Gönderen Konu: [Çözüldü] Ralink RT2500 Ağları Görüyor Ama Bağlanmıyor  (Okunma sayısı 183 defa)
Çevrimdışı cennetyurdum
  • İleti: 5
z@zpb:~$ inxi -SMNnxxz
System:
  Host: zpb Kernel: 4.15.0-46-generic x86_64 bits: 64 compiler: gcc v: 7.3.0
  Desktop: Xfce 4.12.3 tk: Gtk 2.24.31 wm: xfwm4 dm: LightDM
Machine:
  Type: Portable System: NEC s product: Packard Bell EasyNote v: PB24M04029
  serial: <filter>
  Mobo: NEC s model: Dragon A v: 5a serial: <filter> BIOS: NEC S v: R1.04
  date: 09/30/2005
Network:
  Device-1: Ralink RT2500 Wireless 802.11bg driver: rt2500pci v: 2.3.0
  bus ID: 00:11.0 chip ID: 1814:0201
  IF: wlp0s17 state: down mac: <filter>
  Device-2: ULi 1689 1573 integrated ethernet. vendor: Packard Bell B.V.
  driver: uli526x v: kernel port: e000 bus ID: 00:1b.0 chip ID: 10b9:5263
  IF: enp0s27 state: down mac: <filter>
  Device-3: ULi M7101 Power Management  vendor: Packard Bell B.V.
  type: network bridge driver: N/A port: e000 bus ID: 00:1e.1
  chip ID: 10b9:7101
  Device-4: ASUSTek type: USB driver: rt2800usb bus ID: 1-3:3
  chip ID: 0b05:17e8
  IF: wlx382c4a4f16f4 state: up mac: <filter>
 lspci -nnk | grep -iA2 net
00:11.0 Network controller [0280]: Ralink corp. RT2500 Wireless 802.11bg [1814:0201] (rev 01)
Subsystem: Ralink corp. RT2500 Wireless 802.11bg [1814:2560]
Kernel driver in use: rt2500pci
00:1b.0 Ethernet controller [0200]: ULi Electronics Inc. ULi 1689,1573 integrated ethernet. [10b9:5263] (rev 50)
Subsystem: Packard Bell B.V. ULi 1689,1573 integrated ethernet. [1631:c00a]
Kernel driver in use: uli526x
Kernel modules: uli526x
z@zpb:~$ lsusb
Bus 001 Device 005: ID 0781:5567 SanDisk Corp. Cruzer Blade
Bus 001 Device 004: ID 0930:6545 Toshiba Corp. Kingston DataTraveler 102/2.0 / HEMA Flash Drive 2 GB / PNY Attache 4GB Stick
Bus 001 Device 003: ID 0b05:17e8 ASUSTek Computer, Inc.
Bus 002 Device 002: ID 046d:c52f Logitech, Inc. Unifying Receiver
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
z@zpb:~$ rfkill list
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
1: phy1: Wireless LAN
Soft blocked: no
Hard blocked: no
z@zpb:~$ sudo lshw -C network
 password for z:
  *-network:0
       açıklama: Kablosuz arayüz
       ürün: RT2500 Wireless 802.11bg
       üretici: Ralink corp.
       physical id: 11
       bus info: pci@0000:00:11.0
       mantıksal ad: wlp0s17
       sürüm: 01
       serial: 00:10:60:63:fe:75
       genişlik: 32 bits
       saat: 33MHz
       kapasiteler: pm bus_master cap_list eternet physical wireless
       yapılandırma: broadcast=yes driver=rt2500pci driverversion=4.15.0-46-generic firmware=N/A latency=64 link=no multicast=yes wireless=IEEE 802.11
       kaynaklar: irq:19 bellek:ffffe000-ffffffff
  *-network:1
       açıklama: Eternet interface
       ürün: ULi 1689,1573 integrated ethernet.
       üretici: ULi Electronics Inc.
       physical id: 1b
       bus info: pci@0000:00:1b.0
       mantıksal ad: enp0s27
       sürüm: 50
       serial: 00:40:d0:8c:f1:17
       kapasite: 100Mbit/s
       genişlik: 32 bits
       saat: 33MHz
       kapasiteler: pm bus_master cap_list eternet physical mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
       yapılandırma: autonegotiation=on broadcast=yes driver=uli526x driverversion=0.9.3 latency=128 link=no maxlatency=40 mingnt=20 multicast=yes port=MII
       kaynaklar: irq:20 ioport:e000(boyut=256) bellek:d000a300-d000a3ff
  *-network
       physical id: 3
       bus info: usb[member=3516]1:3
       mantıksal ad: wlx382c4a4f16f4
       serial: 38:2c:4a:4f:16:f4
       kapasiteler: eternet physical wireless
       yapılandırma: broadcast=yes driver=rt2800usb driverversion=4.15.0-46-generic firmware=0.36 ip=192.168.1.24 link=yes multicast=yes wireless=IEEE 802.11
z@zpb:~$ iwconfig | grep Power
enp0s27   no wireless extensions.
