Gönderen Konu: [Çözüldü] Aşırı Isınma ve Fan Sorunu  (Okunma sayısı 2294 defa)
Çevrimdışı frigid
  • İleti: 5
  • Dağıtım: Mint 17.3
« : 29 Ağustos 2016, 22:11:24 »
Merhaba arkadaşlar, birkaç günlük linux mate 17.3 kullacısıyım.  Sistemi bilgisayara kurduktan sonra fanın, Win10'a göre,  biraz fazla ses çıkardığını düşünüp biraz araştırma yaptım.  Aşağıdaki başlıktaki işlemleri yaptıktan sonra hem sıcaklık hem de fan sesi daha da yükseldi diyebilirim.
https://forum.linuxmint.net.tr/index.php?topic=180.0
System:    Host: behic-HP-Pavilion-g6-Notebook-PC Kernel: 3.19.0-32-generic x86_64 (64 bit gcc: 4.8.2)
           Desktop: MATE 1.12.0 (Gtk 3.10.8~8+qiana) Distro: Linux Mint 17.3 Rosa
Machine:   System: Hewlett-Packard product: HP Pavilion g6 Notebook PC v: 0692120000204610000610100
           Mobo: Hewlett-Packard model: 1670 v: 09.49 Bios: Hewlett-Packard v: F.52 date: 11/28/2011
CPU:       Dual core Intel Core i5-2430M (-HT-MCP-) cache: 3072 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 9578
           clock speeds: max: 3000 MHz 1: 830 MHz 2: 1008 MHz 3: 1360 MHz 4: 829 MHz
Graphics:  Card-1: Intel 2nd Generation Core Processor Family Integrated Graphics Controller bus-ID: 00:02.0
           Card-2: Advanced Micro Devices [AMD/ATI] Seymour [Radeon HD 6400M/7400M Series] bus-ID: 01:00.0
           Display Server: X.Org 1.17.1 drivers: fglrx (unloaded: intel) Resolution: 1366x768@60.0hz
           GLX Renderer: AMD Radeon HD 7400M Series
           GLX Version: 4.5.13399 - CPC 15.201.1151 Direct Rendering: Yes
Audio:     Card Intel 6 Series/C200 Series Family High Definition Audio Controller
Network:   Card-1: Broadcom BCM4313 802.11bgn Wireless Network Adapter driver: bcma-pci-bridge bus-ID: 02:00.0
           Card-2: Realtek RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller
           driver: r8169 v: 2.3LK-NAPI port: 3000 bus-ID: 03:00.0
Drives:    HDD Total Size: 750.2GB (1.7% used) ID-1: /dev/sda model: TOSHIBA_MK7575GS size: 750.2GB
Partition: ID-1: / size: 682G used: 6.3G (1%) fs: ext4 dev: /dev/sda1
           ID-2: swap-1 size: 6.39GB used: 0.00GB (0%) fs: swap dev: /dev/sda5
Sensors:   System Temperatures: cpu: 83.0C mobo: N/A gpu: 81.50C
Info:      Processes: 183 Uptime: 1:49 Memory: 1027.3/5915.6MB Init: Upstart runlevel: 2 Gcc sys: 4.8.4
OpenGL renderer string: AMD Radeon HD 7400M Series
    GL_KTX_buffer_region, GL_NV_blend_square, GL_NV_conditional_render,
display: :0.0  screen: 0
OpenGL vendor string: Advanced Micro Devices, Inc.
OpenGL version string: 4.5.13399 Compatibility Profile Context 15.201.1151
01:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Seymour [Radeon HD 6400M/7400M Series]
« Son Düzenleme: 30 Ağustos 2016, 12:07:52 Gönderen: frigid »
  • İleti: 16484
Ynt: Aşırı Isınma ve Fan Sorunu
« Yanıtla #1 : 29 Ağustos 2016, 22:44:21 »
Önce aşağıdaki komutu uçbirimde çalıştırarak Intel GPU'ya geçiş yapınız, Intel GPU gündelik işlerinizi görmek için yeterli olacaktır.
sudo aticonfig --px-igpu
Intel GPU'ya geçince sorun yaşarsanız buradaki fglrx/fglrx-updates sürücüsü kurulumu sonrasındaki adımları uygularsınız.
Ayrıca burada anlatıldığı biçimde TLP güç yönetimi uygulamasını kurup yapılandırmayı deneyebilirsiniz.
Çevrimdışı frigid
  • İleti: 5
« Yanıtla #2 : 29 Ağustos 2016, 23:20:50 »
Komutu yazdığımda şöyle bir çıktı aldım.
sudo: aticonfig: command not found
  • İleti: 16484
« Yanıtla #3 : 30 Ağustos 2016, 11:58:35 »
Bağlantıdaki komutlarda aticonfig yazan yerlere, bunun yerine amdconfig yazmayı deneyiniz.
Çevrimdışı frigid
  • İleti: 5
« Yanıtla #4 : 30 Ağustos 2016, 12:06:46 »
Dün gece çözüm ararken sanırım yanlış bir şeyler yaptım. Bilgisayarı yeniden başlattığımda bir türlü açılmadı. Ben de tekrardan kurulum yaptım. Ondan sonra yukarıda vermiş olduğunuz çözümleri uyguladım. Şu an fan normal çalışıyor, bilgisayar eskisi kadar ısınmıyor. Yardım için çok teşekkürler.
