driver libvdpau-va-gl1
sudo sh -c "echo 'export VDPAU_DRIVER=va_gl' >> /etc/profile"
sudo mkdir /etc/adobe
sudo echo -e "EnableLinuxHWVideoDecode = 1\nOverrideGPUValidation = 1" | sudo tee /etc/adobe/mms.cfg
Ardından sistemi yeniden başlatın.
Sonrasında Flash video üstüne sağ tıklayıp ayarları açın ve donanımsal hızlandırmayı etkinleştirin. İşlem sonrasında tarayıcıyı yeniden başlatmalısınız.
  • İleti: 14
    • lutfuarslan
    • lutfuarslan
« Yanıtla #10 : 08 Aralık 2016, 17:36:06 »
Dediklerinizi uyguladım hata almadım fakat görüntü bozukluğu  ve işlemciyi çok harcaması devam ediyor. ve firefox komple sistemi donduruyor mause bile çalışmıyor pcnin fişini çekiyorum firefox kullanmassam donma sorunu yok
sürücü yöneticisi ile fglrx updatesten sadece fglrx yazana geçtim firefoxu sildim görüntü diğer sürücüye göre daha iyi yine bozulmalar olsa bile onun kadar değil      işlemci youtube videolarda  çok yüksek çalışmaya devam ediyor.
bu konu kapanabilir çok teşekkür ederim
« Son Düzenleme: 10 Aralık 2016, 13:17:01 Gönderen: lutfuarslan »
