Merhaba , sanıyorum ki herhangi bir sorun yok.Sürücü güncellemesi ile bumblebee çalışır duruma geldi.Çünkü opiturun -vvv glxgears olumlu yanıt veriyor.Bir de siz göz atarsanız sevinirim.
hwpplayer1[member=612]hwpplayer1[/member]-Aspire-V3-772G:~ > optirun -vvv glxgears
[ 5261.456127] [DEBUG]Reading file: /etc/bumblebee/bumblebee.conf
[ 5261.456274] [INFO]Configured driver: nvidia
[ 5261.456358] [DEBUG]optirun version 3.2.1 starting...
[ 5261.456365] [DEBUG]Active configuration:
[ 5261.456367] [DEBUG] bumblebeed config file: /etc/bumblebee/bumblebee.conf
[ 5261.456379] [DEBUG] X display: :8
[ 5261.456381] [DEBUG] LD_LIBRARY_PATH: /usr/lib/nvidia-346:/usr/lib32/nvidia-346
[ 5261.456383] [DEBUG] Socket path: /var/run/bumblebee.socket
[ 5261.456384] [DEBUG] Accel/display bridge: auto
[ 5261.456386] [DEBUG] VGL Compression: proxy
[ 5261.456387] [DEBUG] VGLrun extra options:
[ 5261.456389] [DEBUG] Primus LD Path: /usr/lib/x86_64-linux-gnu/primus:/usr/lib/i386-linux-gnu/primus
[ 5261.456406] [DEBUG]Using auto-detected bridge virtualgl
[ 5262.795029] [INFO]Response: Yes. X is active.
[ 5262.795051] [INFO]Running application using virtualgl.
[ 5262.795195] [DEBUG]Process vglrun started, PID 12676.
11944 frames in 5.0 seconds = 2388.772 FPS
12394 frames in 5.0 seconds = 2478.689 FPS
12594 frames in 5.0 seconds = 2518.771 FPS
12356 frames in 5.0 seconds = 2471.134 FPS
12555 frames in 5.0 seconds = 2510.965 FPS
12572 frames in 5.0 seconds = 2514.202 FPS
^C[ 5293.696635] [WARN]Received Interrupt signal.
[ 5293.696692] [DEBUG]Socket closed.
[ 5293.711293] [DEBUG]SIGCHILD received, but wait failed with No child processes
[ 5293.711343] [DEBUG]Socket closed.
[ 5293.711352] [DEBUG]Killing all remaining processes.
hwpplayer1[member=612]hwpplayer1[/member]-Aspire-V3-772G:~ > cat /etc/bumblebee/bumblebee.conf
# to take effect.
[bumblebeed]
VirtualDisplay=:8
KeepUnusedXServer=false
ServerGroup=bumblebee
# server exits.
TurnCardOffAtExit=false
# be ignored.
NoEcoModeOverride=false
Driver=nvidia
[optirun]
# primus.
Bridge=auto
VGLTransport=proxy
# the primus bridge
# is not available?
AllowFallbackToIGC=false
# bbswitch - new in BB 3, recommended if available
# switcheroo - vga_switcheroo method, use at your own risk
# none - disable PM completely
[driver-nvidia]
KernelDriver=nvidia-346
PMMethod=auto
LibraryPath=/usr/lib/nvidia-346:/usr/lib32/nvidia-346
# default Xorg modules path
XorgModulePath=/usr/lib/nvidia-346/xorg,/usr/lib/xorg/modules
[driver-nouveau]
KernelDriver=nouveau
PMMethod=auto
hwpplayer1[member=612]hwpplayer1[/member]-Aspire-V3-772G:~ > cat /etc/bumblebee/xorg.conf.nvidia
Section "ServerLayout"
Identifier "Layout0"
Option "AutoAddDevices" "false"
Option "AutoAddGPU" "false"
Identifier "DiscreteNvidia"
Driver "nvidia"
VendorName "NVIDIA Corporation"
# If the X server does not automatically detect your VGA device,
# you can manually set it here.
# To get the BusID prop, run `lspci | egrep 'VGA|3D'` and input the data
# as you see in the commented example.
# This Setting may be needed in some platforms with more than one
# nvidia card, which may confuse the proprietary driver (e.g.,
# trying to take ownership of the wrong device). Also needed on Ubuntu 13.04.
BusID "PCI:01:00:0"
# Setting ProbeAllGpus to false prevents the new proprietary driver
# instance spawned to try to control the integrated graphics card,
# which is already being managed outside bumblebee.
# This option doesn't hurt and it is required on platforms running
# more than one nvidia graphics card with the proprietary driver.
# (E.g. Macbook Pro pre-2010 with nVidia 9400M + 9600M GT).
# If this option is not set, the new Xorg may blacken the screen and
# render it unusable (unless you have some way to run killall Xorg).
Option "ProbeAllGpus" "false"
Option "NoLogo" "true"
Option "UseEDID" "false"
hwpplayer1[member=612]hwpplayer1[/member]-Aspire-V3-772G:~ > cat /etc/X11/xorg.conf
hwpplayer1[member=612]hwpplayer1[/member]-Aspire-V3-772G:~ > dpkg -l | egrep 'nvidia|bumblebee|primus|prime'
ii bumblebee 3.2.1-90~trustyppa1 amd64 NVIDIA Optimus support
ii bumblebee-nvidia 3.2.1-90~trustyppa1 amd64 NVIDIA Optimus support using the proprietary NVIDIA driver
rc nvidia-331 331.113-0ubuntu0.0.4 amd64 NVIDIA binary driver - version 331.113
ii nvidia-346 346.47-0ubuntu4~xedgers14.04.1 amd64 NVIDIA binary driver - version 346.47
ii nvidia-common 1:0.2.91.4linuxmint1 amd64 transitional package for ubuntu-drivers-common
ii nvidia-settings 346.47-0ubuntu1~xedgers14.04.1 amd64 Tool for configuring the NVIDIA graphics driver
ii primus 20131127-1~trustyppa1 amd64 client-side GPU offloading for NVIDIA Optimus
ii primus-libs:amd64 20131127-1~trustyppa1 amd64 Shared libraries for primus
hwpplayer1[member=612]hwpplayer1[/member]-Aspire-V3-772G:~ > lspci | egrep 'VGA|3D|Display'
00:02.0 VGA compatible controller: Intel Corporation 4th Gen Core Processor Integrated Graphics Controller (rev 06)
01:00.0 3D controller: NVIDIA Corporation GK107M [GeForce GT 750M] (rev ff)
