Gönderen Konu: görsel kipte çalışma sorunu  (Okunma sayısı 1024 defa)
Çevrimdışı mehmethanifi
  • İleti: 740
  • Grafik Kartı: atı radeon
  • İşlemci: i5
« : 25 Mart 2016, 15:38:17 »
Merhabalar,
Bir bilgisayara linux mint  17.3 cinnamon kurdum. Kurulum sonunda bilgisayar görsel kipte açıldı. Sanırım ekran kartı yüklü değil.
Ekran kartı çıktıları aşağıda ki gibidir.
inxi -SGx
System:    Host: kalitecontrol Kernel: 3.19.0-32-generic i686 (32 bit gcc: 4.8.2)
           Desktop: Cinnamon 2.8.6 (Gtk 3.10.8~8+qiana)
           Distro: Linux Mint 17.3 Rosa
Graphics:  Card: VIA CN896/VN896/P4M900 [Chrome 9 HC] bus-ID: 01:00.0
           Display Server: X.Org 1.17.1 drivers: openchrome (unloaded: fbdev,vesa)
           Resolution: 1440x900@59.9hz
           GLX Renderer: Gallium 0.4 on llvmpipe (LLVM 3.6, 128 bits)
    GLX_MESA_query_renderer, GLX_OML_swap_method, GLX_SGIS_multisample,
OpenGL renderer string: Gallium 0.4 on llvmpipe (LLVM 3.6, 128 bits)
01:00.0 VGA compatible controller: VIA Technologies, Inc. CN896/VN896/P4M900 [Chrome 9 HC] (rev 01)
Screen 0: minimum 320 x 200, current 1440 x 900, maximum 2047 x 2047
VGA-1 connected primary 1440x900+0+0 (normal left inverted right x axis y axis) 408mm x 255mm
   1440x900       59.9*+   75.0
   1280x1024      75.0     60.0
   1280x800       59.8
   1152x864       75.0
   1024x768       75.0     70.1     60.0
   832x624        74.6
   800x600        72.2     75.0     60.3     56.2
   640x480        75.0     72.8     66.7     59.9
   720x400        70.1
dpkg -l | grep fglrx  (bu komutun çıktısı yok)
inxi -Fx
Machine:   System: MSI product: MS-7255 v: 2.0
           Mobo: Micro-Star model: MS-7255 v: 2.0
           Bios: American Megatrends v: V5.6 date: 10/24/2007
CPU:       Single core Intel Celeron 430 (-UP-) cache: 512 KB
           flags: (lm nx pae sse sse2 sse3 ssse3) bmips: 3599 speed: 1799 MHz (max)
Audio:     Card VIA VT8237A/VT8251 HDA Controller
           driver: snd_hda_intel bus-ID: 80:01.0
Network:   Card: VIA VT6102 [Rhine-II]
           driver: via-rhine port: d000 bus-ID: 00:12.0
           IF: eth0 state: unknown speed: 100 Mbps duplex: full
           mac: 00:1d:92:26:a0:cd
Drives:    HDD Total Size: 120.0GB (4.6% used)
           ID-1: /dev/sda model: ESA3SME2HTMTT120 size: 120.0GB temp: 30C
Partition: ID-1: / size: 109G used: 4.3G (5%) fs: ext4 dev: /dev/sda1
           ID-2: swap-1 size: 1.00GB used: 0.08GB (8%) fs: swap dev: /dev/sda5
Sensors:   System Temperatures: cpu: 86.0C mobo: N/A
Info:      Processes: 134 Uptime: 14 min Memory: 638.6/935.9MB
Teşekkürler.
« Son Düzenleme: 25 Mart 2016, 15:45:01 Gönderen: mehmethanifi »
  • İleti: 16938
Ynt: görsel kipte çalışma sorunu
« Yanıtla #1 : 25 Mart 2016, 16:11:41 »
Bu GPU'nun Linux için 3D hızlandırma desteği mevcut değil. Bu sebeple 2D ortam olam MATE ya da Xfce sürümü kurmanız daha uygun olur.
  • İleti: 740
  • İşlemci: i5
« Yanıtla #2 : 25 Mart 2016, 16:13:29 »
xfce yi kuralım hocam o vakit.
Teşekkürler.