          Mode:Managed  Access Point: Not-Associated   Tx-Power=20 dBm
          Power Management:off
          Bit Rate=78 Mb/s   Tx-Power=20 dBm
          Power Management:on
z@zpb:~$ lsmod
ccm                    20480  6
mmc_block              36864  0
tifm_sd                20480  0
edac_mce_amd           28672  0
snd_hda_codec_si3054    16384  1
snd_hda_intel          40960  3
snd_hda_codec         126976  4 snd_hda_codec_generic,snd_hda_intel,snd_hda_codec_realtek,snd_hda_codec_si3054
rt2800usb              32768  0
snd_hda_core           81920  5 snd_hda_codec_generic,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek,snd_hda_codec_si3054
rt2x00usb              20480  1 rt2800usb
snd_pcm                98304  4 snd_hda_intel,snd_hda_codec,snd_hda_codec_si3054,snd_hda_core
rt2800lib             114688  1 rt2800usb
arc4                   16384  4
rt2500pci              28672  0
rt2x00pci              16384  1 rt2500pci
rt2x00mmio             16384  1 rt2500pci
rt2x00lib              53248  6 rt2800usb,rt2x00mmio,rt2500pci,rt2x00pci,rt2x00usb,rt2800lib
mac80211              778240  4 rt2x00pci,rt2x00lib,rt2x00usb,rt2800lib
cfg80211              622592  2 rt2x00lib,mac80211
snd                    81920  17 snd_hda_codec_generic,snd_seq,snd_seq_device,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek,snd_timer,snd_hda_codec_si3054,snd_pcm,snd_rawmidi
pcmcia                 57344  0
k8temp                 16384  0
yenta_socket           49152  0
eeprom_93cx6           16384  1 rt2500pci
pcmcia_rsrc            20480  1 yenta_socket
tifm_7xx1              16384  0
pcmcia_core            24576  3 pcmcia,pcmcia_rsrc,yenta_socket
tifm_core              16384  2 tifm_7xx1,tifm_sd
sch_fq_codel           20480  7
usb_storage            69632  1 uas
hid                   118784  3 usbhid,hid_generic
radeon               1470464  9
i2c_algo_bit           16384  1 radeon
ttm                   106496  1 radeon
drm_kms_helper        172032  1 radeon
pata_acpi              16384  0
i2c_ali15x3            16384  0
pata_ali               16384  1
drm                   401408  12 drm_kms_helper,radeon,ttm
firewire_ohci          40960  0
i2c_ali1535            16384  0
firewire_core          65536  1 firewire_ohci
uli526x                24576  0
sdhci_pci              32768  0
sdhci                  49152  1 sdhci_pci
crc_itu_t              16384  1 firewire_core
z@zpb:~$ dkms status
z@zpb:~$
Düzenleme: Kod etiketi
« Son Düzenleme: 17 Mart 2019, 11:45:11 Gönderen: Butterfly »
  • İleti: 16812
Ynt: Rt2500 görüyor baglanmiyor
« Yanıtla #1 : 17 Mart 2019, 11:55:58 »
@cennetyurdum , lütfen çıktıları kod etiketi içinde paylaşınız.
Aşağıdaki komutları sırasıyla uçbirimde çalıştırarak, kablosuz ağ aygıtı için güç yönetimini pasifleştirmeyi deneyebilirsiniz.
echo -e '[connection]\nwifi.powersave = 2' | sudo tee /etc/NetworkManager/conf.d/default-wifi-powersave-on.conf
sudo service network-manager restart
Sorun yukarıdaki komutlarla çözülmezse, sırasıyla aşağıdaki komutları çalıştırmayı denersiniz.
sudo sed -i "s/REGDOMAIN=/REGDOMAIN=TR/g" /etc/default/crda
  • İleti: 5
« Yanıtla #2 : 18 Mart 2019, 01:36:29 »
Sorun çözüldü. Şu an kablosuz bağlantıdan yazıyorum. İlgilenen arkadaşa teşekkür ederim. Yaklaşık 40 kadar farklı linux denemiştim ve yorulmuştum.
Bir sorum daha olacak. 2004 model 2GB ram - 128 mb ekran kartı olan 17 inch PackardBell kullanıyorum. O kadar temiz bir nootebook ki rafa kaldırmaya kıyamıyorum. Amd 64 Turion işlemci var. 32 mi 64 mü kurmalıyım. Ayrıca bu donanımla Linux Minti  hızlandırmam için yapılacak birşeyler var mıdır? Program önerir misiniz?
İlgili arkadaşa tekrar teşekkür ederim.
  • İleti: 16812
« Yanıtla #3 : 18 Mart 2019, 01:42:26 »
Rica ederiz.
Başlığı etiketlerseniz, bu konuyu kilitleyelim.
Forumda aynı başlıkta farklı hususları konuşmuyoruz. Diğer aygıt için, aşağıdaki konumuzdaki genel sorunlar için istenen komutun çıktısıyla yeni bir konu açarsanız, yardımcı olmaya çalışalım.
