Gönderen Konu: Linuxa geçmekle doğru mu yaptım ?  (Okunma sayısı 2947 defa)
Çevrimdışı PrisonerMacTavish
  • İleti: 5
  • Grafik Kartı: VIA/S3G UniChrome Pro IGP
  • İşlemci: Intel Celeron 2.13ghz
« : 17 Ekim 2014, 16:37:16 »
Bilgisayarımı daha hızlı bir şekilde kullanmayı amaçlayarak Linux Mint 17 yi kurdum fakat bilgisayar hem açılırken hem de kullanırken oldukça yavaş sizce bunun bir çözümü var mıdır? Linux kullanmayı bırakmalı mıyım?
Uçbirime bunları
dpkg -l | grep flash
inxi -Fx
yazdığımda da karşıma bunlar çıktı.
System:    Host: ulu-P4VM800 Kernel: 3.13.0-24-generic i686 (32 bit, gcc: 4.8.2) Desktop: N/A Distro: Linux Mint 17 Qiana
Machine:   Mobo: N/A model: P4VM800 version: 1.00 Bios: American Megatrends version: P1.50 date: 02/14/2006
CPU:       Single core Intel Celeron CPU (-UP-) cache: 256 KB flags: (sse sse2 sse3) bmips: 4266.87 clocked at 2133.436 MHz
Graphics:  Card: VIA CN700/P4M800 Pro/P4M800 CE/VN800 Graphics [S3 UniChrome Pro] bus-ID: 01:00.0
           X.Org: 1.15.1 drivers: openchrome (unloaded: fbdev,vesa) Resolution: 1280x1024@60.0hz
           GLX Renderer: Gallium 0.4 on llvmpipe (LLVM 3.4, 128 bits) GLX Version: 2.1 Mesa 10.1.0 Direct Rendering: Yes
Audio:     Card: VIA VT8233/A/8235/8237 AC97 Audio Controller driver: snd_via82xx port: d000 bus-ID: 00:11.5
           Sound: Advanced Linux Sound Architecture ver: k3.13.0-24-generic
Network:   Card-1: VIA VT6102 [Rhine-II] driver: via-rhine port: d400 bus-ID: 00:12.0
           IF: eth0 state: down mac: 00:13:8f:92:84:5c
           Card-2: ZyXEL NWD271N 802.11n Wireless Adapter [Atheros AR9001U-(2)NG] driver: carl9170 usb-ID: 0586:3417
           IF: wlan0 state: up mac: 00:23:f8:19:57:78
Drives:    HDD Total Size: 80.1GB (6.8% used) 1: id: /dev/sda model: SAMSUNG_SP0822N size: 80.1GB
Partition: ID: / size: 19G used: 5.1G (30%) fs: ext4 ID: swap-1 size: 1.27GB used: 0.01GB (1%) fs: swap
Sensors:   None detected - is lm-sensors installed and configured?
Info:      Processes: 147 Uptime: 1:33 Memory: 465.3/1191.8MB Runlevel: 2 Gcc sys: 4.8.2 Client: Shell inxi: 1.8.4
Oldukça acemiyim bu yüzden yardımlarınızı bekliyoru  :)
  • İleti: 16851
Ynt: Linuxa geçmekle doğru mu yaptım ?
« Yanıtla #1 : 17 Ekim 2014, 17:19:01 »
Hangi sürümü (Mate, XFCE) kullanıyorsunuz?
  • İleti: 5
« Yanıtla #2 : 17 Ekim 2014, 20:17:48 »
İlginiz için teşekkürler Mate sürümünü kullanıyorum.
  • İleti: 5
« Yanıtla #3 : 17 Ekim 2014, 20:52:55 »
Hocam kubuntu mu kursam ya da daha düşük sistem gereksinimi isteyen bir dağıtım? Takılmaların sorunu ekran kartı diye düşünüyorum ama mutlaka bir çözümü de vardır.
Düzenleme: Mesajlar birleştirildi.
Lütfen peşpeşe mesaj göndermek yerine önceki mesajını düzenlemeyi deneyiniz.
« Son Düzenleme: 17 Ekim 2014, 21:11:37 Gönderen: Butterfly »
  • İleti: 16851
« Yanıtla #4 : 17 Ekim 2014, 21:10:36 »
Aşağıdaki komutu uçbirimde çalıştınız.
sudo pluma /etc/X11/xorg.conf
Açılan metin düzenleyiciye aşağıdaki satırları yapıştırıp dosyayı kaydedin ve sisteminizi yeniden başlatmayı deneyiniz.
        Identifier "Configured Video Device"
        Driver "openchrome"
Section "Module"
        Load  "dri"
  • İleti: 5
« Yanıtla #5 : 17 Ekim 2014, 22:50:25 »
        Driver "openchrome"
Section "Module"
        Load  "dri"
Teşekkürler gözle görülür bir fark oldu ama yine de xpden yavaş :-\
  • İleti: 16851
« Yanıtla #6 : 18 Ekim 2014, 08:48:32 »
Daha az sistem kaynağı kullanan ve daha hızlı bir sistem arıyorsanız XFCE sürümü kullanmalısınız. Öncesinde burada anlatıldığı biçimde sisteminizi güncellemeyi deneyebilisiniz.
Çevrimdışı Eludecraft
  • İleti: 197
  • Dağıtım: OpenSuSE/Chakra
  • Masaüstü: KDE
« Yanıtla #7 : 18 Ekim 2014, 12:26:11 »
Başka dağıtım kurman belki işe yarayabilir ama Kubuntu'nun kullandığı KDE'nin Mate'den daha fazla kaynak tüketeceği aşikar. :)
Çalışan sistemi bozmayacaksın ağa
