Gönderen Konu: LİnuxMint ve Windows10'un ses kartının ortak paylaşılamaması  (Okunma sayısı 246 defa)
Çevrimdışı messett
  • İleti: 22
  • Dağıtım: linux mint
  • Masaüstü: cinnamon
  • Grafik Kartı: Nvidia Geforce 940m
  • İşlemci: İntel core i5-6200
  • RAM: 4 GB
Merhaba, sorun şöyle ki; Windows10(pro 64 bit) ve LinuxMİNT (19.01 Cinnamon -64 bit) kullanıyorum. Ses kartını Windows10'un kullanması sonucu LinuxMİNT'den ses alamıyorum.
inxi -SMAxx
System:    Host: firat-X555UB Kernel: 4.15.0-48-generic x86_64 bits: 64 compiler: gcc v: 7.3.0
           Desktop: Cinnamon 4.0.10 wm: muffin dm: LightDM Distro: Linux Mint 19.1 Tessa
           base: Ubuntu 18.04 bionic
Machine:   Type: Laptop System: ASUSTeK product: X555UB v: 1.0 serial: <root required>
           Mobo: ASUSTeK model: X555UB v: 1.0 serial: <root required>
           UEFI: American Megatrends v: X555UB.301 date: 02/20/2017
Audio:     Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK driver: snd_hda_intel
           v: kernel bus ID: 00:1f.3 chip ID: 8086:9d70
           Sound Server: ALSA v: k4.15.0-48-generic
cat /proc/asound/card0/codec#* | grep Codec
Codec: Realtek ALC256
Codec: Intel Skylake HDMI
cat /proc/asound/modules
0 snd_hda_intel
lsmod | grep snd
snd_soc_skl            90112  0
snd_soc_skl_ipc        65536  1 snd_soc_skl
snd_hda_ext_core       24576  1 snd_soc_skl
snd_soc_sst_dsp        32768  1 snd_soc_skl_ipc
snd_soc_sst_ipc        16384  1 snd_soc_skl_ipc
snd_soc_acpi           16384  1 snd_soc_skl
snd_soc_core          241664  1 snd_soc_skl
snd_compress           20480  1 snd_soc_core
ac97_bus               16384  1 snd_soc_core
snd_pcm_dmaengine      16384  1 snd_soc_core
snd_hda_intel          40960  3
snd_hda_codec         126976  4 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec_realtek
snd_hda_core           81920  7 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_ext_core,snd_hda_codec,snd_hda_codec_realtek,snd_soc_skl
snd_pcm                98304  8 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_ext_core,snd_hda_codec,snd_soc_core,snd_soc_skl,snd_hda_core,snd_pcm_dmaengine
snd                    81920  19 snd_hda_codec_generic,snd_seq,snd_seq_device,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek,snd_timer,snd_compress,snd_soc_core,snd_pcm,snd_rawmidi
aplay -l
**** PLAYBACK Donanım Aygıtlarının Listesi ****
kart 0: PCH [HDA Intel PCH], aygıt 0: ALC256 Analog [ALC256 Analog]
  Altaygıtlar: 1/1
  Altaygıt #0: subdevice #0
kart 0: PCH [HDA Intel PCH], aygıt 3: HDMI 0 [HDMI 0]
  Altaygıtlar: 1/1
kart 0: PCH [HDA Intel PCH], aygıt 7: HDMI 1 [HDMI 1]
  Altaygıtlar: 1/1
kart 0: PCH [HDA Intel PCH], aygıt 8: HDMI 2 [HDMI 2]
  Altaygıtlar: 1/1
kart 0: PCH [HDA Intel PCH], aygıt 9: HDMI 3 [HDMI 3]
  Altaygıtlar: 1/1
kart 0: PCH [HDA Intel PCH], aygıt 10: HDMI 4 [HDMI 4]
  Altaygıtlar: 1/1
pulseaudio --start
N: [pulseaudio] main.c: Kullanıcı tarafından yapılandırılmış, yerel olarak görülen şuradaki sunucu: {82929df7ee394b73b81252fe3b4e5020}unix:/run/user/1000/pulse/native.
pulseaudio --start sonucu çıkan çıktı yukarıda belirtildiği gibi fakat dosyayı açamadım. Ek olarak ise pavucontrol, alsamixer, kmixer veya driverı silip tekrar kurmak dahil hepsini denedim sanırım sorun Windows10 ile ilişikli.
