Gönderen Konu: Linux Mint lisa 12 32 bit kurdum depo sorunu yaşıyorum.  (Okunma sayısı 2040 defa)
Çevrimdışı uyelik269
  • İleti: 2
  • Dağıtım: linux mint lisa
  • Masaüstü: lxde
Merhabalar,
Okulumuzdaki eski bilgisayara lxde masaüstü kurdum fakat depoları güncellediğimde veya paket yüklemek istediğimde aşağıdaki hatayı alıyorum. Öncelikli olarak b43 le başlayan wifi driverlerını kurmak istiyorum.Yardımcı olurasanız sevinirim.
Ignoring file 'local-repository.list.save' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extensionIgnoring file 'local-repository.list.save' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extensionGPG error: http://packages.medibuntu.org oneiric InRelease: File /var/lib/apt/lists/partial/packages.medibuntu.org_dists_oneiric_InRelease doesn't start with a clearsigned messageFailed to fetch gzip:/var/lib/apt/lists/partial/packages.medibuntu.org_dists_oneiric_free_binary-i386_Packages  Encountered a section with no Package: header
Failed to fetch gzip:/var/lib/apt/lists/partial/packages.medibuntu.org_dists_oneiric_non-free_binary-i386_Packages  Encountered a section with no Package: header
Failed to fetch http://packages.medibuntu.org/dists/oneiric/free/i18n/Index  No Hash entry in Release file /var/lib/apt/lists/partial/packages.medibuntu.org_dists_oneiric_free_i18n_Index
Failed to fetch http://packages.medibuntu.org/dists/oneiric/non-free/i18n/Index  No Hash entry in Release file /var/lib/apt/lists/partial/packages.medibuntu.org_dists_oneiric_non-free_i18n_Index
Failed to fetch http://archive.ubuntu.com/ubuntu/dists/oneiric/main/binary-i386/Packages  404  Not Found [IP: 91.189.88.162 80]
Failed to fetch http://archive.ubuntu.com/ubuntu/dists/oneiric/restricted/binary-i386/Packages  404  Not Found [IP: 91.189.88.162 80]
Failed to fetch http://archive.ubuntu.com/ubuntu/dists/oneiric/universe/binary-i386/Packages  404  Not Found [IP: 91.189.88.162 80]
Failed to fetch http://archive.ubuntu.com/ubuntu/dists/oneiric/multiverse/binary-i386/Packages  404  Not Found [IP: 91.189.88.162 80]
Failed to fetch http://security.ubuntu.com/ubuntu/dists/oneiric-security/main/binary-i386/Packages  404  Not Found [IP: 91.189.91.26 80]
Failed to fetch http://security.ubuntu.com/ubuntu/dists/oneiric-security/restricted/binary-i386/Packages  404  Not Found [IP: 91.189.91.26 80]
Failed to fetch http://security.ubuntu.com/ubuntu/dists/oneiric-security/universe/binary-i386/Packages  404  Not Found [IP: 91.189.91.26 80]
Failed to fetch http://security.ubuntu.com/ubuntu/dists/oneiric-security/multiverse/binary-i386/Packages  404  Not Found [IP: 91.189.91.26 80]
Failed to fetch http://archive.ubuntu.com/ubuntu/dists/oneiric-updates/main/binary-i386/Packages  404  Not Found [IP: 91.189.88.152 80]
Failed to fetch http://archive.ubuntu.com/ubuntu/dists/oneiric-updates/restricted/binary-i386/Packages  404  Not Found [IP: 91.189.88.152 80]
Failed to fetch http://archive.ubuntu.com/ubuntu/dists/oneiric-updates/universe/binary-i386/Packages  404  Not Found [IP: 91.189.88.152 80]
Failed to fetch http://archive.ubuntu.com/ubuntu/dists/oneiric-updates/multiverse/binary-i386/Packages  404  Not Found [IP: 91.189.88.152 80]
Some index files failed to download. They have been ignored, or old ones used instead.
Çevrimiçi Danny
  • İleti: 1992
Ynt: Linux Mint lisa 12 32 bit kurdum depo sorunu yaşıyorum.
« Yanıtla #1 : 22 Kasım 2016, 14:36:53 »
Linux Mint 12 sürümünün destek süresi sona ermiştir. 17 veya 18'inci sürümlerden LXDE olan birini indirip kurmalısınız.
  • İleti: 16239
« Yanıtla #2 : 22 Kasım 2016, 14:38:25 »
LXDE masaüstünü seviyorsanız/tercih ediyorsanız Peppermint'i deneyebilirsiniz.
https://peppermintos.com
  • İleti: 2
  • Masaüstü: lxde
« Yanıtla #3 : 22 Kasım 2016, 14:46:08 »
sevmek değilde mecburiyet diyelim linux mint resmi sayfasında 17 ve üzeri lxde sürüm bulamadım.
  • İleti: 991
« Yanıtla #4 : 22 Kasım 2016, 14:48:38 »
Zorin Os Lite,Lubuntu,Peppermint Os gibi nispeten hafif dagitimlari deneyin
  • İleti: 16239
« Yanıtla #5 : 22 Kasım 2016, 15:07:03 »
Linux Mint 12. sürümden itibaren Lxde ISO dosyaları yayınlanmadı. Peppermint, Linux Mint Lxde sürüme yakındır. Bir de Linux Mint Polonya topluluğundan @mati75'in hazırladığı resmi olmaya Linux Mint 17.1 Lxde ISO dosyaları var. Bu sürüm resmi değildir, topluluk üyelerinden birisi tarafından hazırlanmıştır.
https://sourceforge.net/projects/ulmlxde/files/17.1
