Gönderen Konu: [Çözüldü] Steam açılıyor fakat terminalde hatalar veriyor  (Okunma sayısı 2278 defa)
Çevrimdışı lutfuarslan
  • İleti: 14
    • lutfuarslan
  • Dağıtım: linux mint 17.3
  • Masaüstü: cinnamon
  • Grafik Kartı: ati hd5670
  • İşlemci: e4600 core2duo 2.4ghz
lutfu@lutfu-G31M-ES2L ~ $ steam
Running Steam on linuxmint 17.3 32-bit
STEAM_RUNTIME is enabled automatically
Installing breakpad exception handler for appid(steam)/version(1476379980)
Fontconfig error: "/etc/fonts/conf.d/10-scale-bitmap-fonts.conf", line 70: non-double matrix element
Fontconfig warning: "/etc/fonts/conf.d/10-scale-bitmap-fonts.conf", line 78: saw unknown, expected number
[1201/022220:ERROR:main_delegate.cc(779)] Could not load cef_extensions.pak
[1201/022220:ERROR:browser_main_loop.cc(217)] Running without the SUID sandbox! See https://chromium.googlesource.com/chromium/src/+/master/docs/linux_suid_sandbox_development.md for more information on developing with the sandbox on.
Installing breakpad exception handler for appid(steamwebhelper)/version(20161013004706)
Installing breakpad exception handler for appid(steamwebhelper)/version(1476319626)
Installing breakpad exception handler for appid(steamwebhelper)/version(1476379980)
Created shared memory when not owner SteamController_Shared_mem
Generating new string page texture 2: 48x256, total string texture memory is 49,15 KB
Generating new string page texture 3: 256x256, total string texture memory is 311,30 KB
roaming config store loaded successfully - 0 bytes.
Error: texture file 'graphics/avatarborderingame' does not exist or is invalid
Failed to init SteamVR because it isn't installed
Errors in servers/internetgamespage.res:
error loading file 'servers/internetgamespage.res', no such file
../vgui_surfacelib/FontManager.cpp (455) : Assertion Failed: font != vgui::INVALID_FONT
Assert( Assertion Failed: font != vgui::INVALID_FONT ):../vgui_surfacelib/FontManager.cpp:455
crash_20161201022224_18.dmp[19391]: Uploading dump (out-of-process)
/tmp/dumps/crash_20161201022224_18.dmp
ExecCommandLine: ""/home/lutfu/.local/share/Steam/ubuntu12_32/steam" "
System startup time: 4,47 seconds
Generating new string page texture 78: 1024x256, total string texture memory is 1,36 MB
Generating new string page texture 79: 128x256, total string texture memory is 131,07 KB
Generating new string page texture 80: 128x256, total string texture memory is 1,49 MB
Generating new string page texture 81: 64x256, total string texture memory is 1,56 MB
Generating new string page texture 82: 24x256, total string texture memory is 1,58 MB
Generating new string page texture 83: 32x256, total string texture memory is 1,61 MB
(steam:19337): LIBDBUSMENU-GLIB-WARNING **: Trying to remove a child that doesn't believe we're it's parent.
Generating new string page texture 87: 128x256, total string texture memory is 1,74 MB
Generating new string page texture 88: 256x256, total string texture memory is 2,01 MB
Generating new string page texture 90: 512x256, total string texture memory is 2,53 MB
Generating new string page texture 91: 384x256, total string texture memory is 2,92 MB
CAPIJobRequestUserStats - Server response failed 2
STEAM_RUNTIME has been set by the user to: /home/lutfu/.local/share/Steam/ubuntu12_32/steam-runtime
ExecCommandLine: "/home/lutfu/.local/share/Steam/ubuntu12_32/steam steam://open/driverhelperready"
ExecSteamURL: "steam://open/driverhelperready"
crash_20161201022224_18.dmp[19391]: Finished uploading minidump (out-of-process): success = yes
crash_20161201022224_18.dmp[19391]: response: CrashID=bp-e888bb7e-4dbf-45c0-bf74-54ed72161130
crash_20161201022224_18.dmp[19391]: file ''/tmp/dumps/crash_20161201022224_18.dmp'', upload yes: ''CrashID=bp-e888bb7e-4dbf-45c0-bf74-54ed72161130''
forumda araştıra araştıra başlangıç oluşturmayı denedim masaüstüne sonuç bu hatalar yok uçbirimde  sorun kalkmış gibi duruyor  ne dersiniz?
« Son Düzenleme: 01 Aralık 2016, 22:59:12 Gönderen: lutfuarslan »
  • İleti: 1022
Ynt: Steam açılıyor fakat terminalde hatalar veriyor
« Yanıtla #1 : 01 Aralık 2016, 18:12:44 »
LC_ALL=C steam komutu ile Steam'i açtığınızda durum ne oluyor?
  • İleti: 14
    • lutfuarslan
« Yanıtla #2 : 01 Aralık 2016, 18:28:41 »
lutfu@lutfu-G31M-ES2L ~ $ LC_ALL=C steam
Normal gözüküyor zaten küçük bir oyun yükledim açtım tşk
  • İleti: 1022
« Yanıtla #3 : 01 Aralık 2016, 21:27:36 »
Bende linkteki konuda belirtilen şekilde(son mesajlarda)başlatıcı ile kullanıyorum.
https://forum.linuxmint.net.tr/index.php?topic=5422.45
Eğer çalışıyorsa bu şekilde sorun yok.
Çözüldü etiketi ile konuyu kapatabilirsiniz.
  • İleti: 14
    • lutfuarslan
« Yanıtla #4 : 01 Aralık 2016, 22:58:57 »
başlatıcıya çift tıklayarak ve steam komutu ikisiyle de çalışıyor tşk