Herkese teşekkürler şimdiden
« Son Düzenleme: 27 Nisan 2019, 16:25:12 Gönderen: messett »
  • İleti: 16939
Windows'u tam olarak kapatıp, Linux Mint'i bu şekilde açmayı deneyin. Eğer gerçekten Windows hazırda bekletme ile alakalı ise teyit etmiş olursunuz.
Çevrimdışı messett
  • İleti: 22
  • RAM: 4 GB
Windows10 kendini bekleme moduna aldığından dolayı hızlı başlatmayı devredışı bıraktım  :) nadiren LinuxMİNT'den ses geliyor ve sistemi yeniden başlat dedidigimde tekrar ses gidiyor.
  • İleti: 16939
Aşağıdaki komutlarla acpi_osi=Linux değişkeni eklemeyi dener misiniz?
echo 'GRUB_CMDLINE_LINUX="$GRUB_CMDLINE_LINUX acpi_osi=Linux"' | sudo tee  /etc/default/grub.d/acpi-osi.cfg
Çevrimdışı messett
  • İleti: 22
  • RAM: 4 GB
Bu çıkları girdim fakat bir sonuç yok  :)
Farklı bir forumda aynı konuyu açtım
sudo apt remove --purge alsa-base pulseaudio
Kaldırılıyor: alsa-base (1.0.25+dfsg-0ubuntu5) ...
Kaldırılıyor: cinnamon-dbg (4.0.10+tessa) ...
Kaldırılıyor: mint-meta-cinnamon (2018.11.28) ...
Kaldırılıyor: cinnamon (4.0.10+tessa) ...
Kaldırılıyor: libcanberra-pulse:amd64 (0.30-5ubuntu1) ...
Kaldırılıyor: pulseaudio-module-bluetooth (1:11.1-1ubuntu7.2) ...
Kaldırılıyor: pulseaudio (1:11.1-1ubuntu7.2) ...
Tetikleyiciler işleniyor: mime-support (3.60ubuntu1) ...
Tetikleyiciler işleniyor: desktop-file-utils (0.23+linuxmint4) ...
Tetikleyiciler işleniyor: libglib2.0-0:amd64 (2.56.3-0ubuntu0.18.04.1) ...
Tetikleyiciler işleniyor: man-db (2.8.3-2ubuntu0.1) ...
Tetikleyiciler işleniyor: gnome-menus (3.13.3-11ubuntu1.1) ...
(Veritabanı okunuyor ... 291018 dosya veya dizin kurulu durumda.)
Yapılandırma dosyaları kaldırılıyor: pulseaudio (1:11.1-1ubuntu7.2) ...
Yapılandırma dosyaları kaldırılıyor: alsa-base (1.0.25+dfsg-0ubuntu5) ...
Tetikleyiciler işleniyor: dbus (1.12.2-1ubuntu1) ...
