Gönderen Konu: Tarama sorunu HP LaserJet M1212NF  (Okunma sayısı 5872 defa)
Çevrimdışı gokhansiz
  • İleti: 11
  • Dağıtım: evet
Ynt: Tarama sorunu HP LaserJet M1212NF
« Yanıtla #15 : 29 Haziran 2015, 13:57:39 »
Swingsane uygulamasında yazıcıyı göremedim ...
  • İleti: 1973
« Yanıtla #16 : 29 Haziran 2015, 16:38:11 »
scanimage -T çıktısına bakabilir miyiz?
  • İleti: 11
  • Dağıtım: evet
« Yanıtla #17 : 30 Haziran 2015, 14:04:06 »
scanimage -T
MIB search path: /home/a/.snmp/mibs:/usr/share/snmp/mibs:/usr/share/snmp/mibs/iana:/usr/share/snmp/mibs/ietf:/usr/share/mibs/site:/usr/share/snmp/mibs:/usr/share/mibs/iana:/usr/share/mibs/ietf:/usr/share/mibs/netsnmp
Cannot find module (UCD-DLMOD-MIB): At line 1 in (none)
Cannot find module (MTA-MIB): At line 1 in (none)
Cannot find module (NETWORK-SERVICES-MIB): At line 1 in (none)
Cannot find module (UCD-DISKIO-MIB): At line 1 in (none)
Cannot find module (LM-SENSORS-MIB): At line 1 in (none)
Cannot find module (HOST-RESOURCES-MIB): At line 1 in (none)
Cannot find module (HOST-RESOURCES-TYPES): At line 1 in (none)
Cannot find module (SNMPv2-MIB): At line 1 in (none)
Cannot find module (IF-MIB): At line 1 in (none)
Cannot find module (IP-MIB): At line 1 in (none)
Cannot find module (TCP-MIB): At line 1 in (none)
Cannot find module (UDP-MIB): At line 1 in (none)
Cannot find module (NOTIFICATION-LOG-MIB): At line 1 in (none)
Cannot find module (DISMAN-EVENT-MIB): At line 1 in (none)
Cannot find module (DISMAN-SCHEDULE-MIB): At line 1 in (none)
Cannot find module (UCD-SNMP-MIB): At line 1 in (none)
Cannot find module (UCD-DEMO-MIB): At line 1 in (none)
Cannot find module (SNMP-TARGET-MIB): At line 1 in (none)
Cannot find module (NET-SNMP-AGENT-MIB): At line 1 in (none)
Cannot find module (SNMP-MPD-MIB): At line 1 in (none)
Cannot find module (SNMP-USER-BASED-SM-MIB): At line 1 in (none)
Cannot find module (SNMP-FRAMEWORK-MIB): At line 1 in (none)
Cannot find module (SNMP-VIEW-BASED-ACM-MIB): At line 1 in (none)
Cannot find module (SNMP-COMMUNITY-MIB): At line 1 in (none)
Cannot find module (IPV6-ICMP-MIB): At line 1 in (none)
Cannot find module (IPV6-MIB): At line 1 in (none)
Cannot find module (IPV6-TCP-MIB): At line 1 in (none)
Cannot find module (IPV6-UDP-MIB): At line 1 in (none)
Cannot find module (IP-FORWARD-MIB): At line 1 in (none)
Cannot find module (NET-SNMP-PASS-MIB): At line 1 in (none)
Cannot find module (NET-SNMP-EXTEND-MIB): At line 1 in (none)
Cannot find module (SNMP-NOTIFICATION-MIB): At line 1 in (none)
Cannot find module (SNMPv2-TM): At line 1 in (none)
Cannot find module (NET-SNMP-VACM-MIB): At line 1 in (none)
scanimage: open of device hpaio:/net/HP_LaserJet_Professional_M1212nf_MFP?ip=192.168.10.13 failed: Error during device I/O
  • İleti: 1973
« Yanıtla #18 : 30 Haziran 2015, 20:29:00 »
hp-checkçıktısını paylaşabilir misiniz? Bu çıktı uzun olacağından paste2.org gibi bir site kullanabilirsiniz.
hp-scan komutunu verince tarama yapıyor mu peki?
Yazıcıyı kaldırıp tekrar kurmak denenebilir.
Yazıcıları silmek için bu komutu veriniz:
hp-setup -rHplip eklentisi kurmak için bu komutu veriniz. Açılan pencerede ilk seçenekle kuruluma devam ediniz.:
su -c "hp-plugin"Kurulumu yapmak için bu komutu verin.Açılan pencerede yazıcınızı bağlama yöntemini seçiniz. Sanırım yazıcıyı ağdan bağlanıyorsunuz:
hp-setup
  • İleti: 11
  • Dağıtım: evet
« Yanıtla #19 : 01 Temmuz 2015, 10:32:22 »
Öncelikle,
hp-check
http://paste2.org/3VE8HkVe
hp-scankomutu ile tarama yapılıyor. Bu komutla işimiz görülebilir.
