Herkese hayırlı ramazanlar hayırlı akşamlar,benim linuxu kurduğumdan beri kırılma donma sorunu var özellikle en çok youtube tarayıcı üzerinde oluyor.Normalde hdd'ten film izlerkende oluyor takılma donma kırılma gibi.Hemen çıktıları paylaşıyorum..
inxi -SGx
System: Host: root Kernel: 4.4.0-78-generic x86_64 (64 bit gcc: 5.4.0)
Desktop: Xfce 4.12.3 (Gtk 2.24.28) Distro: Linux Mint 18.1 Serena
Graphics: Card-1: Intel Skylake Integrated Graphics bus-ID: 00:02.0
Card-2: NVIDIA GM107M [GeForce GTX 950M] bus-ID: 01:00.0
Resolution: 1920x1080@60.05hz
GLX Renderer: GeForce GTX 950M/PCIe/SSE2
GLX Version: 4.5.0 NVIDIA 381.22 Direct Rendering: Yes
OpenGL renderer string: GeForce GTX 950M/PCIe/SSE2
GL_EXT_render_snorm, GL_EXT_robustness, GL_EXT_sRGB,
GL_NV_conditional_render, GL_NV_copy_buffer, GL_NV_copy_image,
00:02.0 VGA compatible controller: Intel Corporation Skylake Integrated Graphics (rev 06)
01:00.0 3D controller: NVIDIA Corporation GM107M [GeForce GTX 950M] (rev a2)
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 16384 x 16384
eDP-1-1 connected 1920x1080+0+0 344mm x 193mm
1920x1080 60.05*+ 59.93
1680x1050 59.95 59.88
1600x1024 60.17
1400x1050 59.98
1280x1024 60.02
1440x900 59.89
1280x960 60.00
1360x768 59.80 59.96
1152x864 60.00
1024x768 60.04 60.00
960x720 60.00
928x696 60.05
896x672 60.01
960x600 60.00
960x540 59.99
800x600 60.00 60.32 56.25
840x525 60.01 59.88
800x512 60.17
700x525 59.98
640x512 60.02
720x450 59.89
640x480 60.00 59.94
680x384 59.80 59.96
576x432 60.06
512x384 60.00
400x300 60.32 56.34
320x240 60.05
HDMI-1-1 disconnected
DP-1-1 disconnected
Section "ServerLayout"
Identifier "layout"
Screen 0 "nvidia"
Inactive "intel"
Identifier "intel"
Driver "modesetting"
BusID "PCI:0@0:2:0"
Option "AccelMethod" "None"
Section "Screen"
Identifier "intel"
Device "intel"
Identifier "nvidia"
Driver "nvidia"
BusID "PCI:1@0:0:0"
Section "Screen"
Identifier "nvidia"
Device "nvidia"
ii bumblebee 3.2.1-98~xenialppa1 amd64 NVIDIA Optimus support for Linux
ii bumblebee-nvidia 3.2.1-98~xenialppa1 amd64 NVIDIA Optimus support using the proprietary NVIDIA driver
rc nvidia-375 375.39-0ubuntu0.16.04.1 amd64 NVIDIA binary driver - version 375.39
ii nvidia-381 381.22-0ubuntu0~gpu16.04.2 amd64 NVIDIA binary driver - version 381.22
rc nvidia-opencl-icd-375 375.39-0ubuntu0.16.04.1 amd64 NVIDIA OpenCL ICD
ii nvidia-prime 0.8.2linuxmint1 amd64 Tools to enable NVIDIA's Prime
ii nvidia-prime-applet 1.0.6 all An applet for NVIDIA Prime
ii nvidia-settings 381.22-0ubuntu0~gpu16.04.1 amd64 Tool for configuring the NVIDIA graphics driver
ii primus 20150328-3~xenialppa2 amd64 client-side GPU offloading for NVIDIA Optimus
ii primus-libs:amd64 20150328-3~xenialppa2 amd64 Shared libraries for primus
ii primus-libs:i386 20150328-3~xenialppa2 i386 Shared libraries for primus
ii primus-libs-ia32:i386 20150328-3~xenialppa2 i386 Shared libraries for primus (32-bit)
ii virtualgl 2.4.1-1~xenialppa1 amd64 Toolkit for displaying OpenGL applications to thin clients
ii virtualgl-libs:amd64 2.4.1-1~xenialppa1 amd64 Library files for virtualgl