sudo apt install ubuntu-desktop alsa* pulseaudio* python-alsaaudio python-pyalsa python3-alsaaudio python3-pyalsa apulse pulseaudio pulseaudio-module-bluetooth pulseaudio-module-x11 pulseaudio-utils pulsemixer libcanberra-pulse
Not, 'alsa*' ifadesi için 'alsaplayer-alsa' seçiliyor
Not, 'alsa*' ifadesi için 'alsa-base' seçiliyor
Not, 'alsa*' ifadesi için 'alsa-source' seçiliyor
Not, 'alsa*' ifadesi için 'alsamixergui' seçiliyor
Not, 'alsa*' ifadesi için 'alsaplayer-output' seçiliyor
Not, 'alsa*' ifadesi için 'alsaplayer' seçiliyor
Not, 'alsa*' ifadesi için 'alsaplayer-jack' seçiliyor
Not, 'alsa*' ifadesi için 'alsaplayer-common' seçiliyor
Not, 'alsa*' ifadesi için 'alsa' seçiliyor
Not, 'alsa*' ifadesi için 'alsaplayer-esd' seçiliyor
Not, 'alsa*' ifadesi için 'alsaplayer-gtk' seçiliyor
Not, 'alsa*' ifadesi için 'alsa-utils' seçiliyor
Not, 'alsa*' ifadesi için 'alsaplayer-text' seçiliyor
Not, 'alsa*' ifadesi için 'alsa-firmware-loaders' seçiliyor
Not, 'alsa*' ifadesi için 'alsaplayer-xosd' seçiliyor
Not, 'alsa*' ifadesi için 'alsa-tools' seçiliyor
Not, 'alsa*' ifadesi için 'alsaplayer-nas' seçiliyor
Not, 'alsa*' ifadesi için 'alsaplayer-oss' seçiliyor
Not, 'alsa*' ifadesi için 'alsaplayer-interface' seçiliyor
Not, 'alsa*' ifadesi için 'alsaplayer-daemon' seçiliyor
Not, 'alsa*' ifadesi için 'alsa-tools-gui' seçiliyor
Not, 'alsa*' ifadesi için 'alsa-oss' seçiliyor
Not, 'alsa' yerine 'alsa-base' seçiliyor
Not, 'alsaplayer' yerine 'alsaplayer-common' seçiliyor
Not, 'pulseaudio*' ifadesi için 'pulseaudio' seçiliyor
Not, 'pulseaudio*' ifadesi için 'pulseaudio-module-lirc' seçiliyor
Not, 'pulseaudio*' ifadesi için 'pulseaudio-dlna' seçiliyor
Not, 'pulseaudio*' ifadesi için 'pulseaudio-module-raop' seçiliyor
Not, 'pulseaudio*' ifadesi için 'pulseaudio-module-zeroconf' seçiliyor
Not, 'pulseaudio*' ifadesi için 'pulseaudio-module-jack' seçiliyor
Not, 'pulseaudio*' ifadesi için 'pulseaudio-module-gconf' seçiliyor
Not, 'pulseaudio*' ifadesi için 'pulseaudio-module-bluetooth' seçiliyor
Not, 'pulseaudio*' ifadesi için 'pulseaudio-equalizer' seçiliyor
Not, 'pulseaudio*' ifadesi için 'pulseaudio-esound-compat' seçiliyor
Not, 'pulseaudio*' ifadesi için 'pulseaudio-utils' seçiliyor
E: python3-alsaaudio paketi bulunamadı
E: python3-pyalsa paketi bulunamadı
E: pulseaudio-module-x11 paketi bulunamadı
Bunun LinuxMİNT için derlenmiş farklı bir kodu varsa işe yarayabilir gibime geliyor. Söz sizde hocam  :)
  • İleti: 16939
Aynı konuyu farklı kaynaklarda çözmeye çalışmak sorunun derinleşmesine katkıda bulunabiliyor. Bu sebeple, kendi adıma bu tür konulara pek dönüş yapma eğiliminde olmuyorum. Farklı kaynaklardan, birbirinden habersiz olarak alacağınız öneriler; basit bir sorunu dahi karmaşık bir hale sokabilir.
Bununla birlikte, bu paketlerin yapılandırma dosyaları ile kaldırılıp, sonra yeniden kurdurulmaya çalışılması; eksik/silinmiş ya da düzenlendiği için karışmış dosyaları eski haline getirmek için olmalı. Bunun yerine aşağıdaki komutla ilgili paketler ilk haline getirilebilir.
sudo apt install --reinstall -o Dpkg::Options::="--force-confask,confnew,confmiss" pulseaudio linux-sound-base alsa-base alsa-utils
Ayrıca sorunun çözümü için; ses ile ilgili paketlerden ziyade, çekirdek güncellemesini denemek daha uygun olabilir. Buradaki uygulama ile çekirdek sürümü kolayca güncellenebilir.
Komutla paketleri kaldırırken, masaüstü ve meta paketleri de kaldırmışsınız; forumda nasıl yeniden kurulacağı ile ilgili konular mevcut.
« Son Düzenleme: 30 Nisan 2019, 01:21:59 Gönderen: Butterfly »