Yazıcıyı kaldırıp tekrar kurmaya gerek varmı ?
- Yazıcıları silmek için bu komutu veriniz: - => silme konutunu göremedim ..
evet ağ üzerinden yazıcıya bağlanıyorum.
Teşekkürler.
  • İleti: 16273
« Yanıtla #20 : 01 Temmuz 2015, 10:40:38 »
hp-setup -r
Çevrimdışı Trpser
  • İleti: 45
  • Dağıtım: Linux Mint 17.3 x64
« Yanıtla #21 : 07 Ağustos 2015, 19:21:21 »
Ben defalarca denememe rağmen basit taramayla hiçbir zaman m1212nf  kullanarak tarama yapamadım.Onun yerine hplip kullanıyorum.  http://hplipopensource.com/hplip-web/index.html adresinden indirebilirsiniz.Kurulum için cd komutu ile terminali indirdiğiniz dizinde çalıştırın.(indirdiğiniz dizini açıp boş bir yere sağ tıklayıp burada uçbirimi aç a tıklayarak da yapabilirsiniz)
sh hplip-3.15.7.run komutunu çalıştırın.Eğer linux mint 17.2 kullanıyorsanız desteklenmediğine dair uyarabilir.Yine de devam edin.
Press 'y' to continue auto installation. Press 'n' to quit auto instalation(y=yes, n=no*)  yazısı çıkınca "y" tuşuna basın ve enter tuşuna basın.
Please choose the installation mode  Yazdığında "a" tuşuna basın.
   Linux mint versiyonunuzun orada yazan olup olmadığını soracak.Evetse "y" hayırsa "n" tuşuna basın.
   Root şifrenizi soracak.
   Şifreyi girdikten sonra
Please read the installation notes. Press <enter> to continue or 'q' to quit: yazacak.Enter tuşuna basın.
Do you want to install these missing dependencies (y=yes*, n=no, q=quit) ? yaznca y tuşuna basın. Bu aşamada yüklemeyi yapmak için bekletecek.
Do you want to check for HPLIP updates?. (y=yes*, n=no) Yazınca "n" tuşuna basın.
Restart or re-plug in your printer (r=restart, p=re-plug in*, i=ignore/continue, q=quit) Yazdığında yazıcı usb ile bağlıysa kabloyu çıkarıp takın ve yazıcıyı kapatıp açın.Ağ ile bağlıysa sadece kapatıp açın.
   Yazıcı tam açılınca "i" tuşuna basın.
Do you want to setup printer in GUI mode? (u=GUI mode*, i=Interactive mode)  yazınca "i" tuşuna basın.
   Tekrar şifrenizi soracak.
Enter number 0...1 for connection type (q=quit, enter=usb*) ? yazısı geldiğinde eğer cihaz usb ile bağlı ise "0"a ağ ile bağlıysa "1"e basın. Siz ağ ile kullandığınız için ağ ile devam edeceğim.Bende hata verdi.Bu yüzden panelin sağına gelen hp logosuna tıklayarak anlatacağım.Sizde hata vermezse oradaki soruları cevaplayın veya terminalden çıkıp anlatacağım şekilde hp logosuna tıklayarak devam edin.
   Çıkan ekranda setup device ye tıklayın.Oradan ağ için network ile başlayanı,usb için universal ile başlayanı seçip show advanced options a basın.Manual discovery i işaretleyin.Altında çıkan yere yazıcının ekranında ağa bağlanınca yazan numarayı noktalarla birlikte yazın.Next e tıklayın.Yzıcınızı seçerek devam edin.Üstteki download ile başlayanı işaretleyip next e tıklayın.I agree ile başlayan yeri işaretleyip next e basın.Tekrar şifrenizi soracak.Ekrana bir yazı gelecek.OK a tıklayın.Add printera basın.Kurulum bitti.
Taramak için soldaki şeritten parantez içinde printer yazana tıklayın.Ekrana scan seçeneği gelecek.Ona tıklayın.3 tane pencere açılacak.ADF yazan yeri öyle bırakırsanız yazıcının üstündeki kağıt yerine konulan kağıdı tarar.Flatbed e çevirirseniz kapağı açılan yere konulan kağıdı tarar.Ayarlamayı yapınca scan a basın.Panelin sağındaki hp logosu giderse menüdeki arama yerine xsane yazarak tarama programını çalıştırabilirsiniz.
